Question for solo narrowboaters on the Thames
Neil2
8 minutes ago, Neil2 said:
Yes I was thinking how much would the boat move fore or aft as the water falls/rises, also isn't there still a chance the bow might get hung up when descending?  How do you know how much bow line to attach?
Pythagoras can help you. For example if you use a 20' fixed line and the lock rise is 4' which is quite typical, then the boat will move forwards or backwards 5 inches.
Ah yes I see, the bow line forms one side of a right angle triangle and if you assume the line is level before or after the exercise once you know the rise/fall you can calculate the other side of the triangle - thanks!
I have not allowed for the line stretching under tension.
14 hours ago, Neil2 said:
... also isn't there still a chance the bow might get hung up when descending?  How do you know how much bow line to attach?
I tend to overestimate how much bow rope I need for this reason. But if you've taken the rope forward there's no chance of getting hung up until that bow rope is vertical. That would be a long drop.
Edited by blackrose
I struggle with that, esp as Pythagarus might have had 16 digits per Greek foot, help me out here, which is the hypotenuse?
EDIT yes, h must be the longest measurement, so is that the length of the boat or the length of the bow rope to bollard when in the bottom of the lock?
EDIT x 2~       20 x 2 = 400 , 4 x 4 = 16,  what now ,  assuming no calculator .............
5 x 5 = 25
25/12=2.08, ??????
Edited by LadyG
20^2 = 400
4 ^ 2 = 16
400 - 16 = 384
Sqrt(384) = 19.6 (approx) - if you don't have a calculator you have to guess this by trial and error.
So the horizontal distance from bollard to boat reduces from 20 (lock full) to 19.6 (empty) , a difference of 0.4 feet or about 5 inches.
[There is a whole page on Wikipedia on computing square roots.  Not something I have ever needed to do.  https://en.m.wikipedia.org/wiki/Methods_of_computing_square_roots ]
