mross Posted August 8, 2016 Report Posted August 8, 2016 (edited) Does anyone have any experience with IBS inverters? At £1,764 inc VAT for a 1600W PSW it seems good value and it can handle starting loads up to 4.5kW. I particularly like the fact that it can power a Nespresso! http://www.tbruk.com/us16012v--us16024v-inverter-4753-p.asp It's made in Switzerland. Edited August 8, 2016 by mross
WotEver Posted August 8, 2016 Report Posted August 8, 2016 No personal experience but looking at the spec I'd point out that the 1.2A off-load consumption is pretty high. That's nearly 30 Ah per day consumed just by having it switched on, so you'd need to ensure that it's only on when required. Only 7.3 Ah per day in standby so that's not bad at all. Tony
Keith M Posted August 8, 2016 Report Posted August 8, 2016 I would say that is a silly price Mastervolt has 1500 watt inverters for around £ 630 inc vat mark Keith
bottle Posted August 8, 2016 Report Posted August 8, 2016 Have a look here a http://chandlerydirect.com/chandlery-store-uk/12-volt-inverters-chandlery-store.html ps. Have bought from this company but am not connected in anyway whatsoever.
Chewbacka Posted August 8, 2016 Report Posted August 8, 2016 I have one of these http://www.advanceyacht.co.uk/studer-marine-inverters-shop/studer-aj-2400-24-inverter the power saving mode is only 1.2W and 16W when idle but running with a start-up power of 5.2kVA for 5 secs. I am very happy with it as you can run a cheap A+++ fridge and only use 1.2W when the compressor is not running, but you MUST remember to turn of TV or microwave etc as their standby power is enough to keep it awake.
Onewheeler Posted August 8, 2016 Report Posted August 8, 2016 A well-silly price. I've recently fitted a slightly smaller invertor (1 kW cont / 2 kW peak) from Sunshine Solar http://www.sunshinesolar.co.uk/with a much lower quiescent current, very good it is and their range is much cheaper. It also seems to cope well with very warm engine rooms. Martin/
mross Posted August 8, 2016 Author Report Posted August 8, 2016 I dunno why I thought PSW inverters cost £2,000! Must have been in Midland Swindlers too much!
mross Posted August 8, 2016 Author Report Posted August 8, 2016 (ps is that James's brother?) Maybe. There are a lot of them. PM me.
Richard10002 Posted August 8, 2016 Report Posted August 8, 2016 I dunno why I thought PSW inverters cost £2,000! Must have been in Midland Swindlers too much! My Sterling 2500w PSW inverter 80A charger powers our Nespresso without complaint. Don't know what the start up power is. I wouldn't buy another Sterling because it uses 4A when on but with nothing running, and it won't start up from Standby without a fairly big load.... So I can't leave it on 24/7, which is irritating.
Guest Posted August 8, 2016 Report Posted August 8, 2016 My Sterling 2500w PSW inverter 80A charger powers our Nespresso without complaint. Don't know what the start up power is. I wouldn't buy another Sterling because it uses 4A when on but with nothing running, and it won't start up from Standby without a fairly big load.... So I can't leave it on 24/7, which is irritating. True of my sterling (mine isn't a charger.) Never found it a big problem in standby (very economical) but it only powers the washer and the fridge most of the time. Bit of a pain when occasionally using power tools with its few seconds delay, so on these occasions I plug a small table lamp in which holds the inverter in.
