Rob1234 Posted March 18, 2015 Report Share Posted March 18, 2015 Hi Looking for advice on gearbox issue, please. The other day my boat lost drive, the gearbox oil was low and pretty grimey. After a top up it went again and after a few miles it stopped again, could it have a blockage? I pump SAE30 in as that all I had. Rob I mean "put" SAE30 in..... got gearbox and pumps on the brain!! Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 18, 2015 Report Share Posted March 18, 2015 Depends on what the gearbox manual says that it needs and the reason for you needing to top up the fluid in a hurry. Do you have any oil in the bilge or engine tray. Is there an obvious place for the leak -crack, blown gasket or seal.... What make and model is the gearbox? Link to comment Share on other sites More sharing options...
MtB Posted March 18, 2015 Report Share Posted March 18, 2015 (edited) Yes, make and model of gearbox is everything. Not much chance of accurate diagnosis without that. Post a photo if there is no data label. Edited March 18, 2015 by Mike the Boilerman Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 I will get the model number off the plate and post it tomorrow, above is a pic from the manual I found online! Cheers Link to comment Share on other sites More sharing options...
Stilllearning Posted March 18, 2015 Report Share Posted March 18, 2015 That looks like a PRM gearbox. They lose drive if there isn't enough oil in the box, so look for a leak. Link to comment Share on other sites More sharing options...
RLWP Posted March 18, 2015 Report Share Posted March 18, 2015 If it is a PRM box, SAE30 is fine. Do you lose forward and reverse, or just one of them Although, I'd also say you are desperately short of oil Richard Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 The level doesnt seem to have gone down since I refilled....will check again when I get home! yes no forward or reverse! Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 18, 2015 Report Share Posted March 18, 2015 Are all the linkages secure in the correct places? A slipping joint could simply not act on the gearbox when the control is moved. Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 I have checked the control arm? moves fully to the stop when throttle operated. The oil is sort of coffee colour....is that normal? Link to comment Share on other sites More sharing options...
RLWP Posted March 18, 2015 Report Share Posted March 18, 2015 The level doesnt seem to have gone down since I refilled....will check again when I get home! yes no forward or reverse! Low oil Well, it could be something more drastic, but if it gets better when you put oil in, I'd say that was pretty conclusive Those PRM dipsticks are very difficult to read. They pick up droplets off the insides of the box when you take them out to inspect them giving false readings Richard I have checked the control arm? moves fully to the stop when throttle operated. The oil is sort of coffee colour....is that normal? No, sounds like it has water in it. Has your box got an oil cooler? PRM oil is often entirely clear Richard Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 It has water pipes connected to it..... Link to comment Share on other sites More sharing options...
Tony Dunkley Posted March 18, 2015 Report Share Posted March 18, 2015 Almost certainly , it's the gearbox oil cooler that's developed an internal leak. Cooling water leaking into the gearbox oil when not running, and vice versa when you are running the engine. If the engine and gearbox is keel (skin tank) cooled, there'll be oil in the engine cooling system. Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 Can the gearbox oil cooler be rebuilt...or is it a case of replacing? And yet it is keel cooled. Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 18, 2015 Report Share Posted March 18, 2015 Coffee colour as in white coffee? Then the oil is emulsified with water (likely from the cooler but not definitively) find the leak first! Coffee colour as in Black coffee? That's how used oil often looks -shiny surface with dark (suspended carbon) depths. In reality gearbox oil should be long term stable at the colour it was when you first filled the box -there should be little or no colour change and little level change, for years. If there is a leak the leaked oil must be somewhere, choices include bilges, engine coolant header tank, cut. engines burn oil gearboxes don't. Where does the cooling coil get it's cold from? Air, outside water, engine cooling water?? Look at the engine cooling water, is there oil in there? Link to comment Share on other sites More sharing options...
RLWP Posted March 18, 2015 Report Share Posted March 18, 2015 (edited) Can the gearbox oil cooler be rebuilt...or is it a case of replacing? And yet it is keel cooled. Replacing. Now, to get you home. Take one pipe off at the gearbox end, and the other pipe off at the oil cooler end. Then connect the pipe still attached to the gearbox back to the other port, and do the same on the oil cooler. You should now have a loop coming out of and going back into the gearbox, and another going out and into the oil cooler If you can, change the oil in the gearbox That will get you home, it will probably last longer than that - as a hire boat or PRM didn't have an oil cooler at all As Tony says, you may find oil in the cooling water for the engine MORE: This isn't a major disaster - the gearbox shouldn't suffer too much from this water, oil in the cooling water is messy but not really a problem, and oil coolers are readily available and easy to change Richard Coffee colour as in white coffee? Then the oil is emulsified with water (likely from the cooler but not definitively) find the leak first! Coffee colour as in Black coffee? That's how used oil often looks -shiny surface with dark (suspended carbon) depths. In reality gearbox oil should be long term stable at the colour it was when you first filled the box -there should be little or no colour change and little level change, for years. If there is a leak the leaked oil must be somewhere, choices include bilges, engine coolant header tank, cut. engines burn oil gearboxes don't. Where does the cooling coil get it's cold from? Air, outside water, engine cooling water?? Look at the engine cooling water, is there oil in there? A PRM emulsifies any water in the oil very nicely and does a good imitation of a Latte. The recommended installation is a water cooled oil cooler in the engine circuit Richard Edited March 18, 2015 by RLWP Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 Definetly Latte! Managed to get to our destination...we towed it with my Sons boat! So it seems I probably have a faulty oil cooler and probably low oil level. This gives me something to go on....hopefully! I will let you know how I get on....cheers for the help so far! I will be back for more no doubt! Rob Link to comment Share on other sites More sharing options...
bizzard Posted March 18, 2015 Report Share Posted March 18, 2015 Definetly Latte! Managed to get to our destination...we towed it with my Sons boat! So it seems I probably have a faulty oil cooler and probably low oil level. This gives me something to go on....hopefully! I will let you know how I get on....cheers for the help so far! I will be back for more no doubt! Rob I'd drain out that box as soon as possible. If the bearing races get rusty the box can make a horrible harsh droning noise like a low flying Lancaster bomber. If you've had a wheel bearing on your car wear out you'll know what I mean. ''Know what I mean Arry''. Link to comment Share on other sites More sharing options...
Rob1234 Posted March 18, 2015 Author Report Share Posted March 18, 2015 ok cheers. Link to comment Share on other sites More sharing options...
RLWP Posted March 18, 2015 Report Share Posted March 18, 2015 If you do as I suggest and loop the outlet pipe on the gearbox back to the inlet, you can run the engine with no oil pipes on the oil cooler. Bet you water comes out of the ports when the engine gets hot Richard Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 18, 2015 Report Share Posted March 18, 2015 OK "latte" oil definitely needs removing and replacing, maybe with a second change after say 10 hours running. Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 I checked the oil level this morning and it hasn't gone down, so it would seem not to have a major leak. Took the pipes off the oil cooler and they also contain Latte! I cannot loop them back into the box as the ends don't match. I ran the boat in gear with the pipes off and no oil/water seemed to be flowing? The gear box is a Newage. I have taken some pics, but cant seem to upload them! Link to comment Share on other sites More sharing options...
RLWP Posted March 19, 2015 Report Share Posted March 19, 2015 (edited) OK, that's an early PRM Newage gearbox - a 100 or 160. The double ended lever and oil filter on top are characteristic You definitely have oil in the water. It either comes from the oil cooler, or it comes from the gearbox standing in water You can wash the gearbox and oil cooler out with diesel - run it for a while to clear it out Richard Edited March 19, 2015 by RLWP Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 Thanks Richard for help uploading pics. The gearbox isn't sitting in water, so I guess it must be the cooler. Maybe start with a good clean with diesel, should oil be pumped out of the pipes when not connected? Link to comment Share on other sites More sharing options...
MtB Posted March 19, 2015 Report Share Posted March 19, 2015 I can't help but notice all the wood chippings in the engine bay. Been doing a bit of chainsaw carpentry?! Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 No...my son has Ferrets! As boats and walkers go by, they say......"look that boat has rabbits, no they are weasels" Link to comment Share on other sites More sharing options...
