MtB Posted March 19, 2015 Report Share Posted March 19, 2015 Brilliant! Even better than '....oh look they have a sink in there, and TAPS!!' Link to comment Share on other sites More sharing options...
RLWP Posted March 19, 2015 Report Share Posted March 19, 2015 Thanks Richard for help uploading pics. The gearbox isn't sitting in water, so I guess it must be the cooler. Maybe start with a good clean with diesel, should oil be pumped out of the pipes when not connected? It may not be sitting in water now, that doesn't mean it wasn't in the past Richard Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 It may not be sitting in water now, that doesn't mean it wasn't in the past True! So maybe a good flush through with some diesel might do the trick! Link to comment Share on other sites More sharing options...
gazza Posted March 19, 2015 Report Share Posted March 19, 2015 (edited) Those oil cooler hoses look ripe for changing too.... Try a local Hydraulic firm, they will be cheap as chips to replace. Is your engine raw water cooled? If keel cooled are you suffering from coolant loss? Edited March 19, 2015 by gazza Link to comment Share on other sites More sharing options...
RLWP Posted March 19, 2015 Report Share Posted March 19, 2015 What you need to do is pressure test the cooler. You have three options: Disconnect the oil hoses and run the engine, when it is hot, the pressure in the cooling system will force water out the oil side of the cooler Disconnect the water hoses and run the engine. The oil pressure in the box will push oil out of the water side of the cooler Just buy a cooler Richard Link to comment Share on other sites More sharing options...
gazza Posted March 19, 2015 Report Share Posted March 19, 2015 What you need to do is pressure test the cooler. You have three options: Disconnect the oil hoses and run the engine, when it is hot, the pressure in the cooling system will force water out the oil side of the cooler Disconnect the water hoses and run the engine. The oil pressure in the box will push oil out of the water side of the cooler Just buy a cooler Richard My thoughts exactly! In the workshop I've got an old bowman heat exchanger that has a leaking tube stack - its no use to man nor beast at the moment - well not if you want raw water cooling as I do! It was a freebie so I shouldnt have expected too much. Tube stacks are an eye watering price, I have neither the time nor inclnation to rebuild the original so on the shelf it must stay until a decent secondhand replacement turns up Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 I draws water from the canal and spits it out the exhaust! Is that Raw water cooled? It has a heat exchanger ( which was empty the other day) but since top up, stayed full. Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 19, 2015 Report Share Posted March 19, 2015 Flush engine with diesel and discard it once or twice, then fill with the correct oil. If it stays clean then problem was a historic immersion in water. If it get's milky again problem seems to be a water leak into the oil -check hoses and oil cooler. Link to comment Share on other sites More sharing options...
gazza Posted March 19, 2015 Report Share Posted March 19, 2015 I draws water from the canal and spits it out the exhaust! Is that Raw water cooled? It has a heat exchanger ( which was empty the other day) but since top up, stayed full. As Richard has said, time for a new gearbox oil cooler. The tubestack is leaking cooling water into your gearbox oil. Link to comment Share on other sites More sharing options...
RLWP Posted March 19, 2015 Report Share Posted March 19, 2015 I draws water from the canal and spits it out the exhaust! Is that Raw water cooled? It has a heat exchanger ( which was empty the other day) but since top up, stayed full. Many BMCs were set up with two cooling circuits. There is a circuit running through the block and head, and into a large header tank with a heat exchanger in it. You must keep this circuit topped up or you'll blow the head gasket. Flowing through the heat exchanger is canal water sucked from a sea cock, through a pump, through the heat exchanger, possibly around the exhaust manifold and then out of the exhaust. The gearbox cooler is probably in this circuit too Richard Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 19, 2015 Report Share Posted March 19, 2015 My old boat had raw water pumped through the block by a jabsco pump on the cam shaft, back in the days of the 105E petrol engine. Two of them, they never both started simply. Link to comment Share on other sites More sharing options...
RLWP Posted March 19, 2015 Report Share Posted March 19, 2015 My old boat had raw water pumped through the block by a jabsco pump on the cam shaft, back in the days of the 105E petrol engine. Two of them, they never both started simply. I'm not sure which I prefer. A skin tank is a closed system with corrosion protection in the water. A straight raw water system like that is simple and carries the least components The indirect raw water system is about as complicated as it gets! Richard Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 I will have a look for a new oil cooler.....and do a flush with some diesel! Cheers for all the advice! Link to comment Share on other sites More sharing options...
Rob1234 Posted March 19, 2015 Author Report Share Posted March 19, 2015 Just one more thing! What is the little turn knob on the gearbox to the left of the filler nut? Link to comment Share on other sites More sharing options...
RLWP Posted March 19, 2015 Report Share Posted March 19, 2015 It's the vent for the box Richard Link to comment Share on other sites More sharing options...
David Mack Posted March 19, 2015 Report Share Posted March 19, 2015 I'm not sure which I prefer. A skin tank is a closed system with corrosion protection in the water. A straight raw water system like that is simple and carries the least components The indirect raw water system is about as complicated as it gets! Richard Which is fine in an engine designed for it, but a lightweight engine designed for vehicle use includes components which are not sufficiently corrosion-resistant for use with constantly refreshed oxygenated water - especially salt water. I once had a direct cooled BMC 1.5 in which one of the core plugs rusted through, resulting in a spurt of water which happened to land on the dipstick, where it all ran down and turned the oil into latte! vehciel Link to comment Share on other sites More sharing options...
Arthur Brown Posted March 19, 2015 Report Share Posted March 19, 2015 I have to say that some of the flexi pipes in the pictures have seen better days. While you have your head in the engine hole some new pipe would save the next issue being a split pipe. Link to comment Share on other sites More sharing options...
Rob1234 Posted March 20, 2015 Author Report Share Posted March 20, 2015 looks like midland chandlers for the oil cooler http://www.ebay.co.uk/itm/Bowman-DC120-22mm-Oil-Cooler-/271639458752?pt=LH_DefaultDomain_3&hash=item3f3ef933c0 Looking for a Hydraulic company in Leamington spa area for some hoses! Link to comment Share on other sites More sharing options...
gazza Posted March 20, 2015 Report Share Posted March 20, 2015 http://www.castlehyd.co.uk/ Any good to you? Link to comment Share on other sites More sharing options...
Rob1234 Posted March 20, 2015 Author Report Share Posted March 20, 2015 Just spoke to them, they can match up the hoses if I bring the old ones in. Probably wouldn't have a oil cooler on the shelf, although he said he has one...about a foot long and 5" in diameter! Sounds possible! Link to comment Share on other sites More sharing options...
Rob1234 Posted March 21, 2015 Author Report Share Posted March 21, 2015 I looped the oil pipe back into the gearbox as a member recommend, run it with some diesel in and drained. Popped some oil in and still no drive? Ran out of ideas and daylight so will look again in the morning! Link to comment Share on other sites More sharing options...
RLWP Posted March 21, 2015 Report Share Posted March 21, 2015 Put it back together with the pipes in the right place and with the correct oil. If it doesn't work then, you have a problem. Richard Link to comment Share on other sites More sharing options...
Rob1234 Posted March 21, 2015 Author Report Share Posted March 21, 2015 When the engine is running should the oil pipes be under pressure? I.e disconnected from oil cooler spurting oil out....because there is nothing coming out! Link to comment Share on other sites More sharing options...
RLWP Posted March 21, 2015 Report Share Posted March 21, 2015 From memory, yes. Without checking the book, I think the pump puts oil through the cooler before the internals of the box Not that it matters, oil should be coming out anyway Sound like your pump has failed Richard Link to comment Share on other sites More sharing options...
Rob1234 Posted March 22, 2015 Author Report Share Posted March 22, 2015 Can the pump be repaired / replaced....or do i need to find another gearbox! Gulp! Link to comment Share on other sites More sharing options...
