BMC 1.5 spill rail - flexi return pipe
StephenA
The spill rail on our BMC 1.5 has sheared where the rigid pipe from the last injector goes down to the CAV fuel filter. The fuel filter has a little bit of wobble on it and we suspect that is what caused the problem.
Does anyone know of a spill rail where that return line terminates in a flexi pipe coupling and also has a banjo for the fuel filter that has two pipe couplings on it (rather than it being part of the spill rail)?
I think the BSS now allows flexible spill rails IF they are marked as suitably fire resistant, the ends use proper fittings and you have non-return valves on the fuel tank end. I am very happy for a BSS inspector to correct me if this is wrong.
However certain marinisations of BMCs fit a stupidly thin bracket that attaches the filter to the cylinder head resulting in it waving about because of engine vibrations. Personally I would see about fitting a heavier bracket because eventually they snap but a friend of ours simply rammed a wooden wedge between the bracket and head and it seemed to be fine.
Please try to cure the problem rather than the symptom.
The pipe must carry the correct BS number on it, and be readable. It makes constructing flexible spill pipes a bit of a pain as you need to have at least one section with the number readable
It would be better to fix the wobbly filter, otherwise you could end up with a wobbly filter and a mysterious air leak in the diesel system
Richard
I'm sure it's down to the bracket on the fuel filter but the movement is minute - the spill rail sheared on the bit that was work hardened and we ended up with fuel sprayed all over the engine. We used to have a flexi rail but had to replace it because of the labelling issue
  • 2 months later...
Has anyone fitted this conversion kit from Calcutt :
http://www.calcuttboatsshop.com/shop/article_CKSPILLKIT1.5/SPILL-RAIL-KIT-BMC-1.5.html
And if so what the heck is the "banjo with stand pipe" used for?
It looks like it's designed to take a push fit pipe (with clip) but I thought you couldn't use those. I need a banjo that ends in a male thread to connect the return line to the tank to.
Edited by StephenA
To be absolutely certain I'd have to look it up. From memory, because there's a barb on that stub, you can use push fit pipes and clips as a spill back to the tank. It's straight pipes under push on pipes and jubilee clips that is the problem
Richard
So that would mean replacing the fuel return line to the tank which is armoured (and BSS marked) and has threaded ends if I can't find a banjo to male thread part.
The BSS says:
Fuel line connections must be screwed, compression, cone, brazed or flanged.
Flexible fuel hose connections must either be pre-made end fittings on hose assemblies, or hose clips/clamps onto hose nozzles or formed pipe-ends.
So I guess that explains the stand pipe.
Does anyone know if anyone does a banjo with an 1/8" threaded return port which I can use instead of the standpipe - as that kit means you have to throw away your existing fuel return pipe when you move from an old 1.5 spill rail (with the threaded final double port banjo) to a new 1.5/1.8 with the single port banjo.
As I mentioned above the Yard that made up my flexi spill rail made it up with jubilee clips.
Phil
Yes but that doesn't solve the problem with the fuel return line to the tank which has only recently been replaced. Ideally I want to be able to drop in a pre-engineered solution that doesn't involve me replacing lengths of perfectly good hose. Also I really do not like jubilee clips on fuel lines (I don't really like them on water lines).
As the boat is 100 miles away I can't.
What we currently have is:
A 5 banjo spill rail with the 5th banjo (the one for the fuel filter which is a bigger banjo) having an exit pipe that ends in a standard 1/8" threaded connection which the fuel return line to the tank screws onto.
Basically one of these:
http://www.asap-supplies.com/marine/leak-off-rails-and-pipes/fuel-injector-leak-off-spill-rail-for-bmc-1500-and-1800-diesel-131099
Now all anyone sells is
http://www.calcuttboatsshop.com/shop/article_A3ARG1100A/SPILL-RAIL-BMC-1.8.html
Where all 5 banjos are the same size and the one for the fuel filter has no secondary port. This is where the Calcutt converter kit comes in and provides the "Stand Pipe" as the feed back to the tank......
Edited by StephenA
So, you want the BSP male thread part fitting onto the banjo bolt of the converter kit?
Richard
MORE: How about this: http://www.ebay.co.uk/itm/Venhill-M10-20-deg-M10-banjo-20-deg-left-to-1-8bsp-Quick-build-brake-line-system-/181622888807?pt=UK_Motorcycle_Parts_13&hash=item2a49915967
Edited by RLWP
It probably would - I think the new spill rails have a smaller 5th banjo (the same size as the injectors) which is why the calcutt kit comes with an adaptor for the fuel filter (to allow a smaller double height banjo bolt to be used).
I'll have a look for you tomorrow, I have one of the BMC spill rails in the workshop.
Richard
Curiosity got the better of me, the hole in the banjo for the fuel filter is 5/16" or 8mm
Richard
MORE: This might do: http://www.ebay.co.uk/itm/Venhill-M8-8mm-chrome-banjo-to-1-8-bsp-connection-Quick-build-brake-line-system-/181611043959?pt=UK_Motorcycle_Parts_13&hash=item2a48dc9c77
Edited by RLWP
As the Calcutt Kit contains 8mm washers that suggests that all the banjos are 8mm so that ebay item might be the answer - so I'd just get the kit (with a new rail) and that banjo from Ebay.
I'm going to be on the boat in a couple of weeks so I'll probably strip things down or measure them up
Thanks for digging round for me Richard.
  • 7 years later...
Yep, just had exactly the same spill rail failure right at the last injector. ASAP do make a kit for the 1.8 and an adapter kit for the 1.9. Calcutt seem to do the same, BUT, they don't seem to answer e mails too often, so I've lost interest in that company.
This company seem to do a kit for both the BMC 1.5 and 1.8:
The Boatyard (ukboatyard.uk)
BMC 1.5 / 1.8 Diesel Engine Spill Rail
  • Product Code: MBMCSPILLRAIL1.51.8
  • Availability: In Stock
  • £48.60
  • Ex Tax: £40.50
  • Price in Loyalty Points: 4860
Anyone know if they are any good, or what exactly the kit includes ??
Edited by TNLI
Phil
Yep, it looks like that is what I'm going to have to do. I've already got some real nice braided stainless hose and genuine Jubilee clips, so it's just a matter of figuring out who to buy the other bits from. My very old BMC that was fully sized and dumped after spending around a year on the bottom, had an almost new looking spill rail with hoses to link the 4 injectors to the secondary dreaded CAV 296.
A few links for those BMC owners that need to rebuild a spill off fuel rail for the 4 injectors.
End of rail Banjo:
Banjo Bolt Banjo Union Fuel Hose Tail Brake Line fittings Petrol Diesel Joiner | eBay
Next 3 injector top Banjos:
Double two way fuel diesal PLAIN TAIL BANJO EYE UNION LINE HOSE FITTINGS steel | eBay
You can probably reuse the final section of pipe and inline banjo for the CAV 296 filter, BUT if that part is kaput you are going to have an issue finding the parts, as although the bigger 10mm/6mm banjo is available I did not see the one way screw in valve listed.
Double two way fuel diesal PLAIN TAIL BANJO EYE UNION LINE HOSE FITTINGS steel | eBay (BUT you need to select 10mm and the fuel line ID size, which is normally 4mm.
CAV 296 screw in fitting:
Not found!
Total cost around 35 quid, but ASAP will charge you around 80 for a full Copper set, and Calcutta Boats 50 quid. Calcutta did reply to my enquiry and said the cost of the same parts I've ordered was 50 quid plus postage, but they were out of stock for some reason.
Edited by TNLI
End of rail Banjo:
Not found!
apart from the fact that some BMC 1.5 like ours have a double pipe banjo on the top of the CAV - with a threaded connector for the fuel return line.  We got a company somewhere on the south coast (I think) to rebujild it the whole spill rail and provide suitable lengths of flexi hose (with BS markings on them)..  Don't ask me who or the cost - it was several years ago.
