Gibbo Posted June 19, 2012 Report Share Posted June 19, 2012 Hello Gibbo Hello Mr S. You really are bored aren't you. Link to comment Share on other sites More sharing options...
Tony Brooks Posted June 19, 2012 Report Share Posted June 19, 2012 I doubt if they would squeeze all the excess grease out either,posts and lugs are not exactly precision engineered and matched to each other. Loose and wobbly posts were common once too,caused by people banging and levering the clamps about which would allow acid and fumes to quickly corrode the whole thing. Dagenite batteries who i think 'were or merged' with Exide used to be very good batteries,not seen an Exide battery for a while now though,perhaps they're not in buisiness anymore. Yes. certainly became part of Exide. We were Daganite service agents and a such I learnt to put new cells into faulty batteries and build new batteries into old cases. At one time their "replate" batteries came as a complete set of new parts so we had to burn the plates to the posts, then fit and pitch in the lids before finally burning the posts and interlinks. I dare not think what the H&S lot would say about melting lead and casting into burning strips and then the actual lead burning - all without any fume extraction. I doubt Exide are anything more than a label stuck on mass produced batteries nowadays and the same goes for the Lucas brand. Link to comment Share on other sites More sharing options...
Proper Job Posted June 19, 2012 Report Share Posted June 19, 2012 .................... And who remembers those dreadful closed push on lugs held down with a self tapping screw,BMC mainly i'm sure that it was just the self tapping screw passing the current most of the time. I remember them. They were terrible to get a good connection on. One trick we used was to 'drape' short lengths of solder wire over the terminals and then 'tap' the cup on to try to get a half good connection. Link to comment Share on other sites More sharing options...
bizzard Posted June 19, 2012 Report Share Posted June 19, 2012 I remember them. They were terrible to get a good connection on. One trick we used was to 'drape' short lengths of solder wire over the terminals and then 'tap' the cup on to try to get a half good connection. I usually ended up doing that with silver paper from a 10 Weights fag packet. And sometimes biffed the lug on the side against a block,although making them a bit oval it did tighten them.The strange thing was the cables were soldered into them really well. Link to comment Share on other sites More sharing options...
ditchcrawler Posted June 19, 2012 Report Share Posted June 19, 2012 Well my backs to the wall chaps,it looks like i'm outnumbered,however due to my past experiences of posts and lugs coated with grease,vaselene ect,i will not be doing it,although i except the correct stuff for the job and will try it. My experience is general,all types of vehicles. Agree with Tony about some of the continental cars battery terminals,''the collet squeezing type with the wing nuts on top for example. And who remembers those dreadful closed push on lugs held down with a self tapping screw,BMC mainly i'm sure that it was just the self tapping screw passing the current most of the time. You could even buy them with wings on so you didn't need any tools to take the flat battery off. Link to comment Share on other sites More sharing options...
bizzard Posted June 19, 2012 Report Share Posted June 19, 2012 You could even buy them with wings on so you didn't need any tools to take the flat battery off. Yes i've seen a few of those,they could be bought at car spares shops. Link to comment Share on other sites More sharing options...
jelunga Posted June 19, 2012 Report Share Posted June 19, 2012 (edited) I have also worked "out in the field" for years and in winter. The bad connection problems we had stemmed from people who did NOT dress the terminals before putting the clamp on so acid and stuff got between the clamp and post and made a horrible, black, hard insulation stuff which I suspect was some form of lead sulphate. Now, perhaps you did a lot of work on French cars and their battery connection devices were not good in my opinion and would cause problems whatever you did. I know my site has been quoted but I join Gibbo in saying apply Vaseline or terminal dressing BEFORE you put the clamp on. I would never use grease because I have no idea how the additive in it would react although the MOD PX8 (I think) terminal dressing looked a lot like grease. I remember it as PX7, but that was over 20 yrs ago! PS. Just googled px7. It seems to be petroleum jelly ie Vaseline!! Edited June 19, 2012 by jelunga Link to comment Share on other sites More sharing options...
Guest Posted June 19, 2012 Report Share Posted June 19, 2012 I realise I will likely burn in hell, but I gave up using vaseline on me boat batteries last century. I use copper grease (including between clamps.) Forgive me Father for I have sinned etc. Link to comment Share on other sites More sharing options...
ditchcrawler Posted June 19, 2012 Report Share Posted June 19, 2012 I realise I will likely burn in hell, but I gave up using vaseline on me boat batteries last century. I use copper grease (including between clamps.) Forgive me Father for I have sinned etc. I am not sure that is the best product for the job. We used that on nuts and bolts, but still used no-corde on the batteries. It may be fine, I never read the tin. Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2012 Report Share Posted June 20, 2012 (edited) I am not sure that is the best product for the job. We used that on nuts and bolts, but still used no-corde on the batteries. It may be fine, I never read the tin. I too am unsure if it is "approved" for the job so to speak. It is approved by me though Edited to add these are battery friendly according to the blurb: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_189950_langId_-1_categoryId_165705 http://www.google.co.uk/products/catalog?hl=en&cp=11&gs_id=16&xhr=t&q=copper+grease&safe=off&biw=1280&bih=685&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&um=1&ie=UTF-8&tbm=shop&cid=15759530732754572751&sa=X&ei=VGvhT7jICMKm0AXksbzGAw&sqi=2&ved=0CJoBEPMCMAI My theory is it is useful for many other jobs on the car and boat etc, hence one less tin of stuff to keep on the shelf. Edited June 20, 2012 by Guest Link to comment Share on other sites More sharing options...
