chris w Posted December 19, 2007 Report Share Posted December 19, 2007 I bet Schrodinger's cat could reverse a narrowboat... as long as no-one looks ! You're wasted on here Link to comment Share on other sites More sharing options...
Nic Posted December 19, 2007 Report Share Posted December 19, 2007 Just be aware of your surroundings. I like reversing, but if you're in an open marina or stretch of canal with a cross wind, its best not to try. I think its more that most people don't realise you can't steer in reverse, you just need to briefly put it in forward gear to push water over the tiller every so often to correct your boats course, preferably before it goes off course. You see many people waggling the tiller arm frantically, just before they dispatch crew to fend off the bank/moored boat/etc. It could be that my boat pulls to one side in forward gear anyway so I don't notice much change in reverse . As to ensuring no one is around, doesn't help posting videos reversing does it! divx or youtube Link to comment Share on other sites More sharing options...
howardang Posted December 19, 2007 Report Share Posted December 19, 2007 Back in the days of engineless wherries on the Norfolk Broads, this was a common technique for dealing with the bridges at Yarmouth - after dropping their masts, they'd drop the mudweight and by lengthening the rope or shortening it, could control their speed as the river current took them through. Steering was just about keeping the boat in the middle of the span. I think that Thames barges did a similar trick. The barges on the river Hull used the same using a mudweight suspended from the bow. I have heard it described as 'drudging' in some quarters. Howard Anguish Link to comment Share on other sites More sharing options...
blackrose Posted December 19, 2007 Report Share Posted December 19, 2007 The barges on the river Hull used the same using a mudweight suspended from the bow. I have heard it described as 'drudging' in some quarters.Howard Anguish So what happened when the mudweight caught on some immovable object on the bottom? Stopped boat, snapped rope, bow pulled under? Link to comment Share on other sites More sharing options...
Yoda Posted December 19, 2007 Report Share Posted December 19, 2007 The barges on the river Hull used the same using a mudweight suspended from the bow. I have heard it described as 'drudging' in some quarters.Howard Anguish Are you sure? Going upstream its an anchor and going downstream could cause all sorts of navigational problems. Link to comment Share on other sites More sharing options...
pquinn Posted December 19, 2007 Report Share Posted December 19, 2007 i realise there is no steering in reverse but i allways wonder if it matters at all, what position the rudder is in. Link to comment Share on other sites More sharing options...
Timleech Posted December 19, 2007 Report Share Posted December 19, 2007 The barges on the river Hull used the same using a mudweight suspended from the bow. I have heard it described as 'drudging' in some quarters.Howard Anguish Probably a widely used technique, it was certainly used on the Mersey. Tim Link to comment Share on other sites More sharing options...
carlt Posted December 19, 2007 Report Share Posted December 19, 2007 i realise there is no steering in reverse but i allways wonder if it matters at all, what position the rudder is in. There is no steering when the prop is spinning in reverse but, when the boat is going backwards and the gearbox is in forwards, there is loads of manouevrebility. The trick is to balance your reversing with your steering and you can steer, going backwards, as smoothly as going forwards. Link to comment Share on other sites More sharing options...
Keeping Up Posted December 19, 2007 Report Share Posted December 19, 2007 i realise there is no steering in reverse but i allways wonder if it matters at all, what position the rudder is in. Not correct; there is some steering if you're going reasonably quickly Link to comment Share on other sites More sharing options...
howardang Posted December 19, 2007 Report Share Posted December 19, 2007 Are you sure? Going upstream its an anchor and going downstream could cause all sorts of navigational problems. Very sure. The barges used to go up the river stern first with a mudweight suspended from the windlass forward with a man tending the line, keeping it just bouncing along the bottom. The drag slowed the barge down sufficiently so that there was a flow over the rudder enabling the barge to be steered round bends by sheering it across the current. This is a very well known procedure, not just in barge work. It can be used with a mudweight or with an anchor as long as it isn't allowed to bed in. The secret is not letting out too much cable. Howard Anguish Link to comment Share on other sites More sharing options...
David Schweizer Posted December 19, 2007 Report Share Posted December 19, 2007 Not correct; there is some steering if you're going reasonably quicklyI was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat bNot correct; there is some steering if you're going reasonably quicklyI was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat bNot correct; there is some steering if you're going reasonably quicklyI was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat bNot correct; there is some steering if you're going reasonably quicklyI was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat b Link to comment Share on other sites More sharing options...
carlt Posted December 19, 2007 Report Share Posted December 19, 2007 (edited) I was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat b I was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat b I was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat b I was going to make that point as well. My boat can steers quite well in reverse, but is better at speed. I once got a ropund of applause from moored boaters at bremn=nyford when i reversed my boat b I'll have a pint of what David's drinking Edited December 19, 2007 by carlt 1 Link to comment Share on other sites More sharing options...
Keeping Up Posted December 19, 2007 Report Share Posted December 19, 2007 I'll have a pint of what David's drinking Make that 4 pints! 1 Link to comment Share on other sites More sharing options...
David Schweizer Posted December 19, 2007 Report Share Posted December 19, 2007 I'll have a pint of what David's drinking Well usually drink 6X so it was a bit short!! 1 Link to comment Share on other sites More sharing options...
ChrisG Posted December 24, 2007 Report Share Posted December 24, 2007 I'd like a ropund of applause and a glass of red wine, please. Link to comment Share on other sites More sharing options...
