Speedwheel & Gearshift
Liam
Will they just be tapping it and wondering why nothing happens?
I wonder whether I could get used to that... Anyone got a Large Northwich I could try?
GU motor boats were commonly anticlock to increase speed. I often steered a friend's (also ex-GU) boat which was the opposite, though the gearchange was anticlock for ahead, so that switching from one GU boat to this one meant that both controls were reversed :lol:
Tim
Edited by Timleech
If Liam doesn't want it you could try selling it to me :lol:
SteveE
This is the one we have ( Tony's photo)
C/w swivels and ballsockets
£75.00 inc carriage
Chris
1st come 1st served I need to have a clearout
As I recall that is the way I have experienced speedwheel and gearshift. Either way I quite like it for boats with classic style low rpm engines and it does give quite good precise control over engine rpm. The only thing I have noticed both for myself and others using it is that when manoeuvring it is a slower process to reduce revs change gear and increase revs again. I guess though it just means you need to plan ahead and anticipate more. Of course it could just be a matter of practice.
You could fit a speedwheel to a modern engine set-up but it doesn't seem as right on that kind of motor. I have a modern diesel on mine and I think I would rather stick to a Morse control in that situation.
As a different take on this my sister and brother in law's boat has gear wheel and pull-push lever for speed. Weird!
Nick
The ones I've driven, a modern tug, and a Large Northwich, and a couple of others, are both clockwise to speed up, anti clockwise to slow down :lol:
Mine's anticlockwise to speed up.
I soon got used to it as it's like using a tap.
I've not read all posts so excuse me if someone else has already mentioned this:
-I think you could arrange the throttle so it's just a wire wrapped around the speedwheel control rod rather than have a threaded crank jobbie.
It might look a bit crude but I think this was actually used on some old boats.
You would have the advantage of being able to reverse your throttle opening by winding the wire in either direction.
Regds A
I have only seen one left hander and there the chap used a G clamp to pull a cable, so undoing the G clamp opened the jaws and pulled the cable opening the governor.
