Cmseasman1 Posted January 28, 2023 Report Share Posted January 28, 2023 Hi, we are looking to move to Burton Waters in March. We are not new to boating we have been on Windermere for many years and are looking now to broaden our horizons, new challenges. We have a Sealine F33. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 11 minutes ago, Cmseasman1 said: Hi, we are looking to move to Burton Waters in March. We are not new to boating we have been on Windermere for many years and are looking now to broaden our horizons, new challenges. We have a Sealine F33. Have you checked the available draft and airdraft on the Foss dyke ? I think you'll have problems and be confined to a couple of miles either side of the marina. A forumite here has a S23 that was OK but you are a bit bgger all round. The "Glory Hole" on the entry into Lincoln is only 2.8 metres, and going towards the Trent we got stuck at Saxilby with a water depth of 3 feet. The Glory hole : 1 Link to comment Share on other sites More sharing options...
Guest Posted January 28, 2023 Report Share Posted January 28, 2023 26 minutes ago, Cmseasman1 said: Hi, we are looking to move to Burton Waters in March. We are not new to boating we have been on Windermere for many years and are looking now to broaden our horizons, new challenges. We have a Sealine F33. Welcome to the forum. Thats a pretty sizeable boat. Somwhere on the Trent would be better surely? Or the Ouse? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 Assuming these dimensions for a F33 are correct, you are going to struggle. You will most certainly not be able to transit Lincoln and go down the River Witham, You'll struggle with grounding when heading towards the Trent. What is your lowest point ? (Is it the outdrives or are you on shafts ?) Dimensions LOA: 34 ft 6 in LWL: 26 ft 5 in Beam: 11 ft Max Bridge Clearance: 13 ft 3 in Max Draft: 3 ft 1 in Dry Weight: 5500 kg Fuel Tanks Cap.: 644 L Fresh Water Tanks Cap.: 250 L Holding Tank Cap.: 141 L Number of Heads: 1 Link to comment Share on other sites More sharing options...
Cmseasman1 Posted January 28, 2023 Author Report Share Posted January 28, 2023 We were talking to someone yesterday who has a Sealine F42 and has been a number of places. There were a number of large boats on the marina too. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 5 minutes ago, Cmseasman1 said: We were talking to someone yesterday who has a Sealine F42 and has been a number of places. There were a number of large boats on the marina too. Ok - good luck with the trip. Link to comment Share on other sites More sharing options...
Naughty Cal Posted January 28, 2023 Report Share Posted January 28, 2023 1 hour ago, Cmseasman1 said: We were talking to someone yesterday who has a Sealine F42 and has been a number of places. There were a number of large boats on the marina too. The bigger boats in Burton Waters never move. You will be fine with an F33. You won't get through Lincoln though. 2 Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 41 minutes ago, Naughty Cal said: The bigger boats in Burton Waters never move. You will be fine with an F33. You won't get through Lincoln though. I hoped you'd be along - may be worth explaining why you know what you know ? DEFINITELY will not get under the Glory Hole, and having 'hit the hard stuff' at Saxilby (unless its been dredged in the last couple of years) he'll struggle with a draft of 3' 1" (probably a damaged prop, depends on the keel) Link to comment Share on other sites More sharing options...
Cmseasman1 Posted January 28, 2023 Author Report Share Posted January 28, 2023 1 hour ago, Naughty Cal said: The bigger boats in Burton Waters never move. You will be fine with an F33. You won't get through Lincoln though. Naughty Cal, thank you do you have any more advice. I know we can't get to Lincoln that isn't a problem at all. Link to comment Share on other sites More sharing options...
PD1964 Posted January 28, 2023 Report Share Posted January 28, 2023 @MartynG hopefully can give you some local knowledge for the area. Good luck Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 20 minutes ago, PD1964 said: @MartynG hopefully can give you some local knowledge for the area. Good luck Well I had 10 years experience of the local area in both NBs and cruisers. But maybe its not what he wants to hear. Link to comment Share on other sites More sharing options...
Momac Posted January 28, 2023 Report Share Posted January 28, 2023 (edited) As said and pictured you cant get past Lincoln. Going towards Torksey the pinch point is Saxilby The radar arch will need to be lowered. The railway bridge is very low .I had to lie on the flybridge seat Although a F34 (not quite the same) the following video illustrates the headroom I would lower the Arch for Torksey lock also. Downstream from Torksey on the Trent there are no headroom issues. Upstream from Torksey I lower the arch at Nether lock and through Newark Edited January 28, 2023 by MartynG Link to comment Share on other sites More sharing options...
matty40s Posted January 28, 2023 Report Share Posted January 28, 2023 You also need to be aware of where the deer crossings are between Saxilby and Torksey, some of the warning signs are not there any more. Link to comment Share on other sites More sharing options...
Cmseasman1 Posted January 28, 2023 Author Report Share Posted January 28, 2023 3 minutes ago, MartynG said: As said and pictured you cant get past Lincoln. Going towards Torksey the pinch point is Saxilby The radar arch will need to be lowered. The railway bridge is very low .I had to lie on the flybridge . Although a F34 (not quite the same) the following video illustrates the headroom I would lower the Arch for Torksey lock also. Downstream from Torksey on the Trent there are no headroom issues. Upstream from Torksey I lower the arch at Nether lock and through Newark Thank you. Yes this is what we were told yesterday. It will be different that's for sure. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 40 minutes ago, MartynG said: Upstream from Torksey I lower the arch at Nether lock and through Newark Yes - forgot that - the narrow low bridge just after the Town Lock heading upstream - forgot to lower the radar arch and wiped off the radome and the GPS aerial and bent the 'arch'. Not one of my best days. Link to comment Share on other sites More sharing options...
Momac Posted January 28, 2023 Report Share Posted January 28, 2023 4 hours ago, M_JG said: Somwhere on the Trent would be better surely? I agree but perhaps I am biased . 4 hours ago, Alan de Enfield said: What is your lowest point ? (Is it the outdrives or are you on shafts ?) The F33 is on outdrives which can be trimmed up if necessary But i am not keen on the Fossditch in my F33 and have not been down there for the last few years. Naughty Cal is no longer dredging it clear of weed , fishing tackle atc. Link to comment Share on other sites More sharing options...
Momac Posted January 28, 2023 Report Share Posted January 28, 2023 9 minutes ago, Alan de Enfield said: Yes - forgot that - the narrow low bridge just after the Town Lock heading upstream Mill Bridge shown here with the flood gates closed 5 hours ago, Cmseasman1 said: We have a Sealine F33. I may have failed to mention I have a F33 also Link to comment Share on other sites More sharing options...
Cmseasman1 Posted January 28, 2023 Author Report Share Posted January 28, 2023 3 minutes ago, MartynG said: Mill Bridge shown here with the flood gates closed I may have failed to mention I have a F33 also Are you on Burton or a different marina. So I am taken it you do get out and about. Link to comment Share on other sites More sharing options...
Momac Posted January 28, 2023 Report Share Posted January 28, 2023 2 minutes ago, Cmseasman1 said: Are you on Burton or a different marina. So I am taken it you do get out and about. Farndon Marina. Link to comment Share on other sites More sharing options...
Cmseasman1 Posted January 28, 2023 Author Report Share Posted January 28, 2023 2 minutes ago, MartynG said: Farndon Marina. Ah, we had also looked here too. Link to comment Share on other sites More sharing options...
Momac Posted January 28, 2023 Report Share Posted January 28, 2023 There is a vacant mooring space on G pontoon at Fardon previously occupied by a F33. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 1 minute ago, MartynG said: There is a vacant mooring space on G pontoon at Fardon previously occupied by a F33. Either Farndon or Kings marina would be a far, far better option than Burton Waters (still height restrictions but a much easier life) and direct access down the Trent to the Humber and out to Sea - down to Wells Next The Sea (3 hours at 20 Knots Hull marina to Wells) onwards to Yarmouth an Lowestoft - next stop the Thames and London. Not as cheap these days as it was when we were paying 27p - 30p per litre, but a nice trip. Link to comment Share on other sites More sharing options...
Cmseasman1 Posted January 28, 2023 Author Report Share Posted January 28, 2023 What would be the difference there to where we are thinking of. Sorry if this sounds a daft question. Link to comment Share on other sites More sharing options...
Guest Posted January 28, 2023 Report Share Posted January 28, 2023 1 minute ago, Cmseasman1 said: What would be the difference there to where we are thinking of. Sorry if this sounds a daft question. Immediate access to a waterway better suited to your boat. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 28, 2023 Report Share Posted January 28, 2023 (edited) 28 minutes ago, MartynG said: But i am not keen on the Fossditch in my F33 and have not been down there for the last few years. Naughty Cal is no longer dredging it clear of weed , fishing tackle atc. Thats probably the problem I had - entered the Foss-Ditch, got as far as Saxilby and got seriously stuck, took several hours of 'utching' forwards and backwards before we had turned around, tied up and phoned for a Pizza to be delivered. 4 minutes ago, Cmseasman1 said: What would be the difference there to where we are thinking of. Sorry if this sounds a daft question. If you don't know the answer no question is daft, but having asked the question it is beneficial to take the advice of those who have spent many years boating on those waters. Access directly onto the Trent and 'deep water' (well 6 foot in places - but you'll soon find where it has not been dredged) Edited January 28, 2023 by Alan de Enfield Link to comment Share on other sites More sharing options...
