When i run my genny to boil a kettle or run my toaster, it takes a long time and my microwave although the turntable goes round, doesn't heat anything. But if i run the microwave on the batteries via inverter no problem?
Odd things happen with generators.
I have a friend who has a 5kva generator, it would not run his Bosch  hand circular saw at 1200W.  It worked on the mains OK.
Bosch sent him a replacement saw, that one works! Same model!
Any reason for this strange behaviour?
Edited by Tracy D'arth
1 hour ago, Sir Nibble said:
Sounds to me like the Genny output is low (thank you captain obvious). Don't have it set for 110V by any chance?
No definitely 230v. I know washing machinesvcan be awkward, but...a toaster?!
Modern toasters have IC’s in them to control them..gone are the days of a simple bi metallic strip. I’m guessing the voltage and/or waveform of the genny is pretty dire…does it have a proper AVR or just a capacitor or two? You could try putting a decent load on the genny say an immersion and try the toaster then. That might settle it down
Unless you're a gadget freak both a kettle and toaster should be a dumb, unreactive purely resistive load. First component in a microwave is a powerful transformer with a heavy inrush current. I think this is a power problem rather than waveform. What WILL the Genny run?
I agree they should be….but they aren’t! Even my mothers cheap Russel Hobbs toaster has a control circuit…I guess they are now cheaper than a rheostat and a solenoid is cheaper than a bimetallic strip. It’s a mad world.
edited to add…
some microwaves now have inverters rather than transformers. They may be more fussy about the quality of power…I guess they could also be more tolerant too but I bet it’s all down to cost again
Edited by frangar
8 hours ago, Keith M said:
When were the capacitors last checked?
In the genny?   5 years ago.
Halogen hob no problem.
I have noticed that the genny seldom goes above 25% output. If I switch another appliance on, rather than go up to 50%, the other appliances “slow down”.
20 minutes ago, jenevers said:
Mastervolt Whisper 6000
Not your bog-standard type. What will the generator run, without problems?
Edited by Higgs
The capacitors are classed as a service item normally being replaced every 2 to 3 years they are of the voltage control system..
No idea but it sounds like it's worth replacing them to see what happens
