Yes it will. You will need to replace with a metal one, which should be readily available for not to much money.
Not necessarily, it's marked as ISO10088 compliant; but probably only if the metal heat shield is fitted (the bowl shaped piece of metal in the OPs picture).
Edited by Eeyore
On 01/05/2021 at 08:50, BEngo said:
Have you tried looking at inline filters website?  They have a very good equivalents finder.
If it is not there as an equivalent, measure the main dimensions including the thread size/pitch and you can look up an equivalent that way.
You could also try online filters. They have a rep for being helpful.
Vetus are rather good at buying bespoke auxiliary items, and charging the earth for them though.  If you cannot find an equivalent it might be cheaper to swap your filter unit out with a Delphi 296 agglomeration filter.  Loads on line- just ensure you get one with a metal bowl and drain plug to keep BSS happy.
N
Tried them, no replacement, have to buy from Vetus
7 hours ago, Mac of Cygnet said:
Looking at the pics, wouldn't that plastic drain plug (?) on the bottom fail a BSS?
You can get ally ones if you are referring to the CAV lump
Edited by ditchcrawler
A standard bolt and washer works, its not a special thread. Mine is 5/16" UNC, suppose new ones will be 8mm Metric.
