Chewbacka
Days Won
Everything posted by Chewbacka
Water tank outlet size and supplier pipe diameter
Chewbacka replied to TandC's topic in Boat Building & Maintenance
If I was running a pump inlet ‘suction’ pipe for 9m I would use 22mm plastic pipe as I think 15mm would reduce the flow somewhat. As to the tank outlet I doubt if 3/4 bsp would be any better than 1/2”, so would go with 1/2”bsp -
email from CRT, worth a read if coming down the river. Update on 20/03/2023: Opening Hours for Gloucester & Sharpness Canal & River Severn Further to the recent consultation regarding opening hours, we are now pleased to confirm the following for the 2023 summer season: Gloucester & Sharpness Canal Wednesday to Monday open 8am – 6pm Tuesday – Closed (except to pre-arranged commercial traffic) this closure includes Gloucester Lock. River Severn Navigation River Locks open 7 days per week 8am – 6pm Please note that Bevere & Holt Locks will be available at the set times below: Bevere: Open 8am – 9am, 11am – 12pm, 2pm – 3pm, 5pm – 6pm Holt Open: 9:30am – 10:30am, 12:30pm – 1:30pm, 3:30pm – 4:30pm
Knowing when to pump-out before it to late?
Chewbacka replied to David Floyd's topic in Boat Equipment
Just simple stainless switches from eBay -
I think the macerator chops everything up to a fine enough state to be no problem (fitted about 10 years ago without problems). Not sure if using posh toilet paper in a dump through would work. -
This may help https://www.boatsafetyscheme.org/requirements-examinations-certification/hire-boats-requirements-2017/additional-hire-boat-requirements/
I fitted a couple of float switches (4” & 1”) which light up an orange and a red led as the tank fills. Fitted straight after a pump out, wasn’t my most enjoyable job!!! -
Basically correct, but if the marina wishes to connect to the canal then crt require that the marina must agree to only allow boats with a crt licence to stay. So if an unlicensed boat is in the marina crt can not take action against the boat/boater but the marina would be in breach of it’s agreement with crt, so crt can take action against the marina, for example by closing the marina access to the canal. To avoid this situation the marina requires in it’s agreement with boaters that boats are licensed, if a boat is unlicensed then it’s the responsibility of the marina to enforce it’s agreement with the boater.
Thinking of DIY Spray Foam Insulation
Chewbacka replied to Teddy Bear's topic in Boat Building & Maintenance
I had spray foam done 13 years ago and it’s great. If paying someone to do it make sure you tell them when they quote you want it thick, approx flush with the wooden bearers for the lining. That way it’s warm in winter and much cooler in summer. The downside is I agreed to trim it back where it was too thick. Spent a few days with a bread knife. -
These carbon monoxide detectors (Kidde 7DC0)
Chewbacka replied to nairb123's topic in General Boating
Looking at their web site it seems that values less than 11ppm display as zero, so don’t expect a tiny number -
I think it states “fuel used by an engine to move or (engine used to) provide electric power", the intention being to allow older Diesel engines that emit smoke to generate power whilst moored.
From the uk gov statuary guidance Moored vessels You must consult with the public before you can apply the smoke control area rules to vessels that are moored or stationary at a mooring place, including canal boats, to stop them emitting a substantial amount of smoke. Smoke emissions are allowed from fuel used by an engine to move or provide electric power to the vessel. You can exempt specified vessels or classes of vessel from your smoke control area rules. The providing electric power specifically states ‘engine’ so would exclude a stove with a thermoelectric generator. But it does appear that smoke is only smoke when excessive, and that is not defined……
Have a read of these https://www.gov.uk/government/publications/smoke-control-area-enforcement-local-authorities-in-england/smoke-control-area-enforcement-by-local-authorities-in-england https://www.gov.uk/smoke-control-area-rules Many reasonable questions you can ask the council, starting with “how much smoke is reasonable” as the legislation clearly allows some smoke from correctly burned approved smokeless fuel. What evidence do they have that you were emitting excessive smoke. Etc
I think the nearest branch with a teller rather than a room with machines is about 20 miles away, so cashing-up must be becoming difficult for small businesses. The last bank in our town has just closed, so it’s not like I have a choice.
Maybe they had and this is part of their money raising strategy………. Not sure if it’s like the licence fee where you get a discount paying on-line rather than by phone, but if it is should save you something next year
I think Virgin is in the process of moving onto O2 so you may see a change.
But if you do you will know when it’s good and dry🤣
