colin loach Posted September 25, 2008 Report Share Posted September 25, 2008 Hi all. I want to take my cruiser stern boat down the themes but there are two air vents on the back each side.I Don't want any water to go into the engine compartment so could I block the vents in for 2 hours Link to comment Share on other sites More sharing options...
John Orentas Posted September 25, 2008 Report Share Posted September 25, 2008 Hi Colin. The vents are to facilitate engine cooling and ventilation, a run down the Thames is just the occasion when they are most required.. Although you may find the tidal Thames a bit lumpy it will not be such that water will get near the cooling vents. Link to comment Share on other sites More sharing options...
AlanH Posted September 25, 2008 Report Share Posted September 25, 2008 Hi all. I want to take my cruiser stern boat down the themes but there are two air vents on the back each side.I Don't want any water to go into the engine compartment so could I block the vents in for 2 hours They are to allow the engine to take in fresh air. If you block them you could well affect the performance. Woiuld be OK if you lifted a deck board to allow air in for the duration. Link to comment Share on other sites More sharing options...
Bones Posted September 25, 2008 Report Share Posted September 25, 2008 you are talking about the tidal thames aren't you? Would it be possible to put a hose on the end and secure it above the water line at a distance that suits, then water wont come in Link to comment Share on other sites More sharing options...
colin loach Posted September 25, 2008 Author Report Share Posted September 25, 2008 the vents are to big for a hose but lifting the deck board is a option. Has anyone exsperienced the themes and had water coming in. Link to comment Share on other sites More sharing options...
alan_fincher Posted September 25, 2008 Report Share Posted September 25, 2008 They are to allow the engine to take in fresh air. If you block them you could well affect the performance. Woiuld be OK if you lifted a deck board to allow air in for the duration. Lets be careful here.... That's probably fine if it's a water cooled engine, and these are just permitting air into the engine compartment. But if it's an air cooled engine, (something like the SR or ST series, for example), then one of these will be connected to the engine by steel or metal trunking, and is how the engine gets rid of it's hot air, rather than just recirculating it. Block one of those, and the engine will rapidly overheat. (Sorry if that's a bit obvious, but just in case!....) Has anyone exsperienced the themes and had water coming in. Which bit are you planning to do? Brentford to Teddington (or Vice Versa), or are you goin'g on the bit through London to Limehouse? Link to comment Share on other sites More sharing options...
blackrose Posted September 25, 2008 Report Share Posted September 25, 2008 (edited) How high above the waterline are the vents? Most including mine are about 18" above the waterline, but in my opinion is not a great design feature. For watercooled engines the vents are there primarily for the engine's air intake and perhaps to facilitate alternator cooling, so there's actually no reason for them to be anywhere near the waterline and some builders are now putting the vents higher up on the side of the control pedestal. (Not sure if that's the correct term - the upright steel box on many modern boats with the morse contol and gauges on top.) Most of the waves on the tidal Thames tend to hit the bow or come across the beam when you can't turn into them because a bridge is approaching for example, but if you're worried about your vents being too low for that trip perhaps you could use some sort of ducting and waterproof tape to raise the intake. Edit: As Alan says above - if you're just doing Teddington to Brentford don't even worry about it. Edited September 25, 2008 by blackrose Link to comment Share on other sites More sharing options...
colin loach Posted September 25, 2008 Author Report Share Posted September 25, 2008 (edited) its a Liverpool boat with a Isuzu 45 engine water cooled the vents are about 18in off the water line. they are 10in x 6in. I want to go down to limehouse or a bit further, may be I could design some sort of water tight vent . any idea's Edited September 25, 2008 by colin loach Link to comment Share on other sites More sharing options...
John Orentas Posted September 25, 2008 Report Share Posted September 25, 2008 Colin. Hundreds of Liverpool boats navigate the tidal Thames every year, never heard of one having problems, I think you might be trying to cure a problem that does not exist. Link to comment Share on other sites More sharing options...
1066 Posted September 25, 2008 Report Share Posted September 25, 2008 If your water tanks are in the bow,, you could make sure that they are full, and try to stow as much gear up front as possible, in order to raise the stern as far as you can. Other than that, I dunno. Link to comment Share on other sites More sharing options...
blackrose Posted September 25, 2008 Report Share Posted September 25, 2008 (edited) its a Liverpool boat with a Isuzu 45 engine water cooled the vents are about 18in off the water line. they are 10in x 6in. I want to go down to limehouse or a bit further, may be I could design some sort of water tight vent . any idea's Mine's a LB too and I had no problems going down to Limehouse - if one or two waves do splash against the vents only a few cupfuls of water would get in so it's not going sink the boat. Don't block the vents and don't leave the deckboards off! Keep your bow doors shut and you'll be fine. Edited September 25, 2008 by blackrose Link to comment Share on other sites More sharing options...
colin loach Posted September 25, 2008 Author Report Share Posted September 25, 2008 Mine's a LB too and I had no problems going down to Limehouse - if one or two waves do splash against the vents only a few cupfuls of water would get in so it's not going sink the boat. Don't block the vents and don't leave the deckboards off! Keep your bow doors shut and you'll be fine. thats just what i wanted to hear, thanks very much i will let you know how i get on. Colin Link to comment Share on other sites More sharing options...
stuart Posted September 25, 2008 Report Share Posted September 25, 2008 I'd just make sure that theres nothing blocking the vents (battery boxes etc.) and also make sure your bilge pump is working properly (perhaps fit another one?) - any water that does get in will be pumped back out again. Link to comment Share on other sites More sharing options...
colin loach Posted September 25, 2008 Author Report Share Posted September 25, 2008 I'd just make sure that theres nothing blocking the vents (battery boxes etc.) and also make sure your bilge pump is working properly (perhaps fit another one?) - any water that does get in will be pumped back out again. good i dear thanks Link to comment Share on other sites More sharing options...
blackrose Posted September 25, 2008 Report Share Posted September 25, 2008 (edited) I've done that trip a couple of times - once without any accompanying boats. In retrospect that probably wasn't such a great idea. The last thing you want to do is have to deploy your anchor in the event of engine trouble or a fouled prop - you don't know if/when it's going to stop you or exactly what will happen once you drop it. There are so many bridges on that stretch you could easily smash into one. In future I think I'd always go with another boat. If one of you has a problem, they can always throw a rope to the other for a tow. If the lead boat has VHF then the other doesn't have to, but don't forget to exchange mobile numbers before you set out. Edited September 25, 2008 by blackrose Link to comment Share on other sites More sharing options...
colin loach Posted September 25, 2008 Author Report Share Posted September 25, 2008 I've done that trip a couple of times - once without any accompanying boats. In retrospect that probably wasn't such a great idea. The last thing you want to do is have to deploy your anchor in the event of engine trouble or a fouled prop - you don't know if/when it's going to stop you or exactly what will happen once you drop it. There are so many bridges on that stretch you could easily smash into one. In future I think I'd always go with another boat. If one of you has a problem, they can always throw a rope to the other for a tow. If the lead boat has VHF then the other doesn't have to, but don't forget to exchange mobile numbers before you set out. I will take your advice and go with someone else. I haven’t got vhf so hope a Mobil will do. I wanted to take in all the sites, so didn’t want to rush. I was told you can get in at limehouse even at low tide, do you think my 45 engine will be ok against the tide. Link to comment Share on other sites More sharing options...
Canalwatcher Posted September 25, 2008 Report Share Posted September 25, 2008 I will take your advice and go with someone else. I haven’t got vhf so hope a Mobil will do. I wanted to take in all the sites, so didn’t want to rush. I was told you can get in at limehouse even at low tide, do you think my 45 engine will be ok against the tide. Colin You might find the following link helpful for planning your trip http://www.pla.co.uk/pdfs/IWA_Thames_Tideway_Guide.pdf The bit about VHF in this guide is out of date see page 8 of http://www.pla.co.uk/pdfs/maritime/General...nters_copy1.pdf I think I have read that it will not be possible to always get in at Limehouse - you might have an an uncomfortable wait moored to a buoy - its easier to do the trip from Limehouse to Teddington Not that I'm much of an expert having only done Teddington to Brentford a couple of times I wouldn't think there are any worries about the vents though Mick Link to comment Share on other sites More sharing options...
sbillis Posted September 26, 2008 Report Share Posted September 26, 2008 Hi all. I want to take my cruiser stern boat down the themes but there are two air vents on the back each side.I Don't want any water to go into the engine compartment so could I block the vents in for 2 hours When we took Bulrush on the tidal Thames a few years ago the waves come over the vents, even onto the platform where I stand. I thought that the engine compartment would get flooded. When I checked it at Teddington it was bone dry. Somehow the water didnt go in. Simon nb Bulrush Link to comment Share on other sites More sharing options...
colin loach Posted September 26, 2008 Author Report Share Posted September 26, 2008 What boat have you got, and where are your vents. i better phone limehouse before i make the trip Link to comment Share on other sites More sharing options...
colin loach Posted September 26, 2008 Author Report Share Posted September 26, 2008 Colin You might find the following link helpful for planning your trip http://www.pla.co.uk/pdfs/IWA_Thames_Tideway_Guide.pdf The bit about VHF in this guide is out of date see page 8 of http://www.pla.co.uk/pdfs/maritime/General...nters_copy1.pdf I think I have read that it will not be possible to always get in at Limehouse - you might have an an uncomfortable wait moored to a buoy - its easier to do the trip from Limehouse to Teddington Not that I'm much of an expert having only done Teddington to Brentford a couple of times I wouldn't think there are any worries about the vents though Thanks for that link, it made interesting reading( scary) Mick Link to comment Share on other sites More sharing options...
WJM Posted September 26, 2008 Report Share Posted September 26, 2008 Liverpool boat here too. Done the Limehouse trip lots of times with no problems, even on really rough days. As already said, the waves tend to hit the front of the boat. Even if the occasional splash gets in, your bilge pump will chuck it back out. Link to comment Share on other sites More sharing options...
colin loach Posted September 26, 2008 Author Report Share Posted September 26, 2008 Liverpool boat here too. Done the Limehouse trip lots of times with no problems, even on really rough days. As already said, the waves tend to hit the front of the boat. Even if the occasional splash gets in, your bilge pump will chuck it back out. Thanks for that. Colin. Link to comment Share on other sites More sharing options...
