Cloudinspector Posted December 23, 2018 Report Posted December 23, 2018 Can anyone tell me what power starter battery would be suitable for a 2LW? my current one is on its last legs but has no info on it.
jonesthenuke Posted December 23, 2018 Report Posted December 23, 2018 I use 2 off 110Ah 620 CCA batteries in parallel on a 3LW. This seems more than adequate, especially considering the batteries are now about 10 years old! What size starter battery do you have now, that will be a guide.
BEngo Posted December 24, 2018 Report Posted December 24, 2018 Either a 643 or 644 size battery from a decent supplier will be fine. The difference between them is the post layout. Google will provide details. You want 600-700 CCA for those frosty mornings in the middle of nowhere. Ah capacity is not very important if the engine is in good order as it only uses a few Ah to get a start. N
Cloudinspector Posted December 26, 2018 Author Report Posted December 26, 2018 On 24/12/2018 at 07:37, BEngo said: Either a 643 or 644 size battery from a decent supplier will be fine. The difference between them is the post layout. Google will provide details. You want 600-700 CCA for those frosty mornings in the middle of nowhere. Ah capacity is not very important if the engine is in good order as it only uses a few Ah to get a start. N Perfect, thank you.
john.k Posted December 28, 2018 Report Posted December 28, 2018 I had a nasty surprise once with a setup where the motor always started instantly,even on the frostiest morning......or so it seemed..................took a trip to Tasmania.....about 5 below C........the motor just cranked and cranked.......clouds of white smoke,but would not start....Certainly gave me a surprise,thats for sure..............
Kingdom Isambard Brunel Posted December 28, 2018 Report Posted December 28, 2018 Time for a touch of heat down the inlet then. I suppose even diesel has a dew point below which it will not vapourise. My old Ford E04A Anglia, 997cc side valve with 6v battery demanded a burning oily rag on the inlet manifold in really cold weather or you just killed the battery.
john.k Posted December 28, 2018 Report Posted December 28, 2018 My point being failure to start came as a complete surprise.........and could have been in a sticky situation...........admittely on a canal,a sticky situation would probably only involve mud.
PeterG Posted December 28, 2018 Report Posted December 28, 2018 I have checked my records for you and I use a single 019XD battery which gives 100ah and 900CCA which I found at a decent price.
jonesthenuke Posted March 23, 2019 Report Posted March 23, 2019 This post is getting old but this may be of interest. Last week I was installing some more batteries on my boat and waned to check the starting current. Gardner 3LW turning over cold (not run for weeks) 8C ambient temp, engine probably colder. With the decompressor on 300A peak and around 280 spinning engine over. Decompressor off, current approx 380A but cycling with compression strokes. Measurements taken with the fuel rack shut off so that I could check the current without the engine starting. 1
