BrettT Posted June 6, 2017 Report Share Posted June 6, 2017 Hi All, 1st time post - so hopefully I don't upset anyone I am hoping for some advice and ideally a professional opinion regarding the routing of the gas pipe on our boat. It runs down the inboard exposed surface of the gunwale, so it's possible to drop something on it, against it or even step on it. Have a look at the attached pic and tell me if I'm being over cautious! thanks for taking a look! BretttT Link to comment Share on other sites More sharing options...
Dave_P Posted June 6, 2017 Report Share Posted June 6, 2017 Moved from Frequently Asked Questions so that people can reply Link to comment Share on other sites More sharing options...
nicknorman Posted June 6, 2017 Report Share Posted June 6, 2017 As far as I can tell it is compliant with the BSS, however I can see why you don't like it! Perhaps you could protect the pipe by bonding or screwing a strip of wood alongside the pipe? Link to comment Share on other sites More sharing options...
bizzard Posted June 6, 2017 Report Share Posted June 6, 2017 A load more clips would give it strength. You could cover it almost completely with them. Link to comment Share on other sites More sharing options...
zenataomm Posted June 6, 2017 Report Share Posted June 6, 2017 I understand your concern, to be honest I'd leave it exactly as it is. If it bothers you pop rivet a long thin shield of aluminium, angled down over the top of it. Link to comment Share on other sites More sharing options...
BrettT Posted June 6, 2017 Author Report Share Posted June 6, 2017 Thanks all for some useful ideas, I particularly like the idea of totally covering it in P clips, though I feel BSS man may not see the funny side! (Just going to check stock at my local screwfix ) Link to comment Share on other sites More sharing options...
bizzard Posted June 6, 2017 Report Share Posted June 6, 2017 6 minutes ago, BrettT said: Thanks all for some useful ideas, I particularly like the idea of totally covering it in P clips, though I feel BSS man may not see the funny side! (Just going to check stock at my local screwfix ) Leave about half inch to an each between each clip. That way the BSS bloke can still see the pipe. Box it in entirely with something even just a little bit bigger than the pipe and he would probably want it exposed to check it. Link to comment Share on other sites More sharing options...
BrettT Posted June 6, 2017 Author Report Share Posted June 6, 2017 Great advice Bizzard, thank you. Link to comment Share on other sites More sharing options...
WotEver Posted June 6, 2017 Report Share Posted June 6, 2017 43 minutes ago, bizzard said: Leave about half inch to an each between each clip. That way the BSS bloke can still see the pipe. Box it in entirely with something even just a little bit bigger than the pipe and he would probably want it exposed to check it. MtB posted at some point that 'over clipping' contravened some rule or other but I don't think it had anything to do with boats, and neither do I believe that the BSS would mind. Link to comment Share on other sites More sharing options...
bizzard Posted June 6, 2017 Report Share Posted June 6, 2017 18 minutes ago, WotEver said: MtB posted at some point that 'over clipping' contravened some rule or other but I don't think it had anything to do with boats, and neither do I believe that the BSS would mind. If the clips were butted up against each other I could understand it contravening a rule. The examiner might think the gas is flowing through the clips with no pipe inside. An alternative is to weld a steel ledge above it, but then the jolly old shins would end up in tatters. Link to comment Share on other sites More sharing options...
WotEver Posted June 6, 2017 Report Share Posted June 6, 2017 30 minutes ago, bizzard said: If the clips were butted up against each other I could understand it contravening a rule. I can't remember exactly what he said but I think it was something like no farther apart than 300mm and no closer than 150mm. As I said though, I don't believe it was applicable to boats. Link to comment Share on other sites More sharing options...
