mross Posted November 5, 2016 Report Share Posted November 5, 2016 Thanks - good to know. Link to comment Share on other sites More sharing options...
Dave_P Posted November 5, 2016 Report Share Posted November 5, 2016 £3 saving for me as buying at brazier at £11, can't use the fuel boats as only one passes my stomping ground, and that's not very often, and I'm at work.. Might try a bag. I've used Aldi, B&M and Homebargains 10kg bags. All were pretty decent and preferred to some popular narrowboater brands (*cough* Taybrite, *cough, cough* Supertherm) Popped to aldi last night and spotted smokeless coal, 10kg for £3.99 so picked a bag up to try. Wish i hadn't bothered, made the stove up before going to bed and woke up freezing this morning, it had gone out and left unburnt coal, guess it needs more air from the bottom to keep it in than the brazier, also the lumps are either very big or bits of broken ones. Shall use it up and try something else. Maybe Aldi have changed their brand Link to comment Share on other sites More sharing options...
Dave Payne Posted November 5, 2016 Author Report Share Posted November 5, 2016 To be fair, im still learning, i dont think i am putting enough in at night and in the morning its barely giving out heat. Sure ill figure it out and stop fretting that my boat is going to set on fire soon enough. Link to comment Share on other sites More sharing options...
mross Posted November 5, 2016 Report Share Posted November 5, 2016 Has anyone tried the olive wood/charcoal nuts from CPL (coals2U)? https://www.coals2u.co.uk/homefire-olive-briquettes Link to comment Share on other sites More sharing options...
bizzard Posted November 5, 2016 Report Share Posted November 5, 2016 The bottom air control position on stoves can vary a lot depending on the state of the stove. If the door and ash pan doors are not sealing properly or the grate riddler hole is a bit worn, then less bottom air. Flue pipe length and type of fuel make a difference too. Stoves in good nick usually need a bit more bottom air. Link to comment Share on other sites More sharing options...
Rob-M Posted November 5, 2016 Report Share Posted November 5, 2016 The bottom air control position on stoves can vary a lot depending on the state of the stove. If the door and ash pan doors are not sealing properly or the grate riddler hole is a bit worn, then less bottom air. Flue pipe length and type of fuel make a difference too. Stoves in good nick usually need a bit more bottom air. That's what I am finding, my old well worn stove could be closed right down and would keep burning slowly but my new stove will go out if I close the bottom air and needs to have at least a couple of turns open to keep the fire going. Link to comment Share on other sites More sharing options...
