David Mack Posted March 2, 2016 Report Share Posted March 2, 2016 It's a tight fit in the 'ole and quite strong, so you can give it a good push. Does this story involve an actress and a bishop? Link to comment Share on other sites More sharing options...
Guest Posted March 2, 2016 Report Share Posted March 2, 2016 I guess I'll try it through a syringe again and just push harder! Link to comment Share on other sites More sharing options...
Timx Posted March 3, 2016 Author Report Share Posted March 3, 2016 Try putting grease in. What have you got to lose. Could save a lot of cash. You will need grease after a new seal unit is fitted anyway for ongoing maintenance. Hi, I got up early and did as you said, there was a couple of small tubes of silicon grease on board, which I squirted in a little bit, as best I could, left it for five minutes whilst I retrieved the nut which I dropped into the wet bay, not sure how much goes in, but it didn't make any difference, so carried on with the plan and boat was slipped at noon. The slip was a hundred so took it as an opportunity to black it 6 months early as well, and then the slippage is included in the price, so have to pay engineer a couple of hours work plus the part, just hope it all works. Link to comment Share on other sites More sharing options...
Timx Posted March 7, 2016 Author Report Share Posted March 7, 2016 To finish the story, and for future reference to anybody, shaft seal; and delivery £72, labour £70, intertuff blacking repaint £433, vat %20 £115,, skint but happy and on way again, they seemed nice helpful people and had friendly service. Thanks for comments by everyone, will dry bilge out somehow only a couple of inches in parts where the boat leans, no drip from prop now , so apart from rain on a semi trad, all being well should stay dry. Link to comment Share on other sites More sharing options...
valrene9600 Posted March 7, 2016 Report Share Posted March 7, 2016 (edited) Are we using the same type of silicone grease? Mine is too thick to squeeze it out of a syringe - I tried it (and no, there was no needle! ). I know there are some thinner types of silicone grease in a tube with a nozzle, but for a water lubricated gland you want the thick stuff. This is the type I use. Plumba SILICONE grease. Edited wrong image on clipboard Plumba. Edited March 7, 2016 by valrene9600 Link to comment Share on other sites More sharing options...
Timx Posted March 7, 2016 Author Report Share Posted March 7, 2016 Engineer left me a little tube, same as I already had, and told me to give it a squirt once a year .!! Link to comment Share on other sites More sharing options...
ditchcrawler Posted March 7, 2016 Report Share Posted March 7, 2016 Engineer left me a little tube, same as I already had, and told me to give it a squirt once a year .!! Glad your sorted and it was the seal, not just the hose after doing all that. Link to comment Share on other sites More sharing options...
Timx Posted March 7, 2016 Author Report Share Posted March 7, 2016 Glad your sorted and it was the seal, not just the hose after doing all that. Thank you, I have to go on trust and he seemed cool, and it costs what it costs ,i knew I needed some money flow to get out of jail, just in case, so I am happy till next time ..!! Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2016 Report Share Posted March 8, 2016 (edited) Engineer left me a little tube, same as I already had, and told me to give it a squirt once a year .!! I have found the Vetus unit to need lube a little more often than that, but of course it depends on the boat usage. I generally used to put a bit in at engine oil change. Glad you got sorted. Edited March 8, 2016 by Guest Link to comment Share on other sites More sharing options...
