valrene9600
Everything posted by valrene9600
  1. 1 c/cruiser using stove, 1 chainsaw, = no stoppage. Oh! Add a broom, always nice to leave the site tidy.
  2. Nothing more boring than someone asking for help but not prepared to answer questions from members trying to help.
  3. Suggest you check the small on / off switch first as it is easy to look at.
  4. You say it won`t power up then the hoover works!!!! Have i missed something. When we had this type of problem it turned out to be the on/off switch. We now leave the switch on and use the inverter isolator switch for on/off. A bigger beafy switch.
  5. Just upgraded our LED's from 9 to 15's and the extra brightness is fantastic. Led has to be the lighting choice for boaters not on hook up.
  6. Annoying thing about insurance is as mentioned above not knowing how good a company is Until a claim goes in. So just how do you judge what to do to cut down on boating costs?. If you ease back on the throttle you can hear a lower engine feed that is burning less fuel and saving money etc. But saving on insurance is a suck it and see what happens situation. Pay for the cheaper one and hope to be pleasantly surprised or has anyone some ideas. Just how did you choose an insurance company to save on the prmium.
  7. He is I believe the guy who drew up a live aboard policy and has now parted company with the large insurance company he did this with.I could be wrong but am very sure I recently read this in the press. Towergate Marden.
  8. Using high tempreture silicone sealer is generaly used at top of flue pipe. Much cooler up thete near roof collar. Even used lower by stove but i always use fire cement lower down, just oersonal choice.
  9. If no help comes your way then just go down the Asda route. You will soon have a good stock in the tank if you buy 10 litres daily. As for cost, just get some spare Jerry cans to avoid the same happening again.Had a similar situation stuck amongst stoppages last year when wife had knee replaced. Just used a Tesco and swallowed the extra cost.
  10. The one you pictured, post 19?, mine has an arrow on the side.
  11. Blackrose said ealier: Would you mind checking yours and letting me know if there's any air in it because mine still almost half full of air. I've got a feeling it's supposed to be like that. I can't see how you'd get the air out if the pump won't do it. Just spotted this. Mine is now dismantled but I guess operating the pump would have pushed any air straight out through the skin fitting.
  12. Can see what your saying and it makes sense. I based my way by remarks on here about silicone not setting properly but guess that might have been user error and wrong product.Anyway as long as the join is good all is well.Staying alive by whatever means is what counts for us all.
  13. Use fire cement where chimney enters stove. Use masking tape to get neat finish. When dry paint it with stove black paint. Each year check for any loose pieces and re fill any gaps left when you remove loose pieces, pretty easy maintenance. Where the chimney enters the collar on the roof use silicone.
  14. Same filter i have. The top does unscrew to allow access go wire mesh that catches the muck. Suggest you take it apart and givve it all a good clean. Wipe some vaseline around the thread of the lid makes it easy to remove next time.
  15. Very interesting to see the timeline.
  16. If you go directly opposite you have to swim. Walk is if you use the road bridge.
  17. Horizontal. Just lately using immersion as on a electric hook up for a while. Trouble is ran out of water and all taps released air after tank re filled except the hot. Not completely air locked but enough to be a nuisance when showering. Tried running for long time.....no luck, now looking for other solutions.
  18. Watching this thread. Ran out of water and only problem i have now is air in hot taps. Come on everyone help us both. How do you bleed a hot water feed.
  20. When I click link I can't see any thing about 32GB. or14.50.Help.
  21. Do you know the owners? If yes then price Will reflect this. Will you have travel costs? Have the owners done this before and are they approachable as to the fee they usually pay. Are you fussed about how much you get it will you be happy with pocket money and a bit of an adventure.Much to think about and knowing your feelings about it will tell you which approach to make. If a first just do it for ex's and a change of scenery. Above all enjoy!!!!!
  22. With just 39feet of boat, is this actual boat or cabin length, you can't afford to put the stove just anywhere. Space is At a premium so best keep it in the corner. How you will see any benefit, heat wise, moving it to the middle of the boat is beyond me. Leave it where it is and save yourself a lot of money. Perhaps phoning a few yards for an approxamite quote will make you decide. The cost might shockyou.
