londonron Posted October 19, 2014 Report Share Posted October 19, 2014 After following some good advice from Martin (setting him up nicely for more advice) i am not going to take off the heads of my JP3 just yet. Well not until i can get the spares in advance. So does anyone have any genuine head gaskets? could also do with 1 push rod if they are called that. 1 of mine is working but where the rocker sits its got some damage and want to replace it. also how hard is it to take apart a compression change over thats not sealed properly? Link to comment Share on other sites More sharing options...
by'eck Posted October 20, 2014 Report Share Posted October 20, 2014 Have you looked at the Stationary Engine Parts website, then there's Sleeman and Hawken if you have the original Lister part number and also MPS for obsolete parts now being re-manufactured. Link to comment Share on other sites More sharing options...
martyn 1 Posted October 20, 2014 Report Share Posted October 20, 2014 The issue is getting original head gaskets, as those supplied by most UK suppliers (Stationary Engines and Sleeman's among them)come from the same source and although of decent materials they are dimensionally incorrect (in the region of 0.030") thicker than an Lister/Coopers gasket. In turn this makes it impossible to obtain the correct piston to cylinder head clearance (meant to be 0.045" to 0.050") and ends up in the region of 0.070" clearance using these gaskets and the related smoke/lower compression issues this causes. We are currently tooling up to produce them to the correct dims but don't stock them at this time. Link to comment Share on other sites More sharing options...
frangar Posted October 20, 2014 Report Share Posted October 20, 2014 New old stock head gaskets do crop up on eBay from time to time. I've brought quite a few over the years just to make sure I have some when needed....they are of much better quality than the modern ones....especially the imports from the India & thailand. Cheers Gareth Link to comment Share on other sites More sharing options...
londonron Posted October 26, 2014 Author Report Share Posted October 26, 2014 Hopefully i just figured out how to post pics. I am checking out my low compression issues . Piston no 1 and 2 seems lower than number 3 and i had some smoke blowing out the Changeover valves. I couldnt see any copper washers. Should there be some? Link to comment Share on other sites More sharing options...
londonron Posted October 26, 2014 Author Report Share Posted October 26, 2014 [ I seem to have differant injectors. One with 3 washers to space it out. They seem to have the same seriel number. Just a differant make, ones a bosch and one has a bleed screw/leak off attachment on the head. plus 1 pushrod is chipped all around the edge. If anyone knows where i can get one of those. Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 26, 2014 Report Share Posted October 26, 2014 Hopefully i just figured out how to post pics. I am checking out my low compression issues . Piston no 1 and 2 seems lower than number 3 and i had some smoke blowing out the Changeover valves. I couldnt see any copper washers. Should there be some? Yes. There should be a thin copper washer in there. [ I seem to have differant injectors. One with 3 washers to space it out. They seem to have the same seriel number. Just a differant make, ones a bosch and one has a bleed screw/leak off attachment on the head. plus 1 pushrod is chipped all around the edge. If anyone knows where i can get one of those. Best get them tested and reset while you've got them out, especially if the nozzles are different, hence the need for extra washers. I can recommend a place in East London. Where are you? Link to comment Share on other sites More sharing options...
londonron Posted October 26, 2014 Author Report Share Posted October 26, 2014 (edited) i can do east london easy enough. I am in west london at the moment but can drive over. I have found a place that sells the copper washers. But there are 2 types listed. I guess i need to identify the engine i have ? Edited October 26, 2014 by londonron Link to comment Share on other sites More sharing options...
Timleech Posted October 26, 2014 Report Share Posted October 26, 2014 Sometimes injectors end up with extra seating washers simply because the person refitting them hasn't checked whether the old one is still in the head. Another possibility is that the seating in the head has been damaged at some stage and had to be recut, and washers added to restore the height. Tim Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 28, 2014 Report Share Posted October 28, 2014 (edited) i can do east london easy enough. I am in west london at the moment but can drive over. I have found a place that sells the copper washers. But there are 2 types listed. I guess i need to identify the engine i have ? You could try CJ Diesels in Isleworth who have a good reputation, or the place I use is shown below--and they are brilliant! And canalside and very close to Hackney Wick overground station MV Motors 8a Queens Yard, White Post Lane, London E9 5EN020 8985 6077 Edited October 28, 2014 by monkeyhanger Link to comment Share on other sites More sharing options...
londonron Posted October 29, 2014 Author Report Share Posted October 29, 2014 will give them a call. I think they will be fine but if they can test them for a smallish ammount its worth it to me. Took apart and cleaned all three change over valves. Tomorrow is valve clearance time hope i find something soon though or its pistons. Link to comment Share on other sites More sharing options...
by'eck Posted October 30, 2014 Report Share Posted October 30, 2014 Sometimes find that one or other COV doesn't seal properly after screwing in to start on high compression. A little smoke comes out of the blow hole. Unscrewing the offending COV a half turn with engine running will sometimes help by blowing out any carbon that's causing the leak. After a while they self seal anyway. Link to comment Share on other sites More sharing options...
londonron Posted November 2, 2014 Author Report Share Posted November 2, 2014 funny how as you clean all this stuff up the mechanics make more sense. Sadly my mechanic didnt get to me in time to get into the engine this weekend so we did other jobs. Hoping to do a bit this week. Link to comment Share on other sites More sharing options...
George94 Posted November 6, 2014 Report Share Posted November 6, 2014 I might have a usable used push-rod if you are stuck, and I'm in West London. Send me a PM if you are interested. Link to comment Share on other sites More sharing options...
londonron Posted November 23, 2014 Author Report Share Posted November 23, 2014 hi george. That would be good to swap out before it does something stupid. Have rebuilt it all now. Havent fixed anything to do with the starting but want to get it running without the water leaks i had on the exhaust manifold. Started it but really running bad as the only piston with anywhere like compression now has smoke pouring out the injector where if cant be seating properly. Going to try and remove the copper washer thats stuck inside and replace it and hopefully that will help. Also where i cleaned all the changeover valves up they unscrewed partial while it was running . that wasnt helping either Link to comment Share on other sites More sharing options...
londonron Posted December 4, 2014 Author Report Share Posted December 4, 2014 my suffering continues. The exhaust manifold that was split has been repaired. They couldnt weld it (big split) and wrapped a bronze shield around it and drilled and tapped a load of screws to secure it. Sadly it looked like somehow the inside has a split between the exhaust and water section as after a test run i took it off and was full of water. I know marine services are without the pattern to make these at the moment. Any ideas as im stuck and broken. Either how to rig up a new system or to source a replacement. Link to comment Share on other sites More sharing options...
