Willber G Posted January 16, 2014 Report Share Posted January 16, 2014 It's what a red indian ventriloquist lives in. Link to comment Share on other sites More sharing options...
Janet S Posted January 16, 2014 Report Share Posted January 16, 2014 Bit confusing for Leeds Liverpool cruisers, the "WIg Wag" is a term used to describe a series of very sharp bends between Barnoldswick and Skipton. No, that's the wiggly waggly bit... Janet Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2014 Report Share Posted January 16, 2014 No, that's the wiggly waggly bit... Janet And it's one of the most beautiful parts of the whole system... Link to comment Share on other sites More sharing options...
Rick-n-Jo Posted January 16, 2014 Report Share Posted January 16, 2014 An electrical circuit or logic circuit which alternates between two states is known as a wig wag. Since this sort of circuit would be likely to be used to control alternating lights, I'd always assumed that they were named after the electrics. 'Course it's possible that the circuit itself was named after the wavy US railroad signs... Link to comment Share on other sites More sharing options...
MoominPapa Posted January 16, 2014 Report Share Posted January 16, 2014 (edited) An electrical circuit or logic circuit which alternates between two states is known as a wig wag. Flip-flop, surely? MP. ETA example: http://www.msarnoff.org/chipdb/7474 Edited January 16, 2014 by MoominPapa Link to comment Share on other sites More sharing options...
trackman Posted January 16, 2014 Report Share Posted January 16, 2014 (edited) Thanks for the various informative answers. But, trackman, at a canal crossing, the bridge physically prevents passage when lifted, or turned across the canal. Think about how typical canal lift and swing bridges work. I think you will realise that what I said has a valid point! Usually the bridge lifts or swings to one side only, leaving open access on the other for a vehicle that ignores the signals to go straight into the cut. Even on the side where the bridge is, a nasty accident would result if a vehicle ran into the structure at any speed and the vehicle could still end in the canal. Remember these lights are often used at open crossings with no physical barriers, or at those with half barriers that vehicles can drive around if the driver is daft enough. Edited January 16, 2014 by trackman Link to comment Share on other sites More sharing options...
Rick-n-Jo Posted January 16, 2014 Report Share Posted January 16, 2014 Flip-flop, surely? MP. ETA example: http://www.msarnoff.org/chipdb/7474 Hmm, it does appear that the circuits I remember are all to do with flashing lights. So circuit prob. named after its purpose, not the other way around. Should have Googled before posting... Link to comment Share on other sites More sharing options...
Machpoint005 Posted January 17, 2014 Report Share Posted January 17, 2014 A wig wag is for ducks to perk on. Link to comment Share on other sites More sharing options...
Mike Todd Posted January 17, 2014 Report Share Posted January 17, 2014 I must admit I had in mind the greater majority of those I have encountered which are mechnaised complete with interlocking gates which have to be fully shut before the bridge can be opened, but I guess there are others since there is no standardisation of mechanised bridge design! (I was also assuming that we were talking specifically about mechanised ones) Think about how typical canal lift and swing bridges work. I think you will realise that what I said has a valid point!Usually the bridge lifts or swings to one side only, leaving open access on the other for a vehicle that ignores the signals to go straight into the cut.Even on the side where the bridge is, a nasty accident would result if a vehicle ran into the structure at any speed and the vehicle could still end in the canal.Remember these lights are often used at open crossings with no physical barriers, or at those with half barriers that vehicles can drive around if the driver is daft enough. Link to comment Share on other sites More sharing options...
