tom_c Posted October 3, 2010 Report Share Posted October 3, 2010 (edited) here is a short video of the first run of the kelvin F2 destined to go into judith ann, hopefully will get a better video next time we run it Edited October 3, 2010 by tom_c Link to comment Share on other sites More sharing options...
charles123 Posted October 3, 2010 Report Share Posted October 3, 2010 I dont have facebook and dont want to sign up can you put it on youtube please I would like to see and hear it? Charles Link to comment Share on other sites More sharing options...
tom_c Posted October 3, 2010 Author Report Share Posted October 3, 2010 http://www.youtube.com/watch?v=wG4uef1h2JE try this one Link to comment Share on other sites More sharing options...
RLWP Posted October 3, 2010 Report Share Posted October 3, 2010 http://www.youtube.com/watch?v=wG4uef1h2JE try this one Is your boat going to be used somewhere on the equator? Turn it another 90 degrees and you could use it in Australia Richard Link to comment Share on other sites More sharing options...
NB Alnwick Posted October 3, 2010 Report Share Posted October 3, 2010 Seriously, it looks as if you have completed a very nice restoration job. Presumably that video shows the engine running on paraffin/kerosene, is it more economical than an equivalent diesel engine? I said presumably because I would have have thought it risky to install the petrol version in a boat these days . . . Link to comment Share on other sites More sharing options...
tom_c Posted October 3, 2010 Author Report Share Posted October 3, 2010 the engine was running on petrol in this video but we are developing a glow plug starting system to enable cold starting on kerosene Link to comment Share on other sites More sharing options...
NB Alnwick Posted October 3, 2010 Report Share Posted October 3, 2010 the engine was running on petrol in this video but we are developing a glow plug starting system to enable cold starting on kerosene Do you have the Kelvin 'Vaporiser'? I haven't seen a F series engine close up but the bigger 'G' series were fitted with vaporisers and always ran on kerosine . . . Link to comment Share on other sites More sharing options...
tom_c Posted October 3, 2010 Author Report Share Posted October 3, 2010 hi we have quite a few vaporisers, the engine cannot run without it as it also acts as a manifold, however until the vaporiser has heated up we hope to use an electric glow plug to vaporise the fuel. we will see what fuel consumption is like once it goes into the boat. we also have 2 more F4 engines and another F2 and a poppet valve, also some of those common kelvin diesels a J3 and a K2, the J3 is for sale if anyone is interested, i also have some original kelvin propellers to suit some of the engines. Link to comment Share on other sites More sharing options...
NB Alnwick Posted October 3, 2010 Report Share Posted October 3, 2010 Sounds as if you have a very interesting collection . . . Link to comment Share on other sites More sharing options...
billh Posted October 4, 2010 Report Share Posted October 4, 2010 I said presumably because I would have have thought it risky to install the petrol version in a boat these days . . . Why would it be risky "these days" , if as you imply, it wasn't in olden days? Is today's petrol somehow more volatile? If the installation of tanks and fuel lines, carburetor drip trays etc is done properly petrol is ok though re-fuelling a boat where there is no canalside pump could be fraught. The fuel consumption of these F model Kelvins is not good but there are several advantages to using them which I could list if anyone's interested.( As an F2/4 user these last 38 years.) We have a J2 diesel that was got years ago to replace the F4 for fuel economy reasons, but it so far hasn't made it into the (wooden) boat. The F4 is just too nice. Tom's idea of an electric pre-heater for starting direct on Kerosene sounds promising, I should like to see the details of that. Bill Link to comment Share on other sites More sharing options...
billh Posted October 4, 2010 Report Share Posted October 4, 2010 Do you have the Kelvin 'Vaporiser'? I haven't seen a F series engine close up but the bigger 'G' series were fitted with vaporisers and always ran on kerosine . . . The differences between model F petrol and petrol/paraffin are as follows: Compression ratio: pet= 4.5:1 par: 3.6:1 (cylinder heads are different) Exhaust manifold : petrol looks like an ordinary automotive exhaust manifold. Paraffin: the inlet and exhaust manifold is combined into one to vapourize the fuel at the inlet due to the heat of the exhaust. The engine will take paraffin about 2 mins after a cold start so doesn't need much petrol. Cooling system: paraffin: there is a manual regulator to cut down the water flow to the cylinders to help keep the engine hot when slow running.Not fitted to petrol engines Fuel system: there is a fuel change over cock on each carburetor. I think the 60HP G4 had 4 carbs- how economical is that? The F4 will run very well on two cylinders , just shut the fuel off to one of the two carbs if we are pottering about in locks or shallow canals, (ie: most of the time round here!). Bill Link to comment Share on other sites More sharing options...
NB Alnwick Posted October 4, 2010 Report Share Posted October 4, 2010 Why would it be risky "these days" , if as you imply, it wasn't in olden days? Is today's petrol somehow more volatile? If the installation of tanks and fuel lines, carburetor drip trays etc is done properly petrol is ok though re-fuelling a boat where there is no canalside pump could be fraught. The fuel consumption of these F model Kelvins is not good but there are several advantages to using them which I could list if anyone's interested.( As an F2/4 user these last 38 years.) We have a J2 diesel that was got years ago to replace the F4 for fuel economy reasons, but it so far hasn't made it into the (wooden) boat. The F4 is just too nice. Tom's idea of an electric pre-heater for starting direct on Kerosene sounds promising, I should like to see the details of that. Bill My 'these days' was intended as a reference to our current culture of 'Health & Safety' and 'Risk Assessment' - the latter usually being carried out by those with no practical experience. Link to comment Share on other sites More sharing options...
billh Posted October 4, 2010 Report Share Posted October 4, 2010 http://www.youtube.com/watch?v=wG4uef1h2JE try this one Nice one, it's 28 years since I heard that rhythm. Does the impulse work on the magneto, with the electric starter? On the F4 the motor turns the engine too fast so the impulse disengages, so difficult start. It's easier with the handle! Bill Link to comment Share on other sites More sharing options...
tom_c Posted October 4, 2010 Author Report Share Posted October 4, 2010 hi Bill, the impulse works fine with this engine, it also worked on the F4, we nicked the starter and flywheel to put on this f2, but it will probably be converted back to handstart only at some point Tom Link to comment Share on other sites More sharing options...
tom_c Posted October 15, 2010 Author Report Share Posted October 15, 2010 here is another video of the kelvin running, this time on a mixture of petrol and paraffin and also hopefully the correct way up Link to comment Share on other sites More sharing options...
stagedamager Posted October 15, 2010 Report Share Posted October 15, 2010 Sounds and looks great, nicely done! Link to comment Share on other sites More sharing options...
stagedamager Posted October 26, 2010 Report Share Posted October 26, 2010 Any more pictures? Link to comment Share on other sites More sharing options...
tom_c Posted October 27, 2010 Author Report Share Posted October 27, 2010 not yet dan been a bit busy with work Link to comment Share on other sites More sharing options...
