steelaway Posted February 2, 2010 Report Share Posted February 2, 2010 Hi All Ive just bought a HP Office Pro 8000, with an automatic 2 sided (duplex) facility. I tried to print a two sided .pdf document but when I select print options it wont open. I cannot select two sided printing and I cannot get Adobe to talk to the printer. The printer default is set to two sided Help?????? Alex Link to comment Share on other sites More sharing options...
Liam Posted February 2, 2010 Report Share Posted February 2, 2010 Can you print from anything else, such as Internet Explorer or Notepad (If you're on Windows that is) Link to comment Share on other sites More sharing options...
steelaway Posted February 2, 2010 Author Report Share Posted February 2, 2010 Can you print from anything else, such as Internet Explorer or Notepad (If you're on Windows that is) Hi Liam I can print two sided with MS Publisher - no problem. I've not tried IE or Notepad. There just seems to be no connection from Adobe to the printer. I'm on windows 7 but sure thats not the problem. Alex Link to comment Share on other sites More sharing options...
RLWP Posted February 2, 2010 Report Share Posted February 2, 2010 Hi Liam I can print two sided with MS Publisher - no problem. I've not tried IE or Notepad. There just seems to be no connection from Adobe to the printer. I'm on windows 7 but sure thats not the problem. Alex Which version of Adobe? Richard Link to comment Share on other sites More sharing options...
Liam Posted February 2, 2010 Report Share Posted February 2, 2010 When you say you can't get Adobe to talk to the printer, what exactly do you mean. When you go into Print, do you mean that there's no printer listed, or does the print properties window crash? Link to comment Share on other sites More sharing options...
steelaway Posted February 2, 2010 Author Report Share Posted February 2, 2010 When you say you can't get Adobe to talk to the printer, what exactly do you mean. When you go into Print, do you mean that there's no printer listed, or does the print properties window crash? When you select print you have a select print option, but when I select it nothing happens, it just sits there. When I select print it only prints one sided I'm on Adobe 9.3 Alex Link to comment Share on other sites More sharing options...
Liam Posted February 2, 2010 Report Share Posted February 2, 2010 You may have to go into the Adobe print properties and enable duplex printing seperately in there. I'm on a PC with no printer installed at the moment so can't double check. I've had something similar in the past where margins set up on the actual printer worked when printing in all applications apart from Adobe which had to be setup seperately. Link to comment Share on other sites More sharing options...
Keeping Up Posted February 2, 2010 Report Share Posted February 2, 2010 Have you tried it with pdf documents that have previously printed two-sided? I only ask because I often receive pdf documents in which the author has "locked out" the print options Link to comment Share on other sites More sharing options...
stewey Posted February 3, 2010 Report Share Posted February 3, 2010 Adobe can be pretty flaky at times. I tend to use the alternative Foxit for opening and dealing with PDFs. You can download it for free from the following site: http://www.foxitsoftware.com/pdf/reader/download.php Stewey Link to comment Share on other sites More sharing options...
steelaway Posted February 3, 2010 Author Report Share Posted February 3, 2010 Have you tried it with pdf documents that have previously printed two-sided? I only ask because I often receive pdf documents in which the author has "locked out" the print options Hi You have hit it on he head. It is this one bloody .pdf that must have some kind of printer lock on it, even though it allows you to print it. There would have been less confusion if I hadn't just bought a new printer. Thanks for your time guys. Alex Link to comment Share on other sites More sharing options...
