MrCJ Posted October 29, 2009 Report Share Posted October 29, 2009 I just watched waterworld on the tv. A guy on there had got a cordless drill made up attachment called a lockmaster. just put it on pressed the button and opened the paddles. Is there something like this out there? Link to comment Share on other sites More sharing options...
carlt Posted October 29, 2009 Report Share Posted October 29, 2009 I just watched waterworld on the tv. A guy on there had got a cordless drill made up attachment called a lockmaster. just put it on pressed the button and opened the paddles. Is there something like this out there? If you've seen it then it's out there. Link to comment Share on other sites More sharing options...
MrCJ Posted October 29, 2009 Author Report Share Posted October 29, 2009 If you've seen it then it's out there. No this was something he had made himself was just wondering if there was something off the shelf you could buy. Link to comment Share on other sites More sharing options...
magpie patrick Posted October 29, 2009 Report Share Posted October 29, 2009 No this was something he had made himself was just wondering if there was something off the shelf you could buy. You could, in theory, use a 1 inch socket, or even make your own, however the revs might be problematic on most locks, and the load. My drill is several hundred revs per minute and the average paddle needs about 3 turns to get it up, at drill speed the paddle would lift in a fraction of a second and I suspect the cast iron gearing wouldn't be happy, nor would the drill as the torque needed would be pretty impressive. gearbox? Link to comment Share on other sites More sharing options...
JonL Posted October 29, 2009 Report Share Posted October 29, 2009 You can get a cordless tool designed to remove car wheelnuts. Slow rev's but buckets full of torque. That will do the job. Link to comment Share on other sites More sharing options...
The Toad in the Hole Posted October 29, 2009 Report Share Posted October 29, 2009 I've got a custom made biomechanical attachment that's factory fitted to my shoulder. Using a complex but very reliable neuro-electric command system, my brain can command the Automatic Rewind Mechanism to rotate the windlass automatically, thus raising the paddles with the minimum of effort. I have also adapted the A.R.M mechanism to steer the boat without too much readjustment. The only significant problem I've had with it is after repeated use raising pint pots in the pub. The communication network progressively degrades leading to eventual beer/ mouth synchronisation issues and subsequent spillage. Apparently there's a software patch to fix this issue, but they haven't got a release date yet. Link to comment Share on other sites More sharing options...
JonL Posted October 29, 2009 Report Share Posted October 29, 2009 It's not a software patch but a peripheral called Wife . Link to comment Share on other sites More sharing options...
denboy Posted October 29, 2009 Report Share Posted October 29, 2009 You can get a cordless tool designed to remove car wheelnuts.Slow rev's but buckets full of torque. That will do the job. Got mine at the bargain price of £350 including spare batty Link to comment Share on other sites More sharing options...
Mac of Cygnet Posted October 29, 2009 Report Share Posted October 29, 2009 Slow rev's but buckets full of torque. I can see Mrs Mac using that, being slowly but surely turned upside down. Link to comment Share on other sites More sharing options...
MrCJ Posted October 29, 2009 Author Report Share Posted October 29, 2009 I know its lazy but it looked like a good gaget you know one of those things you really must have and cant live without it, which then ends up in the back of a cuboard when the next thing comes along Link to comment Share on other sites More sharing options...
pugwash61 Posted October 29, 2009 Report Share Posted October 29, 2009 Its all very well using something like that to wind the paddles up, but what about winding them back down again? Link to comment Share on other sites More sharing options...
twocvbloke Posted October 29, 2009 Report Share Posted October 29, 2009 Its all very well using something like that to wind the paddles up, but what about winding them back down again? Set the device into reverse? Link to comment Share on other sites More sharing options...
pugwash61 Posted October 29, 2009 Report Share Posted October 29, 2009 Er, that's not gonna work is it? surely it'll come crashing down. When you wind the paddles down by hand, you have to take the weight of the paddle and backwind slowly. I'm sorry (it may be just me), but I just cant see an electric motor being able to work out the differing weights of differing winding gear & dropping the paddles gently. Link to comment Share on other sites More sharing options...
carlt Posted October 30, 2009 Report Share Posted October 30, 2009 Er, that's not gonna work is it? surely it'll come crashing down. When you wind the paddles down by hand, you have to take the weight of the paddle and backwind slowly. I'm sorry (it may be just me), but I just cant see an electric motor being able to work out the differing weights of differing winding gear & dropping the paddles gently. I drop the paddles using my hand as a clutch, to regulate the speed of descent. A motor could easily be adapted to do a similar thing. Link to comment Share on other sites More sharing options...
NB Phoenix Posted October 30, 2009 Report Share Posted October 30, 2009 Lockmaster Windlass Should be available Spring / Summer 2007 Fits any cordless drill............. Still developing a plastic seaseacher magnet for when you drop the drill into the cut! Link to comment Share on other sites More sharing options...
MrCJ Posted October 30, 2009 Author Report Share Posted October 30, 2009 Lockmaster Windlass Should be available Spring / Summer 2007 Fits any cordless drill............. Still developing a plastic seaseacher magnet for when you drop the drill into the cut! well just looked at the website it said it would be lunched 2007 and we now in 2009 I think it never did. Link to comment Share on other sites More sharing options...
Keeping Up Posted October 30, 2009 Report Share Posted October 30, 2009 IIRC the demo on Waterworld only showed it being used on the unique worm-driven paddle-gear on the Northern Grand Union (Hatton/Knowle etc) which is characterised by geared paddles that are very easy to raise, and which return on their own by gravity without being wound down. When I saw it I wondered how it could possibly work on the more traditional rack-and-pinion lock gear. Link to comment Share on other sites More sharing options...
pugwash61 Posted October 30, 2009 Report Share Posted October 30, 2009 Well I cant see it being able to first take the weight of the paddle, whilst you then remove the safety clip, then lowering the paddle gear. I stand to be corrected, I'm open to persuasion, but I'm not convinced............... You'd need 3 hands Link to comment Share on other sites More sharing options...
NB Alnwick Posted October 30, 2009 Report Share Posted October 30, 2009 Well I cant see it being able to first take the weight of the paddle, whilst you then remove the safety clip, then lowering the paddle gear. I stand to be corrected, I'm open to persuasion, but I'm not convinced............... You'd need 3 hands Am I missing something? What would be the advantage over a conventional windlass? Why change something that has worked well for over 150 years and that has no elecktrickery or moving parts to fail? Link to comment Share on other sites More sharing options...
MrCJ Posted October 30, 2009 Author Report Share Posted October 30, 2009 (edited) Am I missing something? What would be the advantage over a conventional windlass? Why change something that has worked well for over 150 years and that has no elecktrickery or moving parts to fail? the guy on the tv said he was getting on and could manage the winding up of the puddles anymore so he came up with this so he could carry on boating. Edited October 30, 2009 by MrCJ Link to comment Share on other sites More sharing options...
pugwash61 Posted October 30, 2009 Report Share Posted October 30, 2009 Am I missing something? What would be the advantage over a conventional windlass? Why change something that has worked well for over 150 years and that has no elecktrickery or moving parts to fail? Here hear. I'll go along with that. Any way, I already have an automatic lock paddle winder. Lisa's her name, Mrs. Pugwash. (Take cover...................Incoming)!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
NB Alnwick Posted October 30, 2009 Report Share Posted October 30, 2009 the guy on the tv said he was getting on and could manage the winding up of the puddles anymore so he came up with this so he could carry on boating. But if the tool applies torque to the paddle gear, then there must be an equal amount of torque in the opposite direction - therefore if the paddle gear is particularly difficult to turn, the tool would be equally difficult to hold. The tool and battery must be much heavier than a traditional windlass and probably much more difficult to carry on your belt or when riding a bicycle. I just cannot see its advantage over winding a traditional windlass Link to comment Share on other sites More sharing options...
MrCJ Posted October 30, 2009 Author Report Share Posted October 30, 2009 (edited) As the person that started this thread I not saying I want to go out there and buy one, need to get the boat first lol. I can see alot of you dont think its a good idea. Now my view is that it worked for this guy, it did look very big and heavier then a normal windlass and as its already been said you cant put in your belt plus you got to have plenty of batterys. But personally I find the winding up and down of the paddles on the locks all part of the fun and enjoyment of being on the canals. Edited October 30, 2009 by MrCJ Link to comment Share on other sites More sharing options...
nb Innisfree Posted October 30, 2009 Report Share Posted October 30, 2009 You could, in theory, use a 1 inch socket, or even make your own, however the revs might be problematic on most locks, and the load. My drill is several hundred revs per minute and the average paddle needs about 3 turns to get it up, at drill speed the paddle would lift in a fraction of a second and I suspect the cast iron gearing wouldn't be happy, nor would the drill as the torque needed would be pretty impressive. gearbox? Somersault? What we need is a manual windlass no larger or heavier than standard with a ratchet and extendable handle (for delicate ladies). Link to comment Share on other sites More sharing options...
Swallowman Posted October 30, 2009 Report Share Posted October 30, 2009 What we need is a manual windlass no larger or heavier than standard with a ratchet and extendable handle (for delicate ladies). Just like the one I designed and had made by an engineering company near home. Problem was drilling a square hole - how would you do that? Link to comment Share on other sites More sharing options...
