Batavia Posted April 5, 2009 Report Share Posted April 5, 2009 I am replacing the plywood "liners" inside the steel roof hatches on Daedalus - after 16 years they are starting to de-laminate. They were stuck on with Evostick 528 and much of this remains firmly fixed to the primed steel. I need to get this off to level the surface before fixing the new liners. Any suggestions as to how best to do this, before I start experimenting with different solvents, heat, etc.? Thanks Chris G Link to comment Share on other sites More sharing options...
Ex- Member Posted April 5, 2009 Report Share Posted April 5, 2009 Cellouse thinners will softenit slowly then try to scrape off with a good sharp edged scraper. This stuff can be a nightmare and in the past I've resorted to paint stripper to remove it which worked well on a painted surface. Don't envy you this job at all especially if originally applied with a nothced trowel as it tends to be quite thick. Link to comment Share on other sites More sharing options...
Hairy-Neil Posted April 5, 2009 Report Share Posted April 5, 2009 (edited) If it's just the hatch lids themselves, it's no big deal to repaint them when you've done. Use butane blowlamp or a heat gun even might do it...... Edited April 5, 2009 by Hairy-Neil Link to comment Share on other sites More sharing options...
Greybeard Posted April 5, 2009 Report Share Posted April 5, 2009 Hi Chris. I've seen a council guy removing some carpet glue using something like this http://www.hagesan.co.uk/epages/61534384.s.../Products/hag66 I don't know if it'll work with evostick though. Supposedly enviro friendly as well. Mike Link to comment Share on other sites More sharing options...
Biggles Posted April 5, 2009 Report Share Posted April 5, 2009 Many years ago when I did some decorating for a contractor at a hospital. I had to get loads of this off a slice room that had been clad half wiy up with Marley tiles. Paint stripper did the job. Biggles Link to comment Share on other sites More sharing options...
alan_fincher Posted April 5, 2009 Report Share Posted April 5, 2009 You used to be able to buy a product called, (quite literallY), "Evo Stick Remover". I'm guessing you can't any more ? Link to comment Share on other sites More sharing options...
Batavia Posted April 6, 2009 Author Report Share Posted April 6, 2009 You used to be able to buy a product called, (quite literallY), "Evo Stick Remover". I'm guessing you can't any more ? Ha! Yes you can....if you look in the right place. I had not found it at a few on-line places I have been looking at for buying the new glue, then today I walked into VAH and they had about 20 tins on the shelf. Expensive (if you want to make your own, it is Heptane and Naptha), but I will try and see if it is a feasible (and affordable) solution before reverting to other solvents - starting with petrol. Nice smell, though. Thanks to others for your suggestions. Chris G Link to comment Share on other sites More sharing options...
LEO Posted April 6, 2009 Report Share Posted April 6, 2009 Ha! Yes you can....if you look in the right place. I had not found it at a few on-line places I have been looking at for buying the new glue, then today I walked into VAH and they had about 20 tins on the shelf. Expensive (if you want to make your own, it is Heptane and Naptha), but I will try and see if it is a feasible (and affordable) solution before reverting to other solvents - starting with petrol. Nice smell, though. Thanks to others for your suggestions. Chris G Hope all goes well - if VAH don't stock a product it's not made! it's a veritable tardis for Hardware and 'goodies' A bit old for solvent abuse aren't you! ATB Mike Link to comment Share on other sites More sharing options...
