Failed Inverter
Bullfrog
Today I switched on my small inverter (Sterling Model A-300-350 2/12 volts modified sine wave. almost exactly 3 years old ) and there was a pop, the light in the switch flashed and went out and that was it - completely dead.
Is there anything fixable in one of these, like a fuse or something, or should I just chuck it and get another, it wasn't expensive when I bought it.
Help, please.
Thanks
David
Maybe just my preference but I'd definately look at getting it fixed.
I'm old enough to have been taught to fix things down to component level and as far as I am aware there isn't too much in an inverter that is complicated so a fix is a definate possibility.
Usual problems of labour cost if you have it done for you or parts availability (and safety) if you do it yourself.
Help, please.
Thanks
David
If it went Pop you will probably find that a component has gone. the first problem is finding out Why, the second is identifying it, the third is replacing it (Inverters can be quite complex) and lastly and most important, doing it safely as high voltages are present, my advice is to bin it
It really depends on how confident/knowledgable you are at component level electronics.
It could be something simple like a Cap or Diode - or it could be something on the HF side where you could do with the circuit diagram showing the waveforms and voltages to be expected at various test points.
Def worth taking the lid off tho :rolleyes:
I will say this once. The chances of fixing it unless you are very experienced are about nil.
It's possible that it's something minor but extremely unlikely. When these things go they usually go big time.
The labour costs for a professional to remove the screws to have a look inside it will exceed the value of the unit.
As I said, it is possible for minor faults to happen, but it is EXTREMELY rare.
Gibbo
Gibbo is right. TBH, even if a fuse has blown, and you replace it, there will have been a reason for its blowing which is usually down to a component failure somewhere deep inside. Even for someone with electronics knowlege, without a circuit diagram, one is working in the dark.
Chris
Gibbo
Thanks - this was my original reaction and you've confirmed it!
Regards
David
I bought a 600W inverter a couple of years ago from Maplin simply because they were at a give-away price at the time. Although I've never yet used it, I did put it on my oscilloscope to have a look at its output. I was surprised to find that it wasn't even a modified-sine wave (ie: a multi-step square wave) output but just a simple square wave output. Lots of stuff will object to running on that.
That's not to say of course that this model is the same kind of output but it's something of which to be aware.
Chris
Chris
doesn't the wave form improve with load ?
No it doesn't.
A squarewave inverter is the simplest way of making an inverter and will have tons of harmonics as well as high harmonic distortion. It will still run Switched-Mode Power Supllies (SMPS) though as these are indifferent to waveform input shape.
Chris
I'd hold onto it for a while, you may come across someone who can fix it cheaply and easily.
They are relatively simple, I'd expect a 50% chance that £2 of components will sort it.
If you really want to bin it, and live in E. Grinstead and pass Horsham any time, could you possibly drop it off there? If so please PM me.
cheers,
Pete.
Edited by smileypete
I said a 350W MSW is relatively simple, do you find them complicated? :rolleyes:
cheers,
Pete.
A perfect of example of a novice believing something is simpler than it really is.
The timing waveforms, voltage levels, shoot-through prevention, inductor current and saturation levels, snubbing, along with a handful of other things are absolutely critical in inverters. If any one of them is out by just a tiny fraction the result is another bag of charcoal as soon as all the expensive components have been replaced.
I've watched in amazement (many times) as a novice switches on a freshly repaired inverter and instantly gets his eyebrows blackened even though he "replaced all the burnt parts".
Just because only one part shows external physical damage does not mean that's the only part failed.
Just because there are few parts in a device does *not* mean it is a simple device. The operation could be very complex.
Try to build yourself one from *your own* design if they are so simple. You'll be in for a shock.
Gibbo
