I lost the key to the padlock on the rear door of my Norman 27
He's probably miles away by now with all the contents of the boat.
I used to regularly cut locks off tractor toolboxes......odd thing was a common,heavily advertized brand was very soft under the hard case,and the one that busted the boltcutters was a cheapie brand  with a small dia staple ............since the net has showed every scrote how to pick locks ,its back to putting a 3 ton lump of concrete against the door.
  • 2 weeks later...
If you have access to liquid nitrogen, dip the lock in a cup of liquid nitrogen and hit with a hammer. The carbon-steel and low alloys steels used for the case and locking ring are temporarily embrittled or lose impact strength at liquid nitrogen temperature and shatter when subjected to a blow. The brass alloy use in the lock are not significantly affected by low temperature of liquid nitrogen.
Demo of liquid nitrogen being used to break a padlock
https://youtu.be/7KE-_dY4PdY
