Roxylass Posted May 7, 2023 Report Share Posted May 7, 2023 What pressure should be showing on my oil gauge when engine starts the needle shows 40 After 20/30minutes it drops to 20 engine seems fine not heating up engine in question sr2 air cooled Link to comment Share on other sites More sharing options...
Tony Brooks Posted May 7, 2023 Report Share Posted May 7, 2023 I would suggest probably OK, but check the oil. Those engines are known for internal fuel leaks that dilute the oil, causing low oil pressure. Feel the oil on the dipstick between thumb and finger and compare it with new oil. also smell it for an unburned diesel small. If this is the problem and it is ignored, the engine will eventually seize up or run away on oil/diesel fumes. Link to comment Share on other sites More sharing options...
Roxylass Posted May 7, 2023 Author Report Share Posted May 7, 2023 Thanks for the quick reply tony engine oil looking like new only changed last year 9and a half pints no blackness to it at all or diesel smell Link to comment Share on other sites More sharing options...
Tony Brooks Posted May 7, 2023 Report Share Posted May 7, 2023 1 hour ago, Roxylass said: Thanks for the quick reply tony engine oil looking like new only changed last year 9and a half pints no blackness to it at all or diesel smell Make sure the oil is the correct SAE specification. My guess is that originally, for UK summer use it would be SAE 30 and SAE 20 for winter, then multigrades came along so probably SAE 20W50 but nowadays, we have things like SAE 5W20 which are probably totally unsuitable because A. it is probably synthetic oil, but as long as the engine is well run in probably won't do much harm in the short term, but more importantly B. it is too runny, so low oil pressure. Hopefully a Lister expert will be along to give chapter and verse. Link to comment Share on other sites More sharing options...
bizzard Posted May 7, 2023 Report Share Posted May 7, 2023 (edited) The SR2 generally run at about 15-20 psi when up to normal running temp. Tick over around 6-10 psi. Edited May 7, 2023 by bizzard Link to comment Share on other sites More sharing options...
Steve56 Posted May 8, 2023 Report Share Posted May 8, 2023 Here's the relevant info from the Lister Manual Link to comment Share on other sites More sharing options...
Roxylass Posted May 10, 2023 Author Report Share Posted May 10, 2023 Many thanks for the reply’s lads Saved me buying a new gauge Cheers Link to comment Share on other sites More sharing options...
