Roxylass
Everything posted by Roxylass
  1. Roxylass
    SR2
    Should I hand crank the SR2 first to get the oil up to the cylinder heads or is this practice not necessary if you have a starter motor haven’t started the engine since October
  2. Are you not meant to put NO1 cylinder decompression lever down first And then NO2 decompression lever I’ve always done that but then I’m not as learned as you guys Once again many thanks
  3. Thanks bizzard is there a lot involved in taking the bottom sprocket off i do have a diagram of it in the parts book or stick with the bungee cord
  4. It does have a dogged starting handle for the camshaft getting past trying to keep it spinning while blindly reaching up for the compression levers
  5. I have a you tube account but can’t seem to move the video from the iPad using the handle start on the camshaft the bottom sprocket doesn’t turn also the raised hand start and chain stay still whilst turning the handle looking from the camshaft end I can move the raised hand start half a revolution Clockwise then it stops spins freely anti-clockwise fitted a bungee cord to stop the spinning just now would it be to complicated for a novice to remove the bottom sprocket to have a look inside
  6. Video won’t load for me
  7. Will that be the at the crankshaft standing at the crankshaft end i can freewheel the raised hand start one way half a turn the other way then it engages got a wee vid hope it shows
  8. When the engine is running i can hold the raised start and stop it spinning without hardly tightening my handgrip let it go and it will start spinning again
  9. On the SR2 is there a device for stopping the hand start Spinning or is it up to the individual to come up with their own device don’t wish to drill a hole through one of the support brackets and insert a long bolt Also don’t think bungee are reliable enough Kind Regards
  10. Many thanks for the reply’s lads Saved me buying a new gauge Cheers
  11. Thanks for the quick reply tony engine oil looking like new only changed last year 9and a half pints no blackness to it at all or diesel smell
  12. What pressure should be showing on my oil gauge when engine starts the needle shows 40 After 20/30minutes it drops to 20 engine seems fine not heating up engine in question sr2 air cooled
  13. Did lister ever supply the air outlet ducting or just the oblong flange Then you had to fit your own canvas or is it feasible to make a solid one Engine in question SR2
  14. I will keep the sticky bit Also use a screw
  15. No the plaque has nothing to do with it at all built in 1968 the glass is rather thick on it but still go down the batten route Also get some of the plastic coated p clips Appreciate your help Tony
  16. Will try that Tony once I have made fast with batten can I use aforementioned clamps plaque on the boat says SMB suitable for carrying 8 persons
  17. Roxylass
    5/16 fuel pipe
    Renewed my feed and return fuel pipes only renewed from the fuel tank to first big filter thats positioned about a metre and a half from the tank not all the way to the small diesel filter on the engine SR2 the ones that I renewed were held fast with closed cell foam don't think the pipes have seen daylight since the section of the bow that I had to remove was counter sunk brass screws2inch and then the screw hole puttyed up 16ft cheverton 1968 not foaming it up again could I use small u clips that is used for electric cable To hold the pipes and steady them
  18. How can I look up my past posts
  19. Roxylass
    15w40
    Thanks Tracy
  20. Roxylass
    15w40
    £60 twenty ltrs good bargain or not
  21. Roxylass
    Gland packing
    Hi Tony the gear box on this SR2 LM 100
  22. Roxylass
    Gland packing
    I wouldn’t think so
  23. Roxylass
    Gland packing
    Boat back in the water this week noticed a small drip not much of a drip but again don’t want a drip at all engine in question Lister SR2 is it a case of taking the nut of each side of the prop shaft and pull the collar back remove packing and renew also is the graphite packing the best to use quite sure my prop shaft is an inch in diameter
  24. Many Thanks Gentlemen Appreciated
  25. Engine in question Lister SR2 when I stop said engine which is just warm to touch after a couple of hours running touch it again 5 minutes later and it is quite hotter is this the normal since it is not drawing cooling air
