knares Posted February 18, 2023 Report Share Posted February 18, 2023 could some one post a picture of the external governor and execrator linkage please i have a manual but the picture is not very clear, i think part of the linkage is missing the motor governor dose not come in and it stalls Link to comment Share on other sites More sharing options...
john.k Posted February 18, 2023 Report Share Posted February 18, 2023 Whats an EXCREATOR...sounds painful..............anyhoo ,its more likely the racks goings thru the pumping units are sticky ........take off the cover and see if there is extensive rust inside gumming things up.................My dumpy with a SL2 was like this after being lost under a bush for 10 years ........after a few hours running it freed up ,and now starts and runs easily. Link to comment Share on other sites More sharing options...
knares Posted February 18, 2023 Author Report Share Posted February 18, 2023 hahaha, yes it dose, don't know where that came from thanks for the info, which cover do you mean, the one opposite the fly wheel but i still think some of the linkage is missing Link to comment Share on other sites More sharing options...
bizzard Posted February 18, 2023 Report Share Posted February 18, 2023 3 minutes ago, knares said: hahaha, yes it dose, don't know where that came from thanks for the info, which cover do you mean, the one opposite the fly wheel but i still think some of the linkage is missing Port side. Upper long plate directly below air cooling outlet box. Throttle cable linkage probably attached to it. Link to comment Share on other sites More sharing options...
knares Posted February 26, 2023 Author Report Share Posted February 26, 2023 ok guys this is what i have got dose it look normal, or is some thing missing the wire is the stop cable Link to comment Share on other sites More sharing options...
Steve56 Posted February 27, 2023 Report Share Posted February 27, 2023 10 hours ago, knares said: ok guys this is what i have got dose it look normal, or is some thing missing the wire is the stop cable No it doesn't look normal if your engine is a variable speed model. There appears to be very little movement on the speed control lever. I would only expect to see something like this if it was a fixed speed engine. Link to comment Share on other sites More sharing options...
john.k Posted February 27, 2023 Report Share Posted February 27, 2023 Dont you get extra fuel for a cold start by pulling out the stopper?.........I know you can pull out something for excess fuel..........not that I need it in the blazing heat. Link to comment Share on other sites More sharing options...
Steve56 Posted February 27, 2023 Report Share Posted February 27, 2023 1 hour ago, john.k said: Dont you get extra fuel for a cold start by pulling out the stopper?.........I know you can pull out something for excess fuel..........not that I need it in the blazing heat. Yes that is correct. Pull the stop lever out and let it rotate in an anti clock rotation. This allows the pumps to open up and deliver more fuel to aid cold starting. It is important that the stop lever is returned to its normal position immediately after start up. Link to comment Share on other sites More sharing options...
RLWP Posted February 27, 2023 Report Share Posted February 27, 2023 18 hours ago, knares said: ok guys this is what i have got dose it look normal, or is some thing missing the wire is the stop cable All correct for a fixed speed engine Richard Link to comment Share on other sites More sharing options...
knares Posted February 27, 2023 Author Report Share Posted February 27, 2023 thanks guys, all my questions answered, now i need to look some where else the cold start is interesting Link to comment Share on other sites More sharing options...
Steve56 Posted February 27, 2023 Report Share Posted February 27, 2023 19 minutes ago, knares said: thanks guys, all my questions answered, now i need to look some where else the cold start is interesting All the cold start does is allow the pumps to open up a little more and deliver more fuel. Also some of these engines have plastic cups on top of the ducting and screwed into the inlet manifold. This is another cold starting device. It allows you to inject oil on top of the piston which raises the compression and aids cold starting. Link to comment Share on other sites More sharing options...
bizzard Posted February 27, 2023 Report Share Posted February 27, 2023 And some have a 12v heater element in the induction air intake to aid cold weather hand starting with the decompression levers. Link to comment Share on other sites More sharing options...
Steve56 Posted February 27, 2023 Report Share Posted February 27, 2023 7 minutes ago, bizzard said: And some have a 12v heater element in the induction air intake to aid cold weather hand starting with the decompression levers. To be fair never seen a heater element in the inlet manifold of an ST engine. Also if the engine is a hand start engine it seems unlikely that 12 volt would be available. But in saying that I could be wrong. Link to comment Share on other sites More sharing options...
bizzard Posted February 27, 2023 Report Share Posted February 27, 2023 10 minutes ago, Steve56 said: To be fair never seen a heater element in the inlet manifold of an ST engine. Also if the engine is a hand start engine it seems unlikely that 12 volt would be available. But in saying that I could be wrong. Mine has, probably an industrial inlet manifold. It's not connected as I have a startermotor. It starts instantly in the winter without any help from de comps ect. Link to comment Share on other sites More sharing options...
knares Posted February 27, 2023 Author Report Share Posted February 27, 2023 Just now, bizzard said: Mine has, probably an industrial inlet manifold. It's not connected as I have a startermotor. It starts instantly in the winter without any help from de comps ect. this one starts ok, but its 40c here some days Link to comment Share on other sites More sharing options...
