Sneill Posted November 2, 2022 Report Share Posted November 2, 2022 Hi guys I am assisting a mate onboard his newly acquired boat which is running a DM2 engine. Is it normal for a pair of water pipes to be connected from the engine to the circulation pipes that run from his Multi fuel burner with back boiler to his Calorifier ? This is in addition to two more smaller pipes that run from the engine to the coil of the calorifier. Your assistance as always greatly appreciated Tia Link to comment Share on other sites More sharing options...
matty40s Posted November 2, 2022 Report Share Posted November 2, 2022 It is not unusual, and would depend on who designed the system and what the requirements were for heating/cooling as to why this configuration exists in this boat. Link to comment Share on other sites More sharing options...
Sneill Posted November 2, 2022 Author Report Share Posted November 2, 2022 Would you know if this set up would be pumped or just working on convection? Link to comment Share on other sites More sharing options...
MtB Posted November 3, 2022 Report Share Posted November 3, 2022 (edited) 8 hours ago, Sneill said: Would you know if this set up would be pumped or just working on convection? Well there must be a water pump on the DM2, so yes, pumped. I doubt the water would circulate around this circuit by natural convection. The stove-to-calorifier circuit could be either. Is there a problem or a fault you are trying to solve? Edited November 3, 2022 by MtB Add a bit. Link to comment Share on other sites More sharing options...
PaulJ Posted November 3, 2022 Report Share Posted November 3, 2022 (edited) Does it also have any valves/ diverters to a skin tank? It could also possibly have an additional pump if the pipework is long or convoluted. I can think of at least one boat I have come across setup like this. As Matty40s says its all down to the who and why- heres an example of a system on a boat I was on recently. Luckily the seller had left a good set of instructions! Edited November 3, 2022 by PaulJ Picture gone strange 1 1 Link to comment Share on other sites More sharing options...
David Mack Posted November 3, 2022 Report Share Posted November 3, 2022 44 minutes ago, PaulJ said: Luckily the seller had left a good set of instructions! But has never thought of labels! 1 Link to comment Share on other sites More sharing options...
PaulJ Posted November 3, 2022 Report Share Posted November 3, 2022 Just now, David Mack said: But has never thought of labels! Nor simplicity 😀 1 Link to comment Share on other sites More sharing options...
alan_fincher Posted November 3, 2022 Report Share Posted November 3, 2022 1 hour ago, PaulJ said: Does it also have any valves/ diverters to a skin tank? It could also possibly have an additional pump if the pipework is long or convoluted. I can think of at least one boat I have come across setup like this. As Matty40s says its all down to the who and why- heres an example of a system on a boat I was on recently. Luckily the seller had left a good set of instructions! Worth owning shares in a fir that makes gate valves! Almost unbelievable.... except obviously not! 1 Link to comment Share on other sites More sharing options...
MtB Posted November 3, 2022 Report Share Posted November 3, 2022 1 hour ago, David Mack said: But has never thought of labels! Probably couldn't find enough! Link to comment Share on other sites More sharing options...
