colin1325 Posted October 27, 2007 Report Share Posted October 27, 2007 hi someone else has just been talking about diesel heaters are they good value for money , do you need to run them for long , does fuel stove give off more heat, you can pick up logs etc free gratis, do the boats ie relativly new ones , retain the heat well all these questions and more colin Link to comment Share on other sites More sharing options...
bottle Posted October 27, 2007 Report Share Posted October 27, 2007 Hi Colin All heaters have a heat output rating ie. 4Kw so an oil or coal one at that rating will give off 4Kw, the difference comes from the amount of energy you have to put in to get that heat out. Easy too find out with oil, manufacturers usually give the amount of oil required per hour, with solid fuel there are many variables, such as type,grade etc of the coal or wood. Oil heaters will give out a constant heat, whereas coal or wood the heat increases and decreases with the loading and burning of the fuel. As to the question of the boat retaining heat, this will depend on the type of insulation fitted, probably the best to have is 'sprayfoam' (in my opinion). I cannot explain with figures but to raise the temperature inside you have to put in more heat than is being lost. Link to comment Share on other sites More sharing options...
colin1325 Posted October 27, 2007 Author Report Share Posted October 27, 2007 Hi Colin All heaters have a heat output rating ie. 4Kw so an oil or coal one at that rating will give off 4Kw, the difference comes from the amount of energy you have to put in to get that heat out. Easy too find out with oil, manufacturers usually give the amount of oil required per hour, with solid fuel there are many variables, such as type,grade etc of the coal or wood. Oil heaters will give out a constant heat, whereas coal or wood the heat increases and decreases with the loading and burning of the fuel. As to the question of the boat retaining heat, this will depend on the type of insulation fitted, probably the best to have is 'sprayfoam' (in my opinion). I cannot explain with figures but to raise the temperature inside you have to put in more heat than is being lost. I CAN UNDERSTAND THAT STATEMENT Link to comment Share on other sites More sharing options...
denboy Posted October 27, 2007 Report Share Posted October 27, 2007 i run a lockgate/refleks diesel stove no electric running costs runs on a gravity drip feed system (although i run a pump as my diesel tanks are lower than the heater} wich is heating 2 4 x 2 double radiators and heats the water in a twin coil clarifyer it burns aprox 1 gal of gas oil a day on the lowest setting and keeps the boat at roughly 75 deg and piping hot water it runs 24/7 in the winter and only goes out if i run out of diesel or i turn it off pound for pound its roughly the same price as coal but dearer to buy but you do have the advantage that you dont need to have coal bags stored on board basicly i light it and forget it till i turn it off Link to comment Share on other sites More sharing options...
DHutch Posted October 27, 2007 Report Share Posted October 27, 2007 Depends what you talking about. - The lockgate diesal squirals seam to be fairly trouble free and good. And they look nice in the room too! However if were talking about eberspachers/webastos they seam to expesive to buy, expersive to run, expesive to maintain and repair, and unreliable. - And even thats when they arnt shooting 4 ft flames out of the exhast accross the towpath! Personally im happy with the bog standerd squirall jobbie, and can only base my above comment on others experiences. - However an attraction i could see, if the ablity to have a heating system that could be set on a time, if you worked thought the day and lived onboard. Anf for that, i would proberbly give the job to a Alde boiler (gas). Daniel Link to comment Share on other sites More sharing options...
Travis Posted October 27, 2007 Report Share Posted October 27, 2007 We have a Kabola D5 fitted which uses no electricery. It runs 4 rads thru the boat and supplies hot water. I give it a good decoke every couple of months or so (half hour job) and is utterly reliable. This will be our 4th winter on board and we have not been cold yet. In the middle of winter we can use £80 pounds worth of diesel a month. I will be converting the boiler to burn heating oil next year for obvious reasons, so our heating costs should reduce the winter after. Also I am interested in the pump that Denis mentions, I would like more info on that please. Andy. Link to comment Share on other sites More sharing options...
denboy Posted October 27, 2007 Report Share Posted October 27, 2007 (edited) We have a Kabola D5 fitted which uses no electricery. It runs 4 rads thru the boat and supplies hot water. I give it a good decoke every couple of months or so (half hour job) and is utterly reliable. This will be our 4th winter on board and we have not been cold yet. In the middle of winter we can use £80 pounds worth of diesel a month. I will be converting the boiler to burn heating oil next year for obvious reasons, so our heating costs should reduce the winter after. Also I am interested in the pump that Denis mentions, I would like more info on that please. Andy. its this one but 12 v http://www.midlandchandlers.co.uk/24V-HARD...VES_A3OGB.aspxe cheaper from lockgate Edited October 27, 2007 by denis boyle Link to comment Share on other sites More sharing options...
colin1325 Posted October 27, 2007 Author Report Share Posted October 27, 2007 does no one run a solid fuel and diesel heater? in conjuntion with each other Link to comment Share on other sites More sharing options...
denboy Posted October 28, 2007 Report Share Posted October 28, 2007 does no one run a solid fuel and diesel heater? in conjuntion with each other Why youll only cook used to have 2 squirels on mine 60 ft only made the mistake of lighting them both once in feb didnt do it again had too leave the doors open all night Link to comment Share on other sites More sharing options...
chris w Posted October 28, 2007 Report Share Posted October 28, 2007 I run a Webasto which heats the calorifier (60L), two large rads and a towel rail in the bathroom. It's output is 5KW, the boat is toasty warm and the diesel consumption is extremely low. It will use 0.5 litres of diesel per hour from cold, BUT only for the first 20 minutes, then it switches into economy mode which uses 0.25 litres per hour thereafter. So, if you ran it for say 6 hours, your total consumption of diesel would be 1.6 litres. Pretty economical and a very effective heating source. Chris Link to comment Share on other sites More sharing options...
GUMPY Posted October 28, 2007 Report Share Posted October 28, 2007 With the price of diesel as it is and likely to go up, I would go for a solid fuel stove. When I had a Morso on the narrowboat I used about 1 x 25kg bag a week maybe 1.25 bags per stove. At £6.50 a bag thats about £8 a week or £1.16 a day or just under 5p an hour Any diesel stove uses a minimum of 0.25L an hour so if diesel is 51p thats 12.75p an hour or £12.50 a week if you leave the stove on 24/7. It is getting very close to me removing my Old Dutch diesel stove and reverting to solid fuel. Assuming I fit it myself it would pay for itself in 35weeks with diesel prices as they are today. In a years time if forced to use full price diesel because you dont have a second tank you could halve that time. Julian Link to comment Share on other sites More sharing options...
chris w Posted October 28, 2007 Report Share Posted October 28, 2007 Julian From a purely financial point of view you are totally correct, but surely not everything in boating is to do with the lowest price? I always get the impression on this forum, from the continual whining about cost and the ability to save a £, that the majority of people are on the breadline which I don't believe for a minute. Sometimes one trades price for comfort and convenience. I love my coal stove too - it works really well and is "sehr gemutlich" , but it is messy and cumbersome compared to switching on the Webasto so it's "horses for courses". Each has their place. For drying towels over a radiator after a shower safely and quickly, the Webasto can't be beaten. I could sell my cars and go by bike and save a ton of dosh each year but it's not so convenient or comfortable! Chris Link to comment Share on other sites More sharing options...
colin1325 Posted October 28, 2007 Author Report Share Posted October 28, 2007 I run a Webasto which heats the calorifier (60L), two large rads and a towel rail in the bathroom. It's output is 5KW, the boat is toasty warm and the diesel consumption is extremely low.It will use 0.5 litres of diesel per hour from cold, BUT only for the first 20 minutes, then it switches into economy mode which uses 0.25 litres per hour thereafter. So, if you ran it for say 6 hours, your total consumption of diesel would be 1.6 litres. Pretty economical and a very effective heating source.Christhats really good chris from what others say they think its as if not more expensive to live on board i cant think it is . i am at present running two properties and know there is not much fun in doing so . god knows where people live but elec and gas rates rent and the rest of it come out to a pretty penny in my part of the world cornwall. gues things must be very cheap up past the bridge maybe some one has had the good idea to put people off turning to liiving on their boats lolWith the price of diesel as it is and likely to go up, I would go for a solid fuel stove.When I had a Morso on the narrowboat I used about 1 x 25kg bag a week maybe 1.25 bags per stove. At £6.50 a bag thats about £8 a week or £1.16 a day or just under 5p an hourAny diesel stove uses a minimum of 0.25L an hour so if diesel is 51p thats 12.75p an hour or £12.50 a week if you leave the stove on 24/7.It is getting very close to me removing my Old Dutch diesel stove and reverting to solid fuel. Assuming I fit it myself it would pay for itself in 35weeks with diesel prices as they are today. In a years time if forced to use full price diesel because you dont have a second tank you could halve that time.Julianhi is red diesel at present 50p a lite yesWith the price of diesel as it is and likely to go up, I would go for a solid fuel stove.When I had a Morso on the narrowboat I used about 1 x 25kg bag a week maybe 1.25 bags per stove. At £6.50 a bag thats about £8 a week or £1.16 a day or just under 5p an hourAny diesel stove uses a minimum of 0.25L an hour so if diesel is 51p thats 12.75p an hour or £12.50 a week if you leave the stove on 24/7.It is getting very close to me removing my Old Dutch diesel stove and reverting to solid fuel. Assuming I fit it myself it would pay for itself in 35weeks with diesel prices as they are today. In a years time if forced to use full price diesel because you dont have a second tank you could halve that time.Julianhi jules it would be 21.42 at 24/7 for a week colin however if you had it on forsay 6 hours a day 5.35 for the week 278.46 a year 0.8925p per day god thats good Link to comment Share on other sites More sharing options...
GUMPY Posted October 28, 2007 Report Share Posted October 28, 2007 (edited) is red diesel at present 50p a lite yes Somehow my figures must have got mangled in my head, didnt use a calculator! 0.25L hr cost 12.5P 24hrs cost £3.06 7 days £21.42 compared to coal thats £13.42 a week more expensive. so thats 32 weeks to buy a solid fuel stove For me there is no point in only having a stove on for 6 hours a day in the winter you sit there waiting for the boat to warm up and then have to relight it in the morning................... Even with both heating sources ( Mikiuni and rads plus the stove) I still find that the stove is on 24/7 throughout the winter. My last lot (594L at the begining of October) was £292 however I get a 2pL quantity discount, there have been price rises since then so it could be as high as 55pL. With both a diesel stove on 24/7 and a Mikuni to heat the water and bathroom I reckon to easily use 1000L of diesel over the winter. Julian Edited October 28, 2007 by idleness Link to comment Share on other sites More sharing options...
smileypete Posted October 28, 2007 Report Share Posted October 28, 2007 does no one run a solid fuel and diesel heater? in conjuntion with each other Without a shoreline, this would be my ideal setup. Coal or diesel stoves can also help keep the boat dry as they're extracting air from the inside. Forced air diesel heaters can be used on a timer which can be handy. cheers, Pete. Link to comment Share on other sites More sharing options...
GUMPY Posted October 28, 2007 Report Share Posted October 28, 2007 Without a shoreline, this would be my ideal setup. Coal or diesel stoves can also help keep the boat dry as they're extracting air from the inside. Forced air diesel heaters can be used on a timer which can be handy. Exactly what I have here, decided upon after 15years experience living aboard. Julian Link to comment Share on other sites More sharing options...
colin1325 Posted October 28, 2007 Author Report Share Posted October 28, 2007 Somehow my figures must have got mangled in my head, didnt use a calculator!0.25L hr cost 12.5P24hrs cost £3.067 days £21.42compared to coal thats £13.42 a week more expensive.so thats 32 weeks to buy a solid fuel stoveFor me there is no point in only having a stove on for 6 hours a day in the winter you sit there waiting for the boat to warm up and then have to relight it in the morning...................Even with both heating sources ( Mikiuni and rads plus the stove) I still find that the stove is on 24/7 throughout the winter.My last lot (594L at the begining of October) was £292 however I get a 2pL quantity discount, there have been price rises since then so it could be as high as 55pL.With both a diesel stove on 24/7 and a Mikuni to heat the water and bathroom I reckon to easily use 1000L of diesel over the winter.Julianhi julian thanks you r right of coarse but it is still about bla de bla cheaper than warming my house at present we have 12 spaces a few of em we dont even get to use but my wife insists on having the back door open and then she will tell me that she is cold i can suffer the cold but she cant colinSomehow my figures must have got mangled in my head, didnt use a calculator!0.25L hr cost 12.5P24hrs cost £3.067 days £21.42compared to coal thats £13.42 a week more expensive.so thats 32 weeks to buy a solid fuel stoveFor me there is no point in only having a stove on for 6 hours a day in the winter you sit there waiting for the boat to warm up and then have to relight it in the morning...................Even with both heating sources ( Mikiuni and rads plus the stove) I still find that the stove is on 24/7 throughout the winter.My last lot (594L at the begining of October) was £292 however I get a 2pL quantity discount, there have been price rises since then so it could be as high as 55pL.With both a diesel stove on 24/7 and a Mikuni to heat the water and bathroom I reckon to easily use 1000L of diesel over the winter.Julianhi julian thanks you r right of coarse but it is still about bla de bla cheaper than warming my house at present we have 12 spaces a few of em we dont even get to use but my wife insists on having the back door open and then she will tell me that she is cold i can suffer the cold but she cant colinsorry while your heating boat is the diesel heater heating the water for boat as well or what sorry i have to ask Link to comment Share on other sites More sharing options...
jayjayranger Posted October 28, 2007 Report Share Posted October 28, 2007 stupid question coming but do diesal feed boilers give of any smell esp the reflex drip feed ones Link to comment Share on other sites More sharing options...
GUMPY Posted October 28, 2007 Report Share Posted October 28, 2007 stupid question coming but do diesal feed boilers give of any smell esp the reflex drip feed ones No I have an old dutch, same idea as reflex and no smell. Flue length is critical and on a NB you will need at least 3ft above the roof. The only time it can smell is if you get a downdraft but thats the same on a coal stove. Julian Link to comment Share on other sites More sharing options...
chris w Posted October 28, 2007 Report Share Posted October 28, 2007 stupid question coming but do diesal feed boilers give of any smell esp the reflex drip feed ones My diesel heater (Webasto) doesn't give of any smell into the cabin at all. It's installed in the engine hole of a cruiser stern. Chris Link to comment Share on other sites More sharing options...
Yoda Posted October 28, 2007 Report Share Posted October 28, 2007 The lowest common denominator is a solid fuel stove ie wood or coal. If you have one then you can heat and cook without requiring any other means. So if you run out of gas/heating oil/shore electricity or diesel you still have the ability to look after yourself. Link to comment Share on other sites More sharing options...
chris w Posted October 28, 2007 Report Share Posted October 28, 2007 We once stupidly ran out of coal while moored up sheltering from terrible rain storms for a day in the middle of nowhere so the diesel heater saved us. The best plan I guess is not to be dependent on a single source of heating. Chris Link to comment Share on other sites More sharing options...
colin1325 Posted October 28, 2007 Author Report Share Posted October 28, 2007 can you get hot water from the diesel heater / solid fuel heaters Link to comment Share on other sites More sharing options...
bottle Posted October 28, 2007 Report Share Posted October 28, 2007 Yes and yes but it depends on the model, design. Link to comment Share on other sites More sharing options...
denboy Posted October 28, 2007 Report Share Posted October 28, 2007 can you get hot water from the diesel heater / solid fuel heaters and you can cook on them too Link to comment Share on other sites More sharing options...
