Chimney problem
Karl
The other day I swept the chimney as I’ve done several times over the years but I’ve also changed the coal and now I’ve got tar running down the side of the roof and even coming down the chimney into the boat. I can see it running down the outside of the chimney in the boat and when it lands on the top of the stove it stinks and has even taken the paint off the top of the stove. I have gone back to the old coal and even though the tar is still coming through it is less. If I burn logs it stops but is more exepensive as I buy kiln dried logs. Why has this started doing this ? Is it just because I changed coal and has more tar in it ? Does it just need burning off in the chimney ?
The new coal make be making the issue worse but it isn't the actual issue...
The tar dripping down the flue is almost certainly due to a leak in the sealant between the flue and the collar and needs redoing, worst case it may be a hole/corrosion in the flue at the top, allowing tar to drip back into the boat.
The tar outside might be more related to the new coal but it's almost inevitable whatever coal is used, best way to mitigate this is a good quality tight fitting double skin chimney
Whatever you do to fix the tar problem, do make sure to remove the tar from the external paintwork as soon as you see it, ideally before it dries. It does stain very efficiently, which I hope you haven’t found out to your cost.
