rusty69 Posted September 5, 2019 Report Share Posted September 5, 2019 (edited) 1 hour ago, cutandpolished61 said: ge f162d/835/4p is the GE code. I definitely have to change them. Drawing to much power. So that code suggests a 240V lamp. Are you sure they aren't running through your inverter? Turn it off will soon prove it (assuming you aren't plugged into shorepower or a generator). Edited September 5, 2019 by rusty69 Link to comment Share on other sites More sharing options...
Boater Sam Posted September 5, 2019 Report Share Posted September 5, 2019 They are 12v fittings with a small inverter on a pcb inside connected to the on off switch, built in, a 7" square white plastic cover, can't remember who's make but I have 6 of them. They were very popular 20 years ago! I put another switch in them and a length of LED strip lamps stuck to the back behind the 16w D tube. So I have the choice of LED or Fluorescent or both together. A lot of light. I am doubtful if you could simply replace the tube with an LED replacement without changing the wiring inside. They use 4 pin 16w tubes without a seperate starter, the inverter takes care of starting. 2 Link to comment Share on other sites More sharing options...
Jen-in-Wellies Posted September 5, 2019 Report Share Posted September 5, 2019 (edited) 10 minutes ago, Boater Sam said: They are 12v fittings with a small inverter on a pcb inside connected to the on off switch, built in, a 7" square white plastic cover, can't remember who's make but I have 6 of them. They were very popular 20 years ago! I put another switch in them and a length of LED strip lamps stuck to the back behind the 16w D tube. So I have the choice of LED or Fluorescent or both together. A lot of light. I am doubtful if you could simply replace the tube with an LED replacement without changing the wiring inside. They use 4 pin 16w tubes without a seperate starter, the inverter takes care of starting. Excellent. Some information from someone who has used them on a boat. My personal opinion is that the best way of converting these fittings to LED would be to strip out the mini inverter/starterr and the tube from inside and replace them with a suitable multi LED flat panel connected to the 12V input, as shown in the Bedazzled link I put in a previous reply. This would save the power loss from having to convert 12V to 240V, then back down to voltage inside a mains LED replacement and possibly still be powering the starter, even though it is no longer needed. Jen Edited September 5, 2019 by Jen-in-Wellies Link to comment Share on other sites More sharing options...
