WotEver
Patron
Everything posted by WotEver
  1. Despite living in Birmingham and now Nuneaton I don’t know the area at all but thanks, I’ll check it out if I can. I’ll take a close look on Google maps and see if I can locate where you mean
  2. Thanks I’ll see how my schedule pans out but I might be able to make a short road trip next week.
  3. How close can you get to it by car (and park)?
  4. Sea Dog addressed that in #12. One of your bottles runs out. You now have x weeks to replace it. If you can’t find a supplier on the correct side in that time then you probably ain’t cruising very much.
  5. Which, at the end of the day, might actually be simpler I guess.
  6. Why couldn’t the doors just be an inch short, effecting the vent that way? Someone else suggested this earlier.
  7. I guess you could but I wonder if the back of the casing is strong enough to take the nut? It could be quite a thin casting at that point. The net result isn’t much different to Sam’s suggestion I suppose, although yours wouldn’t leave a hole for muck to ingress onto the flywheel, IF the casting is sufficiently strong.
  8. You’d fish out the remainder of the bolt once the starter motor was off but as you point out, how would you fit a new bolt? Sam’s suggestion appears to me to be your only way forward.
  9. In that case I think Sam’s idea of cutting a hole in the back of the casing is your only sensible way forward. You could fit a small aluminium plate over it afterwards if you wanted to keep the muck out, but that wouldn’t be essential.
  10. If you grip the head with a pair of mole grips (if there’s enough metal left to do so) and pull hard while turning, does anything happen?
  11. See David’s post. He explains it better than I did. I have no idea about your insurance policy but if you don’t feel confident to change the thermocouple then don’t. Or indeed 907 screws into 891, which is the grill control valve.
  12. A thermocouple has the end that pokes into the flame, and a ‘tube’ running from the back of it. At the end of the tube is a fattened out bit with a captive nut. This end connects to the valve. If wiggling it makes it work then either the nut is loose or there’s a break within the tube bit. If it’s loose, tighten it. If the fault is internal, replace it So in your diagram 908 screws into 912. If that nut is loose (unlikely) then tighten it. If the other end isn’t in the flame then move it. If wiggling it has any effect whatsoever then replace it.
  13. You’ll just be pushing it more into the flame.
  14. You’ll need to PM David with your email address.
  15. A thermocouple is usually dead easy to replace. A nut at the far end connects it to the valve and that’s it.
  16. The gas pipe connects (via the control valve) to the jet. The burner sits on top of the jet. The gas comes out of the jet then through the holes in the burner.
  17. 2.5mm over 5m @ 30A will only drop a volt. Your problem is connections along the way. Check each glow plug too - they should each have a cold resistance of 0.55 ohms. If you find one that’s infinite then it’s burned out.
  18. I’d also try replacing the black relay. They only cost a couple of quid and the contacts don’t last forever.
  19. Yes and no. I maintain that two mains earth bonds to the hull will have zero detrimental effect.
  20. I hated that bloody fox.
  21. Mind the what? OW!!!
  22. Correct. So without an earth bond an IT short could have the hull sitting at 230V. Hence I disagree with the RCD’s statement that the bond ‘need not’ be present.
  23. Yes. It proves that it’s not bonded
