monkeyhanger
Everything posted by monkeyhanger
Historic/Working Boats/Ex Working Boat..Whatever
monkeyhanger replied to Chris-B's topic in General Boating
He's setting off for Ricky already! -
Photo number 10 might just be "Harry", which, with a full length conversion, was moored in Kingsland Basin, Hackney for a number of years. When sold, the new owner sadly neglected to have a survey done, and shortly afterwards, after being drydocked for blacking, a rivet broke as the dock was being refilled. Remedial action was taken to prevent sinking, but the hull was found to be in a sorry state. Subsequently resold, the new owner had her taken to WFB (wrecking the 3 cylinder Dorman on the way due to lack of cooling water), where the hull was found to be in such a state that only the bow section was worth salvaging.A virtual rebuild and a new engine (a JP2)ensued. A sad story, but a nice looking boat now.
I can highly recommend Mick Betts. He lives on narrowboat "Agnes Blomfield" just below Cosgrove lock.If you go, please say Jack recommended him.
I have a JP2, and in that, the engine oil and gearbox oil are one and the same thing. If, by gearbox, you mean a reduction box (between the forward/reverse box and the propshaft), I'd recommend Hypoid 80 or 90 in that.
Probably best not to say when you're going.You've told everyone where you live, and nere do wells might guess your house will be empty.
Except that the mini flywheel weighs several pounds, whereas the JP flywheel weighs several hundredweight!
Natural rope. Have you used this stuff? Is it as good as "proper" creosote that we used to be able to get? If it smells like proper creosote it may be OK, because the smell used to stop the local cats using my fenders as a scratching post!
Just got new bow and stern fenders for my boat, and I would like to treat them with some preservative before I hang them on the boat. In the past I've used a mixture of old engine oil and creosote, but I've now used it all up and I can't buy any more creosote in the quantity I need ( about two litres) What does everyone else use, if anything?
I've had work done here:- Phelps transport 24-26 White Post Lane Hackney 0208 533 3399 I can really vouch for the quality of their work. They fitted new elements in my JP injector pump and recalibrated it. They are almost canalside too, being on the Lea, just before the junction with Duckett's Cut. I doubt you'd do better. Jack
As a moorer in London, I've got used to making sure my front doors are locked from the inside when travelling through urban areas, especially when working locks. It's very easy to be distracted and this can allow undesirables on your boat.
Removing oil/grease from steel.
monkeyhanger replied to Rod a mod from Tod's topic in Boat Building & Maintenance
I've always felt that the white spirit cuts through the oil and grease, then the washing up liquid helps disperse the white spirit. Final washing with warm water gets rid of the washing up liquid. When I've used on engine bays of cars it has left a slight sheen on painted and plastic areas. I've always assumed that this was from the remains of the white spirit, but, from what people have said, it may actually be from the washing up liquid. However, in using this method for over 30 years, I can honestly say that I've never had a problem with paint not adhering properly. All I can suggest is that, if you are worried, try it on a part that is accessible or can be removed and cleaned with a different method should problems arise later. Jack -
APOLOGIES--sorry, I should have said 4 PARTS WHITE SPIRIT and 1 PART WASHING UP LIQUID.If you were to use the first "recipe" you'd have a boatful of bubbles! Jack. -
I've used it for over 30 years when degreasing engines,car parts, boat parts etc, in fact anything that required heavy duty degreasing. I was told about it by a mate who repaired London taxis for a living, and he swore by it. I've never had any problems with this method, but I do rinse off well afterwards. It's important to use warm or hot water to do this- cold water does work but not as well, and the heat from hot water aids the drying process afterwards. I also use "Bonda rust primer" if painting is required afterwards. Wonderful stuff. Not easy to get, but worth searching out. Jack -
I normally use a mixture of 4 parts washing up liquid (Fairy is best) and 1 part white spirit. Put them in a jamjar and give it a good shake until they mix together. Use an old paintbrush (a 1 inch one will be about the right size) and paint all over the engine and engine bay, rubbing well into all the nooks and crannies, to get rid of all the grease and oil.Make sure that the area is dry when you do this, or it won't work.Once you've cleaned it all, wash off with warm/hot water. Allow to dry. Apply paint. Job done! -
I got mine from my local plumbers merchant. Cost me all of 10 pence.
That boat is "Opportunity", owned by Laburnum Boat Club, which is a watersports based youth club on the Regents canal in Hackney
A warning to people intending to visit, or pass through London. Yesterday I boated from Cowley to the East End of London. There is quite a bit of weed on the Paddington Arm, especially on the London side of the North Circular aqueduct, and it gets worse the nearer to central London you get. BW had their weed scooper machine tiding up in the pool at Little Venice, but I suspect this is merely cosmetic,what with the tourist season in full swing. The weed extended all the way to my mooring at the east end of the Regents canal, and had quite an effect on slowing down my journey time. There is a lot of stringy weed growing up from the bottom, which meant that my trip involved a lot of reversing to clear the blades, and had an effect on my speed through the water, and there is great deal of floating green weed, which although this doesn't cause any navigation problems, it quite often looks like you're boating over a bowling green! I wonder if the floating stuff is the seed for the stuff that always wants to grab your prop? The situation has been bad on the Lea Navigation for some years now, and it looks like it's spreading! The weed grows in the summer, reaches its peak around the middle/end of August, and then dies away again, until next Spring when it begins all over again. Be warned that you may need to extend your journey times if you intend visiting the capital in the near future.
When I passed through Slapton on the GU a couple of days ago, I noticed, in one particular pound, six dead carp floating on the surface. Most were quite large, one looking to be over two feet long. I found it strange to find so many in such a small length of canal. Shortly afterwards, in the same pound, I saw three long black furry creatures slip into the water from the edge of a field. I assume that the animals were mink. I wonder if the two sightings were connected?
Thanks to all the people who ventured forth with information. It looks like I've got the correct injector pump, which was my main concern. I've still got to sort the diesel leakdown problem, however. I've got another pump as a spare, which, incidentally DOES have a dipstick, so I guess I'll have to give that a try and see what happens. Thanks again. Jack
I'm certain I looked through the engine 'ole doors at this engine at the weekend at Braunston. Don't recall seeing the 'ecky thump name, though. Jack
It's the marine version. Pump and flywheel are next to each other. Jack
I'm not on the boat at present, so I've had to dig out some old photos from when I built the engine in my front garden! From the photos it appears the the front (flywheel) cylinder is fed from the port furthest from the engine centre line. I assume you're referring to spill timing the injection- I've done that and it's correct. Jack
Sounds like a very sensible solution. My pump, unfortunately, does not have a dipstick fitment, so I have made up a small swan neck pipe and fitted it to what I assume is the oil level plug in the back of the pump body. I have a small catch can located underneath the swan neck to collect the drips. Interestingly, if I drive the boat gently, or have a few locks to go through, the catch can will remain empty. If I have a lockless section and get the chance to wind the engine up for a length of time so that it gets good and hot, I can then expect to find a can of oil/diesel mixture there the following morning. I've often wondered if there may be a crack in the pump body which only opens up enough when it gets really hot. Jack
Thanks for the prompt reply. I have recently had new elements put in the pump, and had it recalibrated. The engine always starts first time and doesn't smoke more than would normally be expected, but it does seem to have a mind of its own as regards tickover. On occasions it will run well for (say) a week, then it will decide to tick over slowly, and the hand start mechanism rattles, so I adjust the speed up a little, then the following day it runs faster and I end up fiddling again to slow it down a touch. The joys of old engines, I suppose! On a slightly different tack, I find that I have an amount of leakdown of diesel from the upper chamber of the CAV pump into the oilbath at the bottom, so diluting the oil. I'm concerned about wear and potential damage to the cam due to the lack of lubrication of the diesel compared to pure oil. I find that I regularly have to put a good squirt of oil in there to compensate, with the subsequent problems of overfilling the pump sump. Do you think I'm being overcautious? Jack
