Mods-
How about automatically preventing more than say 6 replies to a thread for every post by the original poster?
If OP doesn't come back, thread is closed.
If you read the CRT article you will notice that it is intended for boaters with restricted mobility at accessible moorings.
If you are concerned about the design there is nothing to stop you using a lighterman's hitch round the base.
Yes, looks like you set a precedent.
At the time I had and still have a current BSS. I think my installation will be compliant at renewal. Fingers crossed.
I just declared my self converted boat as electric, no questions asked.
I think the only requirement is that the prop is driven by an electric motor not diesel.
The 69A current you are seeing is fine.
It will be going to the theater not the battery. A VSR in place of the split charge diode would give you a better charging Voltage. Otherwise I think you're OK. 15 seconds is quite a long burst of power for a bow thrusters.
Not seized, that would cause excess current draw by the starter motor. It's only about 300A so not seized and not a Volts drop fault in the wiring either, the Volts drop is In the battery.
