Morris
Everything posted by Morris
  1. Thank you for the detailed reply Tony, but also botheration! You have confirmed my fears, but much better finding out now rather than after buying it and the first shopping trolley or encounter. Sadly it's the only one I've seen so far that didn't remind me of the smell of finding old unwashed football socks in my school bag. Ah well, better widen the search area. Thanks again.
  2. We are currently thinking about buying a cruiser and have seen one that ticks pretty much every box, apart from the engine being on a sail drive (beta marine) . Am I right to be wary of this set up or is it potentially robust enough? I'm not sure what weed hatch arrangement it has (if any) either. Anyone have any experience of navigating the canals with such a set up?
  3. I'm always delighted when I see there is an update on the best thread on cwdf (it's my favourite anyway)! Fantastic work.
  4. This seems like the best solution, taking the axial load off the gearbox and allowing the engine to jiggle about however it likes without affecting the stern tube & gland. I've only got 11" between the gearbox flange and the stern tube seal though, so no chance of fitting that lot in. I'm seriously considering relocating the engine, but Mrs M says she doesn't want it in the kitchen.
  5. Sorry can't help with a name but I have seen a water can on Instagram which looks to be by the painter of that gorgeous cabin block. At least it gives you an approximate date! There is a can in flowers afloat (p15) in a similar style but no name is given for the painter.
  6. I agree with Mr Vagabond, they look like dead woodlice. You wouldn't generally see them crawling about as they like to find dark damp places to hide. Not sure what they do there. Win at hide and seek maybe. Do you run the tap a bit first before filling the jar?
  7. Not sure if anyone would be interested to see these, but a relative has some pictures and memorabilia from 1978 which I believe was the first year of the Basingstoke canal cruises on the John Pinkerton. The skipper was John Hulbert.
  8. Just went to buy a tester (dial type) , tested it and the pointer was just below the lowest measurement on the scale (12 deg C). I like your idea Phil, but unfortunately we don't have a freezer. (BTW that's a nice dipper in your avatar. Ron hough iinm) Based on this (the reading, not the dipper) would it be best to drain it down?
  9. Our boat is currently out of the water and we are going to be away for most of December. The coolant in the engine/skin tank is of unknown age/antifreeze protection quality and I am somewhat concerned about it freezing whilst we are away. Would it be best to test antifreeze (are testers reliable?) and if it seems OK from that leave as is, or drain down?
  11. Just tested one of mine using your method - wasn't flat. In my head it sounds like 'poy-curt'
  12. 101362E & 101363E I think are the Wuppertal Schwebebahn 101596E - NRM York
  13. 101353E bus on left showing 'Driffield via Staxton' is a Beverley Bar bus, with curved roof to allow it to fit through Beverley North Bar. 100937E from Import 1 is Beverley North bar (Dont know if you've got these already but 100936,937 and 942 are taken in Beverley too. 941 is Withernsea)
  14. I was just about to buy this but the listing had already ended. It is heading to the UK though, anyone on here? https://www.ebay.co.uk/itm/166411166796 I think I'm right in saying it is by Frank Jones?
  15. Thank you for the link and additional explanation, I appreciate it.
  17. Thanks for the replies, fwiw I wasn't trying to get away with an unsafe installation, I'm actually pretty darn risk averse! I had been reading past threads on the topic and thought that some knowledgeable folks had suggested that something other than option 5 was acceptable, but I probably misunderstood. This is what I was envisaging in this (at present completely hypothetical) situation, my thinking being that the charger would only be used very occasionally (once a week/fortnight) and plugged in for maybe 2-3 hours at a time. I'm interested in this, because it seems to be the opposite of what is written on this page http://www.tb-training.co.uk/MarineE11.html#MAINS Electricity ie, 'without a working earth system the RCD cannot work'.
  18. When setting up a battery charger for occasional use to be powered by shore power on an otherwise 12V only boat what degree of permanence do you feel is advisable/ would you feel comfortable with? 1) shore lead in through window/pigeon box, 16 to 13a socket converter, charger attached to batteries with croc clips. 2)as per 1 but battery charger has 16v plug, is attached to batteries and fused 3) as per 2 but with shore power inlet fixed to outside of boat 4) as per 3 but with gi & hull earth bonding 5) as per 4 but with consumer unit. 6) other
  19. Thanks for posting that documentary Ray, just watched and really enjoyed it.
  20. She looks really nice, I'm looking forward to seeing your progress. If you need any substandard welding doing give me a shout!
  21. Sold by BW in 2010 I believe, one owner since then. I went to see it a couple of weeks ago and was very tempted but thought I would want to do more to it than I have time for at the moment. Shame because I love its unconventional look. Yes I remember seeing it at around 25k because to me at the time it seemed very reasonable at that. Then I looked into wooden boats a bit more a decided I didn't have a clue! I remember it being marked as sold too.
  22. I don't think I've seen Carnaby mentioned on this thread yet? https://narrowboats.apolloduck.co.uk/boat/harland-and-wolff-40-traditional-for-sale/744627
  23. Is it common for shells to be built without knees? Ours has two stringers along the inside but nothing extending vertically from the framing on the baseplate. Would it be beneficial to fit some? (For the purposes of this discussion assume that removing the fit out is not an issue.)
  24. Actually I do remember a music video (I think it was for chasey lane?) where the lead singer held up a card with that phrase on so I thought it might be a reference to them. But I like to make ornithology jokes that invariably fall flat.
  25. Good username op, I am also a sulidae fan but alas have only had opportunity to see the gannet thus far.
