Content Count
2305 -
Community Reputation
16 NeutralAbout stuart
- Birthday 12/20/1975
Gender
Location
West Midlands
Previous Fields
Boat Name
nb Dusk till Dawn
Boat Location
West Midlands
Contact Methods
Website URL
http://www.waterexplorer.co.uk
7892 profile views
Looking at the brochure, the rubbers are about the same size as the washer - thats 33.7mm in my case, so the rubber is likely 32mm. Interestingly, they also appear smooth, without the "top hat" so I think this may just be a side effect/moulding of them being crushed against the bearing!
Thanks Tony. The original parts quote "P30-R: silent rubber blocks should be compressed to 13 mm."
On second thoughts, https://www.whiteline.com.au/product_detail4.php?part_number=W31487 TOYOTA LAND CRUISER 1981-1991 - LAND CRUISER 60 SERIES HJ TOYOTA LAND CRUISER 1980-1990 - LAND CRUISER 60 SERIES FJ TOYOTA LAND CRUISER 1985-2000 - LAND CRUISER 70 SERIES Appears to be a good match. Bush Type Bush Qty OD A ID B L C FL D FLOD E C/Tube QTY C/Tube Size Similar Bushing Size 7 4
Looks like the mini part is too small, the outside diameter at 32.8m is smaller than the washers on the Pythondrive @ 34mm. The "top hat" is also 18mm vs 14mm. I might give it a go anyway and see what happens! These are the dimensions I got from this site https://www.whiteline.com.au/product_detail4.php?part_number=W81156&sq=280666
Isuzu 35HP 4LB1 - Water hose replacement
stuart replied to stuart's topic in Boat Building & Maintenance
For anyone who's shopping online to find heater hose, I found https://www.autosiliconehoses.com/rubber-hose-radiator-heater-epdm-automotive-hoses-black.html to be the most competitive priced, and free delivery if you spend over £40. -
I'd agree @Alan de Enfield but I'd struggle to find hose that is 34mm I/D, you have to go with the standard sizes. There is a single barb on the inlets rather than smooth tube though, so if I can get the clamp around that, should be good. -
I took the plunge and pulled the pipes off to measure as I couldn't find any information online. Here's the results, in case it helps somebody else. On the bottom of the header tank, is a 35mm outlet, requiring 35mm I/D hose The other side of the pump is also a 35mm I/D hose (marked X below) On the thermostat to header tank connection, it's a 90 degree bend. A = 32mm outlet, requiring 32mm I/D hose B = 72mm C = 112mm D = 100mm The hot water take off for the calorifier is -
Thanks Tony, I'll see if I can find the dimensions for those, the 'top hat' looks a little wider in the photos I've found. May see if my local motor factors has some to look at.
Thanks Tony. I've just been to the boat to remove them. They have a 10mm hole for the bolt, the bushing is now 39.6mm in diameter (after being squashed) and 13 to 14.7mm thickness. There is a little top hat that fits into the python unit, only a few mm tall and 14mm in diameter. The metal washer that pushes against this is 33.7mm diameter. As expected hard as nails after all these years
stuart started following Isuzu 35HP 4LB1 - Water hose replacement and Python Drive - replacement parts
Opening a REALLY old thread here, but I've still not replaced the bushings - 6 years later they are still grazed, but working, although the boats hardly done any miles in that time. I'm going to take a look this afternoon to measure up for after market parts. My boats been left unloved for a number of years, so ignore the rust!
Hello everyone, Its been a very long time since I last posted, but I'm hoping you can help. I've an Isuzu 35hp engine, model 4LB1 - which I've had for 15+ years now. It's still using the original EPDM rubber hoses between the engine and skin tank for cooling, I'd like to swap those out to avoid failure due to the hoses getting brittle. I've checked all over the existing hoses for the dimensions and found nothing - does anyone know what the internal diameter of the Isuzu water outlet/inlets are? I've read through the service manuals, and whilst it
I implemented that logic in my diybms as well.
@MoominPapa just for information, I've implemented the DIYBMS v4 code tonight to provide a pulsed output on the relays should it be required. The relay switches on for about 100ms - anything less and the relay can't switch fast enough so nothing happens.
I've used PCBWAY and JLCPCB, no problems with either.
You'll like my youtube video of reflowing using a frying pan then !!
