tosher
Everything posted by tosher
  1. I have Sterling 3KW inverter (combi unit) about a year old, the fans do run quite often, for short periods, but only when the inverter/battery charger is working quite hard. When just floating the batteries on shore power the fans never run. This inverter was a replacement for my original one that kept tripping out, the fans on that one never ran at all so maybe that caused the fault. It was replaced by Sterling after 2 years free of charge. tosher.
  3. Just noticed that on the back of my licence holder it states "YOU MUST DISPLAY YOUR LICENCE - IT IS A LEGAL REQUIREMENT". I'm sure some people would argue that it does not say "Current" licence but most people fully understand what it means and do comply.
  4. Call Shureflo LTD. Tel 01293 424000 Get it straight from the horses mouth. tosher
  6. Just carry a small shovel, cr@p on the canal bank and then throw it in the canal with the shovel. Just like hundreds of dog owners do with their dog cr@p !!!!!! Only joking!
  7. This bit of kit works fine for me as well. May be worth a mention that the Vetus manual states that the max length of usage for a 55kg bow thruster (12volt at 375amps or 24volt at 205amps) is -- 4 minutes continuously or maximum of 4 minutes per hour.
  8. Thanks for that, the Izusu engine manual says that if a calorifier is NOT fitted then both the take off and return pipes on the engine should be blanked off and not connected directly together so I assumed that blanking just the supply off for engine warm up would be OK.
  9. Slightly off topic but has something happened to Chris-W, I doubt he could resist responding to a thread like this. Hope he's OK.
  10. That is correct, the pipes to the calorifier are taken off and returned before the thermostat. A 12v solenoid valve of the correct bore, fitted in the calorifier supply and controlled from a switch on the engine panel labled "Fast Warm UP" may be the answer?
  11. If I start my Izusu 42 from cold with cold water in the calorifier and drive away immediately it takes at least 20 minutes, maybe longer, for the temperature gauge to reach normal operating temperature of about 85 deg. If however I close the water valves from the engine to the calorifier, the engine is up to temperature in less than half the time, about 8 or 10 minutes. If I then open these valves the engine temperature falls back to about 75 deg and slowly returns to normal as the calorifier warms up which takes about a further 15 minutes. So on a completely cold boat the engine warm up period can be reduced by approx 50% by isolating the domestic hot water system until the engine is hot. Is that a good practice to adopt???
  12. Does the thrust from the hydraulic bow thruster vary with engine speed or is it constant from tickover to full revs? If you have to increase engine speed to increase thrust then this will also increase the main prop speed and hence boat speed. If this is the case then to increase thrust without increasing boat speed would mean selecting neutral first then reselecting a gear to drive the boat, then reselecting neutral again to power up the thruster -------- If the thrust is constant at all engine speeds (as in an electric one) then control would be much easier. tosher
  13. This advice was given to me by Rylards, they say Premium Protection adheres better to the hull/old coating. I did as they suggested just over a year ago but the boat has not been out of the water since so can't comment on it's effectiveness. tosher.
  14. Here is the question that many people will be thinking --- How do you download the latest software? tosher.
  15. I travel all over so can call in most places. tosher
  16. Which type of bow & stern fenders are the most robust and last the longest? The traditional ones constructed from 100% rope or the more recent ones which have some sort of rubber core. Can anyone recommend a good maker or a good place to buy them? Thanks.
  17. I had exactly the same trouble a couple of weeks ago on my Vetus which is 2 years old. No wear on brushes but sticking in boxes and freeing off solved the problem. tosher.
  18. A quick call to HMI Plant, the main UK dealer for Izusu enginines would end the confusion. They are very helpfull with queeries from boaters. tosher.
  19. Many thanks for your replies, just the information I was looking for. Very helpful. Cheers.
  20. I am fitting a shore power socket in the cratch area at the front of my boat. Could any one tell me if there is a minimum height above the well deck or water level at which it should be sited to conform with the lates regs ????. Many thanks.
  21. Would you share your experiences of using a bow thruster with us all, must be pretty bad to make such a damning statement.
  22. Thanks Chris -- a man of your word. Excellent guide, like others I will tackle my first service with confidence. After 2 years light use it's never been touched and never missed a beat but who knows what I might find insde? Quite looking forward to doing the job now. Cheers again Chris. --- tosher
  23. The next time you do it Chris I'm sure many of us Webasto owners would really appreciate a few pictures, I certainly would. Thanks
