Content Count
652 -
Community Reputation
58 NeutralProfile Information
Gender
Location
Solihull
Interests
Old cars, rock climbing, being outside
Previous Fields
Boat Name
Bimble Be
5079 profile views
p6rob started following Webasto not working properly., Sailing the seas of Confusing Portable Generators and bow thruster or not?
Just before Christmas I bought one of the generic German 3.5KW frame generators. It's rated as 96db, so not even close to silent. On the plus side, it has metal panels, so not a fully open frame and I've added some sound deadening, both rubber and foam which has quietened it down but added to the weight. I think the noise level is now less than my boat engine. It was cheap, only 160.00 new from a facebook advertiser and delivered within two hours of enquiring about it. It's needed some very specific positioning of the choke lever to get it to start and the exact position varies almost daily. Checking and topping up the oil is awkward because of the panels There's no way I could lift it on and off the boat from the bow, so have to carry it through the boat, which is awkward and in the process I've broken the fuel line. Luckily I had some better quality fuel hose on board, so only a few minutes to put right. I would have preferred to get something better but it was needed in a rush. Engine head gasket blew, the boat is on a winter mooring in the corner of a silty basin (Cambrian Wharf) I think the skin tank wasn't performing very well because it's knee deep in the silt. I want to see if I can make it quieter. To me it doesn't sound too bad now, from inside the boat it's less annoying than my boat engine partly because there's less vibration and the windows don't rattle but the other evening, there were two people sitting on a bench nearby, when I turned the generator off one of them said, "bloody hell that was loud, they should ban people running generators". The fact they had managed to sit within about 15meters, while it was running, makes me wonder if it really is that bad but that being said, I don't like generating noise at the best of times. Rob
I'm terrible at reversing but manage most of the time and seem to have less mishaps than people who rely on the bow thruster, especially when they find they've drained the BT battery before completing their manoeuvre and then have no clue how to recover the situation. One of the few places I need to wind and reverse is Cambrian Wharf. Sometimes things go really well and I seamlessly manage to wind the boat on a sixpence and reverse into one of the spaces without touching the sides, other boats or pontoon and step off, rope in hand like a pro. Other times the boat seems to curve all over the place, I miss the winding hole, have to fend off the boats and generally make a pigs ear of it. I've been intending to do a boat handling course for the last 7 years, Maybe next year it'll actually happen. Rob
If the batteries are fully charged, it sounds like voltage drop through too thin cables, or a high resistance connection. As a test, try running an extra pair of positive and negative cables from the battery to the heater. If it then runs, either make the new cables part of the install, with an inline fuse, or replace the existing ones with thicker cables. Rob
As soon as I found out about them, I've only used goat chains or rings, except when we randomly tried tying up before the start of the 2018 BCN challenge somewhere with no rings or armco. I found my stakes, unused since 2011 but not the hammer which I hid sometime ago because my son had an annoying habit of hitting things with it. Peter X and I knocked the stakes in as best as possible with a 1" spanner iirc, so pretty badly, however they held all night with some passing traffic. Would mud weights be of any extra benefit if you have to use stakes? Rob
There's been a few boats moored for longer than overnight recently, just above the top lock. Don't think they came to any harm. I moved from Birmingham to Knowle over the weekend. The elsan was in a terrible state, mainly because it's been blocked up and seeping sewage into the bin area. Spent three hours on Saturday trying to clear it up, then reported it to CRT and they're getting in touch with the contractors to fix it. Apart from that, it's quite a nice place. My work backs onto the canal about 600 yards up from the top lock.
Hi Stefan, Not specific to matt black paint but generally speaking you should stick to the same manufacturer for the primer, undercoat and top coat. I'm using Craftmaster rust treatment, primer, undercoat and top coat on my cabin bilge at the moment. Not sure if they sell matt black off the shelf but I had them mix me a small pot of a specific RAL colour in their signwriting paint for an old car I own, which arrived next day so presumably matt black wouldn't be an issue. They're very helpful both online using their contact form and over the phone. craftmasterpaints.co.uk Rob
Thanks everyone. Mind back at ease now. I do have a wet and dry vac but not one I want to chuck, however, there does seem to be quite a few on ebay to choose from, around the price of a pump out, so that could well be a viable alternative. Rob
Hi, As part of refitting my boat, I'm removing the unused pump out tank. Before my ownership, the boat had a dump though toilet which had long since been removed and the porta potti sat on top of the tank with a plate over the dump through hole. I've now discovered the tank is about 1/3 full of at least six year old bodily fluids and is a bit too heavy to maneuvre without risking spillage. If I reconnected the pipes, would it pump out successfully or will the hole where the toilet should be cause an issue? In my head, pump outs require vacuum to work but now I'm wondering if it's just a suction pump pulling the liquids up but then how do they cope with solids. The tank sits low in the boat, so not sure how I could successfully siphon it into portable containers for elsan disposal. Also, if anyone wants a stainless steel dump through tank there's one available very soon, currently in Cambrian Wharf with or without existing contents. 🤢 Thanks in advance Rob
I'm guessing I've missed some excitement! The floor still isn't sorted that's for sure. I've got all the boards and joists but it's been an experience cutting to fit, finding the board wouldn't fit through the door. Taking it back to my mother's to cut, returning again finding it would fit through the door but needed a bit more shaving off, etc. Replacing the floor without removing the side panels is proving to be an endurance feat with at least a few more weeks to complete. Rob
It's a job to tell and unfortunately those are the most rotten joists and literally fall apart when you touch them but from what I can make out, the extra bits are the full height of the joist. I don't think so. The amount of work that would have gone into fitting them at that stage wouldn't have made any sense.
It has been proving quite difficult. The most frustrating thing is my boat is in Lapworth, right by Curtiss' timber yard and pass it everyday going to work. I can see the stuff I want, neatly stacked at the side of the road but they are shut. Realistically, I can just wait a bit longer to order the wood and spend longer cleaning, prepping and painting the metal.
Thanks for the replies. There were four reasons for the standing water. A long term leak from the hose to the bathroom sink taps, which I fixed when I bought the boat six or seven years ago. The shower tray having a crack, which will be replaced as part of the refit, the pipework to the carolifier, which I'm not convinced is fully cured at the moment but as it'll all need to be disconnected to fit the new floor, will be. Oh and a partial sinking when the base plate had a hole in it, that one has definitely been fixed! I'm attempting to buy the wooden joists today. Rob
I'm stripping out the interior of my boat to replace rotten floors and joists. The joists are 75mm x75mm what type of wood should I use? Are fence posts adequate? Also on some of the transverse beams it looks like 12mm x 75mm pieces had been screwed to both sides, why would that would be? Would it be better to get 100x75mm posts to replace them? The boat has had a lot of standing water in the cabin bilge for some time, so a few of the joists have been squidgy enough to pull apart by hand. It's a job that I've been wanting to do for a couple of years but a frozen shoulder has prevented it until now. Thanks in advance. Rob
Thanks. I suspect I'll just keep replacing the batteries every couple of years until li-ion controllers become affordable but might take these ones into work and use their fancy charger to see if that perks them up a bit first. The isn't much electrical stuff in use. If all the lights are on they draw under 3 amps and the lights might be on for six hours per day in winter, The water pumps run for about 15 minutes a day in total. Phone charges overnight but the internet dongle is always plugged in. On the rare occasions I use the TV, the engine tends to be running, same with vacuum. Only really use the laptop on its battery. The diesel heater gets used about 30 times a year when the weather is chilly but not worth having the stove going. Fridge and water heater are both gas.
