Paloma Bob
7 Followers
    uk
  • Occupation
    retired
  • Boat Name
  • Boat Location
Paloma Bob's Achievements
Explorer
Explorer (2/12)
13
  1. If you'd like to give me a call on 07932-815-207 I'll see what I can do to help. Regards Bob
  2. 1: Ignition switch mechcanism is damaged..... Replace switch. 2: Safety lock out is preventing you from igniting it. This is normally caused by oxcidistation of the alloy, preventing the full closure of the main burner gas valve and therfore the safety will not allow ingition. Replace the main alloy body, which pretty much equates a rebuild. Palomabob (Still working) Tel:07932-815-207
  3. If you need to contact me regarding your Paloma water heater, then please give me a call on: 07932 815 207
  4. Call me if you've not managed to sort it. Palomabob Tel: 07932 815 207
  5. Sounds like a partial blockage in the bypass, de-scale the water inlet control valve including the slow ignition valve, check the venturi is clear and that the pressure plate springs back smoothly. Although de-scaling will clear limescale, it won't clear silicon and alike sealants, which I've found to be one of the biggest killers of Paloma water heaters.
  6. First guess, not enough gas ! Main valve opens to feed burners, what little gas there is goes there rather than the pilot, hence the pilot goes out.
  7. Yep I'm still above the ground 👍
  8. Thank you, if you could give me a call when its available that would be great as I don't drop in here that often. Regards Bob Tel: 07932 815 207
  9. By any chance would you be selling the Rinnai water heater ?
  10. The 'O' ring seal on the activating rod has failed, allowing water to pass from the water control valve and exiting via the weep hole. To replace this its best to remove the whole burner assembly and dismantle the diaphragm housing. Looking at the condition of the weep hole I would be surprised if the return spring has not rusted away too.
  11. Hi Pip, If you'd like to give me a call I'll see what I can do to help. Regards Bob Tel: 07932 815 207
  12. If you need to call me, my number is 07932 815 207 Regards Palomabob
  13. Hello,
    A forum member suggested I ask you about the leak problem on my water heater (posted on forum a few minutes ago). It has not been caused by frost as we have not had any yet! Any help would be most welcome.
    1. Paloma Bob
      Paloma Bob
      Hi there,
      If you've not managed to to sort this then please give me a call on 07932 815 207
      Regards Bob
  14. Hi. I’m hoping you can help me. I have a Paloma PH5-3F and the gas burners aren’t coming on to heat the water. The temp adjustment valve is ceased as well, but this didn’t effect the burners until now. I have dismantled it from the heater and tried descaling, also tried WD40. I have replaced the diaphragm, but nothing’s working. There is good water flow and the pilot lights no problem. When I turn the tap off quickly the burners light open for a split second and then go out. If I turn the tap off slowly they don’t light up. I thought maybe trying this a few times would free things up, but it’s not improving.
    Any sensible suggestions on what to try next very much appreciated
  15. Looking to get my paloma waterheater fixed/recon model- PH-5-3F mark v, Just heard about Paloma Bob and wonder if any body has his number, Many thanks Kevin.
    1. Paloma Bob
      Paloma Bob
      Hi Kevin,
      My number is 07932 815 207
      Regards Bob
