flat terybat
Timx
I quite liked Smiley Pete's list. Seemed to cover every possibility.
For diagnosing any problems like this it's good to have a half decent multimeter as a bare minimum.
The problem itself could be one or more of: failing batt(s), defective alternator, failing starter, bad batt isolator, defective or undersized split charge relay, corroded or loose batt terminals, poorly made or corroded crimp terminals, broken alt or split relay connections, undersized wiring so on....
Trying to diagnose the problem via a forum without any voltage or current readings whatsoever is really not the best way to go.
In the longer term it'd be good to fit a half decent panel voltmeter, and at least get some idea of what readings to expect when things are working normally.
cheers, Pete.
~smpt~
Are you a relative of Stanley Unwin?
Edited by Chris Pink
mm so the dial saying both or 1 or 2, we have left at both so they are connected, so at night best thing to do is change to one or two as not sure as which is which
mm so the dial saying both or 1 or 2, we have left at both so they are connected, Yes so at night best thing to do is change to one or two Yes as not sure as which is which See Chris's post above.
This also implies that you do not have an automatic, split charge system (relay or diode) but manual selection.
Depending on how the connections are configured: assuming no.1 is the start battery ands no.2 is domestic.
Select no.1, start engine, when engine running, select Both.
When moored and engine stopped select no.2.
To start enigine, select No.one....
