IdealStandard Posted January 23, 2013 Report Share Posted January 23, 2013 I am trying to finish off plumbing in a mini CH system, but some of the junctions just don't want to play ball! The main problem is that alot of the plumbing is in the engine bay and I have therefore used 1/2" thermal hose. Plumbers obviously don't like messing around with hoses and there are no fittings to be found! One of the fittings I am having trouble with is a 3/4" male bsp to 1/2" hose. Is there a direct converter, or am I going to end up with some convoluted mish mash? The next is a 1" bsp male which I also want to get down to 1/2" hose, which is even more awkward. My current thinking is that it might be easier to take the 1" bsp down to a 15mm copper and jubilee clip a hose straight on. If anyone could recommend anything it would be appreciated. Tim Link to comment Share on other sites More sharing options...
alan_fincher Posted January 23, 2013 Report Share Posted January 23, 2013 One of the fittings I am having trouble with is a 3/4" male bsp to 1/2" hose. Is there a direct converter, or am I going to end up with some convoluted mish mash? Why not try Google. I found this at my first attempt, and there look to be plenty of other options..... Link to comment Share on other sites More sharing options...
IdealStandard Posted January 23, 2013 Author Report Share Posted January 23, 2013 Why not try Google. I found this at my first attempt, and there look to be plenty of other options..... I have tried google, although I find the search terms kind of tricky with this sort of thing. Just to clarify, the fitting is 3/4" bsp male, so I need a 3/4" female. Link to comment Share on other sites More sharing options...
alan_fincher Posted January 23, 2013 Report Share Posted January 23, 2013 (edited) The next is a 1" bsp male which I also want to get down to 1/2" hose, which is even more awkward. My current thinking is that it might be easier to take the 1" bsp down to a 15mm copper and jubilee clip a hose straight on. Customers who bought this also bought this I won't even ask why on earth you are getting involved in something like 1" BSP for boat plumbing, though! Just to clarify, the fitting is 3/4" bsp male, so I need a 3/4" female. I can see that now, but in original post I'd say it's not entirely obvious! Maybe reduce 3/4" BSP to 1/2" BSP with something like this, then use this Edited January 23, 2013 by alan_fincher Link to comment Share on other sites More sharing options...
IdealStandard Posted January 23, 2013 Author Report Share Posted January 23, 2013 (edited) Customers who bought this also bought this I won't even ask why on earth you are getting involved in something like 1" BSP for boat plumbing, though! The 1" is a header tank fitting. it's awkward, but it was cheap. Edited January 23, 2013 by IdealStandard Link to comment Share on other sites More sharing options...
alan_fincher Posted January 23, 2013 Report Share Posted January 23, 2013 The 1" is a header tank fitting. it's awkward, but it was cheap. Maybe, but only if you don't spend double figures on expensive couplings to adapt to it!...... Link to comment Share on other sites More sharing options...
IdealStandard Posted January 23, 2013 Author Report Share Posted January 23, 2013 Maybe, but only if you don't spend double figures on expensive couplings to adapt to it!...... True! I didn't even consider it at the time. Link to comment Share on other sites More sharing options...
smileypete Posted January 23, 2013 Report Share Posted January 23, 2013 (edited) You can get from almost anything to anything with these: Screwfix and Toolstation do them, BES do a great range; well worth getting a paper copy of the BES catalogue. 15mm compression fittings almost always use a 1/2" BSP thread which opens up some possibilities. Also a tube of Fernox LS-X leak sealer can be very handy. cheers, Pete. ~smpt~ Edited January 23, 2013 by smileypete Link to comment Share on other sites More sharing options...
Timleech Posted January 23, 2013 Report Share Posted January 23, 2013 midland sw*ndlers do a useful range of BSP to hose brass fittings, here. Other chandlers are available. Tim Link to comment Share on other sites More sharing options...
Ray T Posted January 23, 2013 Report Share Posted January 23, 2013 This lot may be able to help. http://www.pirtek.co.uk/ Link to comment Share on other sites More sharing options...
matty40s Posted January 23, 2013 Report Share Posted January 23, 2013 This lot may be able to help. http://www.pirtek.co.uk/ I think that someone should say something about this abuse...... Link to comment Share on other sites More sharing options...
Puddlejumper Posted January 23, 2013 Report Share Posted January 23, 2013 you just have to get bsp to hose fitting normaly called tail fitting any plumbers merchant should stock emm Link to comment Share on other sites More sharing options...
Chris Pink Posted January 23, 2013 Report Share Posted January 23, 2013 Ok, related question. I've just spent an entertaining hour underneath someone's sink who has a fine collection of speedfit elbows to get the water to go around corners to get to and from the water pump. It occurred to me it would be easier to replace a lot of those elbows with a hose tail and some flexible hose. why is this not done? Link to comment Share on other sites More sharing options...
by'eck Posted January 23, 2013 Report Share Posted January 23, 2013 Just a tip - if wanting to attach rubber hose with clamp to copper pipe, solder a compression fitting olive of same size close to the end of the copper pipe to act as a barb. Push rubber hose over olive and fix with hose clamp after the olive. You won't be forever re-tightenting the hose clips to stop weeping then. Link to comment Share on other sites More sharing options...
smileypete Posted January 23, 2013 Report Share Posted January 23, 2013 (edited) Or try Ebay, here's a 1" BPST male to 1/2" hose tail for £5 http://www.ebay.co.uk/itm/170975041317 Just needs a 1" brass socket to go onto the header tank, something like: http://www.ebay.co.uk/itm/230777362926 It occurred to me it would be easier to replace a lot of those elbows with a hose tail and some flexible hose. why is this not done? Better still use a tap flexible or two... cheers, Pete. ~smpt~ Edited January 23, 2013 by smileypete Link to comment Share on other sites More sharing options...
IdealStandard Posted January 23, 2013 Author Report Share Posted January 23, 2013 Or try Ebay, here's a 1" BPST male to 1/2" hose tail for £5 http://www.ebay.co.uk/itm/170975041317 Just needs a 1" brass socket to go onto the header tank, something like: http://www.ebay.co.uk/itm/230777362926 Better still use a tap flexible or two... cheers, Pete. ~smpt~ Just the ticket. Thanks. Link to comment Share on other sites More sharing options...
