b0atman Posted August 24, 2018 Report Share Posted August 24, 2018 My skin tank has a radiator style manual bleed valve .Is it a workable proposition to have an auto bleed valve ? Link to comment Share on other sites More sharing options...
blackrose Posted August 24, 2018 Report Share Posted August 24, 2018 Does it need to be bled so often that a manual valve won't do? I hardly ever bleed mine and when I do there's not much air in there. I only really use it when changing the antifreeze. Link to comment Share on other sites More sharing options...
Tony Brooks Posted August 24, 2018 Report Share Posted August 24, 2018 I am not sure how an auto bleed valve would cope with a pressurised cooling system at up to about 1 bar, 15 PSI. If it needs bleeding frequently enough to be thinking of fitting an auto bleed valve then the underlying problem needs addressing rather than just covering it up. If you only have the manifold type expansion tank then a remote one may prevent air entering the system each time the system cools down. If its combustion gasses then it needs sorting before you have a major overheat and potentially expensive damage. Link to comment Share on other sites More sharing options...
BEngo Posted August 24, 2018 Report Share Posted August 24, 2018 Auto bleed valves of the compressed cardboard disc type are cr@p. They either leak or they don't bleed. If you want automatic venting and have an unpressurised system just run a vent pipe with an open from where the bleed valve is end to a point above the top of the header tank. With a pressurised system you would need to lead the vent pipe into a Tee just below the header tank, assuming this is where the pressure cap is. N Link to comment Share on other sites More sharing options...
b0atman Posted August 24, 2018 Author Report Share Posted August 24, 2018 OK so its a no go . Link to comment Share on other sites More sharing options...
