Jrtm Posted September 13, 2016 Report Share Posted September 13, 2016 Infact here is davids engine. As you see comes from side up over and back. Even shows the water pipe too. Link to comment Share on other sites More sharing options...
David Mack Posted September 13, 2016 Report Share Posted September 13, 2016 Infact here is davids engine. As you see comes from side up over and back. Even shows the water pipe too. That comes up from between the cylinders, which is what ours did with the old manifold. This is a picture with the old manifold: And with the new: Link to comment Share on other sites More sharing options...
Jrtm Posted September 13, 2016 Report Share Posted September 13, 2016 Yes but look at davids silancer its over the gear box and back head your is over the 2 cylinders. Link to comment Share on other sites More sharing options...
MtB Posted September 13, 2016 Report Share Posted September 13, 2016 Infact here is davids engine. As you see comes from side up over and back. Even shows the water pipe too. Swerving off topic for a sec, what's going on with that starter motor? There is no ring gear on the flywheel so how does it turn the engine over? A rubber wheel or some such thing?! Link to comment Share on other sites More sharing options...
Derek R. Posted September 14, 2016 Report Share Posted September 14, 2016 I think that's a flywheel cover, and is cut close to the starter pinion cover hiding the ring beneath. Link to comment Share on other sites More sharing options...
MtB Posted September 14, 2016 Report Share Posted September 14, 2016 I think that's a flywheel cover, and is cut close to the starter pinion cover hiding the ring beneath. Ah I geddit now. I thought it was an oddly wide flywheel too! Thanks... Link to comment Share on other sites More sharing options...
Jrtm Posted September 14, 2016 Report Share Posted September 14, 2016 Sorry yes had a flywheel cover over the top painted red so sort of looks like part of the flywheel has a cut out for the starter But most you see seam to have diffrent setups but again there are differences on nearly every engine you look at that are the same if im honest. Most nationals you look at have diffrent setups most bollys do even modern engines are diffrent even when put in by same builders Link to comment Share on other sites More sharing options...
