bizzard Posted July 1, 2014 Report Share Posted July 1, 2014 This little wheeze is for folk who, don't know, want to know, don't believe or have been told porky pies concerning the width of there vessel. So here is a very simple, cheap and cheerful way of making a home made boats beam measuring device, without all the expense of fancy electronics or by shooting things like Laser beans all around and about. The GIANT calliper gauge. All that's required to knock up your GIANT calliper gauge is as follows;- Three lengths of wood of about 4X1/2'',one bit about 7'6'' long and two bits about 6' long. 4 4'' nails, 2 G clamps and one hammer. Nail the two 6' long bits of wood end on to each end of the 7'6'' cross beam with one nail each so that they pivot, bang em in hard and bend em over on the back so as to make the pivoting action nice and stiff. Bang a nail right through each lower end of the 6' long bits so that the nail points face each other. these are the all important measuring points. To use your home made GIANT calliper gauge its best to have a bit of help as obviously the calliper is a bit unwealdly due to its necessary size. For those who are unpopular and have no mates in this world need not panic, its still quite easy to perform the measurement on your tod with a little thought, intrepidness, sensibility and your are reasonably fit with a good sense of balance, it should not be a problem. Ok, so with the two G-clamps at the ready held by your mouth, grasp with both hands your calliper gauge and step up onto your cabin roof and stand legs akimbo roughly in the middle with the callipers cross beam resting on your shoulders behind your head like a Dutch milkmaid. Grasp with both hands the side measuring bits that hang down and pull them towards you, bringing the two nails into perfect light contact with your gunwales. Now comes the tricky bit. Gently raise the calliper off the gunwales without shifting the devices pivots which being stiff should stay put. Lay it down on the roof or towpath and bung a G-clamp on at both pivot points for security in case anyone trips or cycles over your device and goes upsets the measurement which will cause you to do it all again. Now all there is to do now is to with a tape measure measure between the two nail points and you will be bestowed with and accurate measurement of your boats beam and can defy anyone who thinks its otherwise.. To measure a hysterical open working type boat or tug where a cabins not in the way you can either stand on the holds floor or again legs akimbo stand by placing a foot on each gunwale to execute the measurement. Also if your boat has two opposite side doors you can perform with a little manipulating of the gauge the measurement in the dry, if it happens to be raining, or out of the sun if you get sunstroke easily. When measurement is completed bang a load more nails in to retain and save the measurement for future reference and proof of width. That's it folks. Link to comment Share on other sites More sharing options...
system 4-50 Posted July 1, 2014 Report Share Posted July 1, 2014 Mk II - Use from a standard hump-backed bridge. Get mate to drive boat through bridge. With the friction set right you will get the maximum width of the full length of the boat. Without moving from the bridge, measure the gap between the top points of your scissors. Move to bank, lay scissors down and set the top gap to the measured value if they have been disturbed. Then measure the nail points gap to get your answer. Main benefit: A new use for bridges. Any good? Link to comment Share on other sites More sharing options...
b0atman Posted July 1, 2014 Report Share Posted July 1, 2014 That's all right for width but what about height ? If you go on Dragons den you can tell them that Standedge tunnel is interested in two sets. Link to comment Share on other sites More sharing options...
bizzard Posted July 1, 2014 Author Report Share Posted July 1, 2014 (edited) Mk II - Use from a standard hump-backed bridge. Get mate to drive boat through bridge. With the friction set right you will get the maximum width of the full length of the boat. Without moving from the bridge, measure the gap between the top points of your scissors. Move to bank, lay scissors down and set the top gap to the measured value if they have been disturbed. Then measure the nail points gap to get your answer. Main benefit: A new use for bridges. Any good? Excellent, you may need extra long arms though or a much deeper gauge. Edited July 1, 2014 by bizzard Link to comment Share on other sites More sharing options...
Paul G2 Posted July 1, 2014 Report Share Posted July 1, 2014 Excellent, you may need extra long arms though or a much deeper gauge. Not if you tie a line around your ankles and hang from the bridge. Although you would need a couple strong chaps to haul you back up. Link to comment Share on other sites More sharing options...
bizzard Posted July 1, 2014 Author Report Share Posted July 1, 2014 (edited) Not if you tie a line around your ankles and hang from the bridge. Although you would need a couple strong chaps to haul you back up. Or just let go when the boat moves off. The calliper gauge should keep him afloat. Edited July 1, 2014 by bizzard Link to comment Share on other sites More sharing options...
YamYam Posted July 1, 2014 Report Share Posted July 1, 2014 Was it Till Death us do Part where Alf measured his wallpaper size above the door by standing back and holding his arms out to get a measurement. That didnt work either Link to comment Share on other sites More sharing options...
Mrs Tawny Owl Posted July 1, 2014 Report Share Posted July 1, 2014 Not if you tie a line around your ankles and hang from the bridge. Although you would need a couple strong chaps to haul you back up. No need, just reverse boat back carefully and get one mate (not necessarily strong) to cut the line. Make sure you don't let the calliper move when you fall neatly on to the roof though or you'll have to do it again. Sue Link to comment Share on other sites More sharing options...
system 4-50 Posted July 1, 2014 Report Share Posted July 1, 2014 There is no reason why the scissors (callipers) shouldn't be permanently attached to a bridge so that everybody passing by can measure their personal dimensions. Nails might be a bit wearing so they could be replaced by castors or small wheels. To aid readability the pivot point needs to be very much lower than the tops so the best site is a very tall bridge such as some of those on the SU such as the Telegraph Pole bridge. The scissors would need to be pegged to prevent them closing altogether. Link to comment Share on other sites More sharing options...
