Doorman Posted August 20, 2013 Report Share Posted August 20, 2013 You can buy the basic indicator from Philippi without panel, part # 514310230 priced €14.20 + 19% VAT a couple of years ago. Although based in Germany their delivery service is within a couple of days. Thanks again, it certainly beats Steve's basic A/C input panel on our boat! Link to comment Share on other sites More sharing options...
GUMPY Posted August 20, 2013 Report Share Posted August 20, 2013 Yeah Julian, But we would need a hell of a long shore line lead whenever we went cruising on that basis! I find a curly cable works well I leave mine at the moorings as I rarely use shore power when away, but then if I felt that I would need it I would just take it with me and deploy it when necessary. Link to comment Share on other sites More sharing options...
NorthwichTrader Posted January 31, 2014 Report Share Posted January 31, 2014 Did mine with an 8mm s/s nut & bolt, had access to some 16mm earth cable so used it, don't think it needs to be that thick though. Gibbo said good job, so good enough for me That looks neat, Julynian...I've got a little bit of welding being done in the engine room over the W/E so thought I might get a couple of bolts welded in for AC/DC earthing at the same time! Does SS conduct the same as mild steel? Any issues with using it? Also, is there any reason why the bolts can't be welded half way up the bulkhead wall, for example, or is a bottom crossmember, or even the base-plate itself a better proposition? ALSO, 12v and 240v within 3" of each other, is that ideal? Link to comment Share on other sites More sharing options...
WotEver Posted January 31, 2014 Report Share Posted January 31, 2014 Yes nearasdammit. It's (arguably) harder to weld. No, it doesn't matter. Yes. T Link to comment Share on other sites More sharing options...
NorthwichTrader Posted January 31, 2014 Report Share Posted January 31, 2014 Yes nearasdammit. It's (arguably) harder to weld. No, it doesn't matter. Yes. T Cheers, much appreciated...as always! Link to comment Share on other sites More sharing options...
Keith M Posted February 1, 2014 Report Share Posted February 1, 2014 That looks neat, Julynian... I've got a little bit of welding being done in the engine room over the W/E so thought I might get a couple of bolts welded in for AC/DC earthing at the same time! Does SS conduct the same as mild steel? Any issues with using it? Also, is there any reason why the bolts can't be welded half way up the bulkhead wall, for example, or is a bottom crossmember, or even the base-plate itself a better proposition? ALSO, 12v and 240v within 3" of each other, is that ideal? Should there not be an appropriate label as well Keith Link to comment Share on other sites More sharing options...
NorthwichTrader Posted February 1, 2014 Report Share Posted February 1, 2014 Will do, thanks, Keith! It's exactly what I'm after, every little detail! Incidentally, are there labels for 12 AND 240 earth points, and should they be labelled separately? Cheers, Stuart Link to comment Share on other sites More sharing options...
Keith M Posted February 2, 2014 Report Share Posted February 2, 2014 Will do, thanks, Keith! It's exactly what I'm after, every little detail! Incidentally, are there labels for 12 AND 240 earth points, and should they be labelled separately? Cheers, Stuart most people put the two fixing points in very close of each other say 20 / 25 mm of each other The labels i use are for 230-volt systems You can get them all electrical wholesaler's Keith Link to comment Share on other sites More sharing options...
