khaffra Posted January 6, 2005 Report Share Posted January 6, 2005 I am considering buying a generator to charge the batteries on my boat to save running the engine if I don't want to move for a while. I have a Victron Invertor/Charger fitted, If I was to hook the generator up to the 240V input of the boat and switch the charger and invertor onto Auto will this then charge the batteries while supplying 240V to the boat as well. (I am presuming this is the same as connecting to a land line?) Also any idea approx what size generator would be required for this (I think the charger is rated at 40amps). Link to comment Share on other sites More sharing options...
colinjw Posted January 6, 2005 Report Share Posted January 6, 2005 Hi khaffra, I've got a 30 amp charger and sterling said that 900 watts would cover it no problem so if you go a bit more you should be safe. BUT.....it would probably work out cheaper (that's the Jockinese in me) and quicker to use your engine to recharge your batteries. Colin Link to comment Share on other sites More sharing options...
nigel carton Posted January 6, 2005 Report Share Posted January 6, 2005 if you can afford a bit extra, i'd go for 2kw Link to comment Share on other sites More sharing options...
nbtafelberg Posted January 7, 2005 Report Share Posted January 7, 2005 I am picking up a 3KW generator today. It runs it at only £600 inc vat (roughly).... GENESIS 3000 3kw - 3.75kva - 230/115v Vanguard OHV- 117 432 engine Oil Safety, Circuit breaker Run Time: 8.9hours Noise Level: 97 lwa Weight: 50 kg http://www.generators.co.uk/silenced/sdmo.htm The more KW you have the more stuff you can run. Hoovers use a lot of power as do microwaves. We have a good system as we have a 1kw inverter, 2x64 watt solar panels and a Sollatek Charge controller/battery regulator with a very cool digital read out. On top of that I've nearly got all the lights replaced with very bright low voltage LUMINA lights (http://www.sollatek.com/Lumina.htm), these are very very good - its dark now and its like daylight in my saloon. Power management on boats is not down to just GENERATING power but the efficient use of the power that is generated. Link to comment Share on other sites More sharing options...
Guest Posted January 7, 2005 Report Share Posted January 7, 2005 We have a 40amp Sterling charger which needs a 2kw genny (quote from Sterling not me)-our genny is only 1kw and this charger stalls it immediately. On our inverter (Sterling) you just switch the inverter to off position and connect to shoreline/genny and the boat runs straight from mains. I do not know if they are all like this. Link to comment Share on other sites More sharing options...
Richard Bustens Posted January 7, 2005 Report Share Posted January 7, 2005 Hi A supply of 900w is the equlivant of only 3.75A landline. which is a bit on the low side. Link to comment Share on other sites More sharing options...
Alastair Posted January 7, 2005 Report Share Posted January 7, 2005 I tried using my 16A charger from a 750W genny. the charger could only put 4A into the batteries from this - very disappointing. Link to comment Share on other sites More sharing options...
bramley Posted January 7, 2005 Report Share Posted January 7, 2005 i also have a genny to run whe engine is not avaible or to noisy, i have a 2.4 kw genny with a 30 amp battery charger, and i can only get in 15amps max, i plan to sell my genny if anyone is intrested 6 months old 72db's i want to get a diesel one Ross Link to comment Share on other sites More sharing options...
Richard Bustens Posted January 7, 2005 Report Share Posted January 7, 2005 Dont forget that if the charger is a good one it will only put what is required into the battery. not the full wack. What does it charge at if you plug into a landline? Link to comment Share on other sites More sharing options...
Alastair Posted January 7, 2005 Report Share Posted January 7, 2005 usually starts at 14, then drops off as the battery charges properly. The generator just can't output enough current. Voltage, yup, not current. Link to comment Share on other sites More sharing options...
John Orentas Posted January 7, 2005 Report Share Posted January 7, 2005 (edited) Alastair. Remember even a fairy large battery can't sustain a charge of more than 7 - 10 amps, the maximum capacity or the charger does not come into it. The charge voltage tells you very little. Edited January 7, 2005 by John Orentas Link to comment Share on other sites More sharing options...
nbtafelberg Posted January 7, 2005 Report Share Posted January 7, 2005 I just picked up my Generator Superb! Worked like a dream... Link to comment Share on other sites More sharing options...
