anthony Posted March 30, 2006 Report Share Posted March 30, 2006 What gear is used nowdays to heat water for the shower ect using gas as the energy source? Could a caravan carver system be used? Link to comment Share on other sites More sharing options...
stuart Posted March 30, 2006 Report Share Posted March 30, 2006 I belive you can still use gas to heat water on a boat. The recommended systems for new installs are ones that are room sealed (ie. they use air from outside to burn through the flue). Although there is some acceptance for older Paloma type heaters due to their excellent safety record. Link to comment Share on other sites More sharing options...
nbtafelberg Posted March 30, 2006 Report Share Posted March 30, 2006 We have a Morco gas boiler that works BRILLIANTLY Link to comment Share on other sites More sharing options...
Graham Bowers Posted March 30, 2006 Report Share Posted March 30, 2006 What gear is used nowdays to heat water for the shower ect using gas as the energy source? Could a caravan carver system be used? See my thread on "advice on selecting a shower head". I have seen one room sealed heater from Morco but at the thick end of £500 and needing a 230V AC supply it was not so attractive to me. I saw it here by the way http://www.marcleleisure.co.uk/index.htm Cheers Graham Link to comment Share on other sites More sharing options...
awatsonbcp Posted March 30, 2006 Report Share Posted March 30, 2006 we use a good ole paloma and have a carbon monoxide detector just in case Link to comment Share on other sites More sharing options...
anthony Posted March 30, 2006 Author Report Share Posted March 30, 2006 Thanks for the info folks. My budget is tight which is why i asked if i could use a modern caravan carver system which is about £300 which is just about my limit. It needs to be safer than safe too. Link to comment Share on other sites More sharing options...
fuzzyduck Posted March 30, 2006 Report Share Posted March 30, 2006 Have a look at one of these, a friend has one fitted to his boat and loves it. room sealed, and weighs in at slightly less than £300 too. http://cgi.ebay.co.uk/Propex-Malaga-high-c...1QQcmdZViewItem Link to comment Share on other sites More sharing options...
DHutch Posted March 31, 2006 Report Share Posted March 31, 2006 we use a good ole paloma... Yeah, same. Its a very nice unit, and has worked faultlessly all its life (15years) - I bealve the morco units are very simular and equally good in use. We also have a calorifyer, which can heat the water using steam from the boiler, or the stove via the central heating loop. Daniel Link to comment Share on other sites More sharing options...
