jockwalt Posted August 29, 2011 Report Posted August 29, 2011 hi any one know suppliers of stainless steel self drill cs screws and a2 metric nuts and bolts at good prices thanks steve
Ex- Member Posted August 29, 2011 Report Posted August 29, 2011 hi any one know suppliers of stainless steel self drill cs screws and a2 metric nuts and bolts at good prices thanks steve I've not come across stainless steel self drill cs screws We used TEK screws but not sure if in SS probably too brittle. I've used a lot of stainless steel fittings lately, I find Screwfix the cheapest but their stock range is limited, I've ended up buying smaller quantities from e-bay other than that just hunted out SS suppliers on line. I only last weekend bought some very nice SS wood screws Torx type cost me over £50 for 400 screws. SS is so expensive just have to shop around.
jockwalt Posted August 29, 2011 Author Report Posted August 29, 2011 I've not come across stainless steel self drill cs screws We used TEK screws but not sure if in SS probably too brittle. I've used a lot of stainless steel fittings lately, I find Screwfix the cheapest but their stock range is limited, I've ended up buying smaller quantities from e-bay other than that just hunted out SS suppliers on line. I only last weekend bought some very nice SS wood screws Torx type cost me over £50 for 400 screws. SS is so expensive just have to shop around. thanks for your info steve
sharpness Posted August 29, 2011 Report Posted August 29, 2011 I picked up a flyer at Crick? (together with some screws I wanted) from A2A4 Fixings ltd in Southampton. They claim to have over 25,000 lines. Might be worth a look. www.a2a4.com & wwwa2a4.co.uk Steve
smileypete Posted September 1, 2011 Report Posted September 1, 2011 hi any one know suppliers of stainless steel self drill cs screws and a2 metric nuts and bolts at good prices Toolstation.com are another one for common sizes, probably not super quality but free delivery over £10. For self tappers maybe cut the thread with an identical normal steel self tapper then put the softer SS one in. cheers, Pete.
steelaway Posted September 1, 2011 Report Posted September 1, 2011 hi any one know suppliers of stainless steel self drill cs screws and a2 metric nuts and bolts at good prices thanks steve Try ScrewFix not stainless but perfectly OK for inside. I used them to fix down my floor to the steel bearers Alex
Ex- Member Posted September 1, 2011 Report Posted September 1, 2011 Try ScrewFix not stainless but perfectly OK for inside. I used them to fix down my floor to the steel bearers Alex I used the same they're perfectly adequate, I've recently had flooring and panelling removed and not spotted any that have rusted 7 years on. Stainless Steel for this application I'm pretty sure would be too brittle and snap, possibly the reason you can't find any. You will need a really good quality and powerful 240 volt drill to get these screws in or be prepared to burn out cheaper drills if you use them. You'll have quite a few failures before you get the knack of getting them through 2 inch bearers and through 4 to 6mm steel in one drilling action. Battening to the roof and sides is much easier though assuming you're affixing 1 inch batten to 1 inch steel ribbing.
steelaway Posted September 1, 2011 Report Posted September 1, 2011 I used the same they're perfectly adequate, I've recently had flooring and panelling removed and not spotted any that have rusted 7 years on. Stainless Steel for this application I'm pretty sure would be too brittle and snap, possibly the reason you can't find any. You will need a really good quality and powerful 240 volt drill to get these screws in or be prepared to burn out cheaper drills if you use them. You'll have quite a few failures before you get the knack of getting them through 2 inch bearers and through 4 to 6mm steel in one drilling action. Battening to the roof and sides is much easier though assuming you're affixing 1 inch batten to 1 inch steel ribbing. Exactly right - on all counts Alex
Justme Posted September 1, 2011 Report Posted September 1, 2011 For self tappers maybe cut the thread with an identical normal steel self tapper then put the softer SS one in. Harder. The problem is that they snap due to the hardness (IE brittle) not due to being to soft.
system 4-50 Posted September 1, 2011 Report Posted September 1, 2011 I got my last lot of A2 & A4 screws from www.screwsline.co.uk some time ago. They are now under new management & I don't know how they compare on price.
